problem with naming scheme
  • Donaldd
    • Oct 2011
    • 9
    I am finally ready to do my definitive rip of all my albums after playing with dbpoweramp for a while.
    Although I have resolved most problems I have come up against the naming scheme still perplexes me.
    I know what I want in the normal part of the naming scheme which is create [artist] directory if not there [album] sub-directory then [track] - [artist] - [title]
    My problem is with compilations :cry:
    Please could someone explain how when ripping a compilation, a folder is created of the title adding ,discx if more than 1 in Various Artists i.e \Various Artists\[album],discx
    and inside the songs are setup as [track]- [artist]- [title]
    I've played around with yours plus the default naming schemes and cannot work out how to get \Various Artists\[album],discx
    When testing an example multi disc I see
    Various Artists\Immaculate, Disc 1 - Disc 1\05 - Madonna - Holiday
    instead of Various Artists\Immaculate,Disc 1\05 - Madonna - Holiday
    Thanks in advance
    • 6189
    Re: problem with naming scheme
    post the string here from your dynamic naming setting so we can see what you've entered to produce the above. (and why would you want a separate album subdirectory for each disk under various artists. Wouldn't it make more sense to have one subdirectory for the album, then a separate disk 1, disk 2, etc. subdirectories underneath the single album name? Like:
    Various Artists/Immaculate/disk 1/track....
    ......................................./disk 2/track...
    I suspect you're getting double disk no. listed because you have the settings for dbpa set to show disk number with album title in another settings location.
    • BrodyBoy
      • Sep 2011
      • 780
      wouldn't it make more sense to have one subdirectory for the album, then a separate disk 1, disk 2, etc. Subdirectories underneath the single album name? Like:
      Various artists/immaculate/disk 1/track....
      +1
