Won't encode a specific track
  • earthbound
    • May 2012
    There is one track on a CD I have that stalls dBpoweramp at 0% encoding. I tried flac and apple lossless encoding with the same result. This is not a CD I particularly care about but I've never had a problem like this before. What might cause this?
    • 46160
    Re: Won't encode a specific track
    Try ripping to Test Conversion, this will tell if is the encoder (or HDD), or reading that is a problem.
    • earthbound
      • May 2012
      Same result when ripping to Test Conversion. dBpoweramp hangs after ripping, at "CPU1 (or2) Encoding 0%"
        • 46160
        Try burst mode ripping.
        • earthbound
          • May 2012
          Same result. Only difference is that progress showed 0% while ripping, then stuck at 0% encoding. I don't really care if I can rip this or not, it's more of a curiosity why it won't work. There are 4 tracks and the first 3 rip OK.
            • 46160
            Do you have any security software?
            • earthbound
              • May 2012
              Yes, Norton Internet Security with latest updates
              My system summary (thanks to Piriform's Speccy):
              Operating System
              Windows 8 Pro with Media Center 64-bit
              CPU
              Intel Mobile Core 2 Duo P8600 @ 2.40GHz 44 °C
              Penryn 45nm Technology
              RAM
              4.00GB Dual-Channel DDR2 @ 398MHz (6-6-6-18)
              Motherboard
              Sony Corporation VAIO (N/A) 47 °C
              Graphics
              Generic PnP Monitor (1920x1080@60Hz)
              2287MB ATI Mobility Radeon HD 3650 (Sony)
              Hard Drives
              932GB Seagate ST1000LM024 HN-M101MBB (SATA) 30 °C
              51MB Ricoh Memory Stick Disk Device (SSD)
              Optical Drives
              Optiarc BD ROM BC-5500S
              Audio
              High Definition Audio Device
              • earthbound
                • May 2012
                Yes, Norton Internet Security. I replied a couple days ago with my PC config (Windows 8, etc) but it didn't get posted. I could send you the CD if you want to play with it.
                  • 46160
                  I think it CD drive related, if you were to try in a different CD drive I have a feeling it would rip without problem.
                  • mdubin
                    • Jul 2013
                    • 42
                    Same thing happened to me. I was not getting accurate rips using an older external CD/DVD burner but was having hardly any problems with my newer laptop internal burner. To make sure, I purchased a new external usb powered CD/DVD burner and everything rips fine with this one too. So in my case, it was definitely drive related.
                    mdubin
