FLAC Problem
  • MegaBit
    • Jun 2013
    FLAC Problem
    Greetings, everybody.
    This is my first post.
    I have done a search about this matter and couldn't find anything about the issue, so I hope I'm doing everything right... :D
    I'm using «dBpoweramp R 14.4» with an old «Fujitsu-Siemens s7100» (Intel T-2500 2.0GHz/4GB of RAM) with Win XP Prof SP3...
    The rest can be seen from the "Secure Extraction Log" of one of those CDs I will append at the end of this document; I'm doing a "RIP to MultiEncoder" with «FLAC», «WAV AsSource» and «WAV 320kbps~48KHz» as the chosen formats.
    With almost all the discs I've ripped - for "«dBpoweramp» fine tuning & future routine procedures" - I'm stumbling upon the same problem.
    No error reported, but while on the (critical) listening test (of the FLAC file) there are songs with missing parts/bits of sound - Strangely enough (or not, you tell me...), both other (WAVs) files do not present any problem! :confused:
    The same happens if I just convert only to «FLAC».
    I have tried changing settings, but still no cigar, even with the most conservative/high quality/slow settings! :headbang:
    Please help!
    TIA,
    Warm regards,
    MegaBit
    dBpoweramp Release 14.4 Digital Audio Extraction Log (Secure Extraction Log)
    Drive & Settings
    Ripping with drive 'D: [MATSHITA - UJ-841Db ]', Drive offset: 102, Overread Lead-in/out: No
    AccurateRip: Active, Using C2: No, Cache: 4 KB, FUA Cache Invalidate: No
    Pass 1 Drive Speed: 6, Pass 2 Drive Speed: 6
    Ultra:: Vary Drive Speed: No, Min Passes: 3, Max Passes: 6, Finish After Clean Passes: 2
    Bad Sector Re-rip:: Drive Speed: 6, Maximum Re-reads: 34
    Encoder: [Multi Encoder] -enc1="FLAC=-uncompressed -verify" -encMopt1=" -tofolder={mqt}B:\!FLAC Lossless\{mqt} -dynamic={mqt}[artist] ~ [album]\[[album artist] ~ [album]] [track] » [title]{mqt}" -enc2="Wave=-compression={mqt}PCM{mqt}" -encMopt2=" -tofolder={mqt}B:\!WAV AsSource\{mqt} -dynamic={mqt}[artist] ~ [album]\[[album artist] ~ [album]] [track] » [title]{mqt}" -enc3="Wave=-compression={mqt}WAVEMP3{mqt} -wavemp3={mqt}-b 320 -encoding={qt}SLOW{qt} -freq={qt}48000{qt}{mqt}" -encMopt3=" -tofolder={mqt}B:\!WAV 320kbps~48KHz\{mqt} -dynamic={mqt}[artist] ~ [album]\[[album artist] ~ [album]] [track] » [title]{mqt}"
    DSP Effects / Actions: -dspeffect1="_MultiEncoder="
    Extraction Log
    Track 1: Ripped LBA 0 to 27350 (6:04) in 2:03. Filename: B:\!WAV 320kbps~48KHz\Allyson, Karrin ~ Ballads - Remembering John Coltrane\[Allyson, Karrin ~ Ballads - Remembering John Coltrane] 01 » Say It (Over and Over Again).IGNORE
    AccurateRip: Accurate (confidence 4) [Pass 1]
    CRC32: 61059497 AccurateRip CRC: 3BF79B4B [DiscID: 011-0019fb03-00dfee04-960e7a0b-1]
    AccurateRip Verified Confidence 4 [CRCv1 3bf79b4b]
    Track 2: Ripped LBA 27350 to 52737 (5:38) in 1:39. Filename: B:\!WAV 320kbps~48KHz\Allyson, Karrin ~ Ballads - Remembering John Coltrane\[Allyson, Karrin ~ Ballads - Remembering John Coltrane] 02 » You Don't Know What Love Is.IGNORE
    CRC32: A5369EB7 AccurateRip CRC: 87186BCC [DiscID: 011-0019fb03-00dfee04-960e7a0b-2]
    AccurateRip Verified Confidence 4 [CRCv1 87186bcc]
    Track 3: Ripped LBA 52737 to 78507 (5:43) in 1:31. Filename: B:\!WAV 320kbps~48KHz\Allyson, Karrin ~ Ballads - Remembering John Coltrane\[Allyson, Karrin ~ Ballads - Remembering John Coltrane] 03 » Too Young to Go Steady.IGNORE
    CRC32: 19B4C18B AccurateRip CRC: 9089DB24 [DiscID: 011-0019fb03-00dfee04-960e7a0b-3]
    AccurateRip Verified Confidence 4 [CRCv1 9089db24]
    Track 4: Ripped LBA 78507 to 109292 (6:50) in 1:39. Filename: B:\!WAV 320kbps~48KHz\Allyson, Karrin ~ Ballads - Remembering John Coltrane\[Allyson, Karrin ~ Ballads - Remembering John Coltrane] 04 » All or Nothing at All.IGNORE
    CRC32: C4AC0742 AccurateRip CRC: 9F586A30 [DiscID: 011-0019fb03-00dfee04-960e7a0b-4]
    AccurateRip Verified Confidence 4 [CRCv1 9f586a30]
    Track 5: Ripped LBA 109292 to 128947 (4:22) in 0:58. Filename: B:\!WAV 320kbps~48KHz\Allyson, Karrin ~ Ballads - Remembering John Coltrane\[Allyson, Karrin ~ Ballads - Remembering John Coltrane] 05 » I Wish I Knew.IGNORE
    CRC32: C911885F AccurateRip CRC: C321BE33 [DiscID: 011-0019fb03-00dfee04-960e7a0b-5]
    AccurateRip Verified Confidence 4 [CRCv1 c321be33]
    Track 6: Ripped LBA 128947 to 155587 (5:55) in 1:15. Filename: B:\!WAV 320kbps~48KHz\Allyson, Karrin ~ Ballads - Remembering John Coltrane\[Allyson, Karrin ~ Ballads - Remembering John Coltrane] 06 » What's New¿.IGNORE
    CRC32: 3A8A26E4 AccurateRip CRC: 51FE2CBB [DiscID: 011-0019fb03-00dfee04-960e7a0b-6]
    AccurateRip Verified Confidence 4 [CRCv1 51fe2cbb]
    Track 7: Ripped LBA 155587 to 182832 (6:03) in 1:12. Filename: B:\!WAV 320kbps~48KHz\Allyson, Karrin ~ Ballads - Remembering John Coltrane\[Allyson, Karrin ~ Ballads - Remembering John Coltrane] 07 » It's Easy to Remember.IGNORE
    CRC32: CB5B878A AccurateRip CRC: EBDAF4DC [DiscID: 011-0019fb03-00dfee04-960e7a0b-7]
    AccurateRip Verified Confidence 4 [CRCv1 ebdaf4dc]
    Track 8: Ripped LBA 182832 to 204307 (4:46) in 0:54. Filename: B:\!WAV 320kbps~48KHz\Allyson, Karrin ~ Ballads - Remembering John Coltrane\[Allyson, Karrin ~ Ballads - Remembering John Coltrane] 08 » Nancy (With the Laughing Face).IGNORE
    CRC32: D145409B AccurateRip CRC: 6D4EE4D1 [DiscID: 011-0019fb03-00dfee04-960e7a0b-8]
    AccurateRip Verified Confidence 4 [CRCv1 6d4ee4d1]
    Track 9: Ripped LBA 204307 to 234230 (6:38) in 1:12. Filename: B:\!WAV 320kbps~48KHz\Allyson, Karrin ~ Ballads - Remembering John Coltrane\[Allyson, Karrin ~ Ballads - Remembering John Coltrane] 09 » Naima.IGNORE
    CRC32: EF0E1D58 AccurateRip CRC: 5A207C92 [DiscID: 011-0019fb03-00dfee04-960e7a0b-9]
    AccurateRip Verified Confidence 4 [CRCv1 5a207c92]
    Track 10: Ripped LBA 234230 to 250890 (3:42) in 0:38. Filename: B:\!WAV 320kbps~48KHz\Allyson, Karrin ~ Ballads - Remembering John Coltrane\[Allyson, Karrin ~ Ballads - Remembering John Coltrane] 10 » Why Was I Born¿.IGNORE
    CRC32: E788D468 AccurateRip CRC: 985C61A9 [DiscID: 011-0019fb03-00dfee04-960e7a0b-10]
    AccurateRip Verified Confidence 4 [CRCv1 985c61a9]
    Track 11: Ripped LBA 250890 to 277980 (6:01) in 1:01. Filename: B:\!WAV 320kbps~48KHz\Allyson, Karrin ~ Ballads - Remembering John Coltrane\[Allyson, Karrin ~ Ballads - Remembering John Coltrane] 11 » Ev'ry Time We Say Goodbye.IGNORE
    CRC32: E8049C2F AccurateRip CRC: 434CB534 [DiscID: 011-0019fb03-00dfee04-960e7a0b-11]
    AccurateRip Verified Confidence 4 [CRCv1 434cb534]
    11 Tracks Ripped Accurately
    • 46198
    Re: FLAC Problem
    Visit here:
    Install the Calculate Audio CRC codec, then convert both the FLAC and WAVE file to this 'encoder', after conversion a CRC number shows, if the number is the same for both FLAC and WAVE then the audio content is identical, and the issue is likely your player which cannot read FLAC correctly.
