Ripping HiRes DVD Audio Discs
  • bjast
    • Mar 2011
    • 72
    I have a bunch of DVD Audio discs left over from when I used to own an Acura TL which had a sound system that would play these. Sweet system. Is there anyway I can rip these into FLAC or better yet, AIFF format, and keep their original 24/96 quality? Thanks.
  • TedSmith
    • Jun 2012
    • 21
    Re: Ripping HiRes DVD Audio Discs
    I tried a few different programs and finally settled on DVD Audio Extractor (http://www.dvdae.com/) None of the DVD Audio extractors I tried ripped all of my DVDAs but DVD Audio Extractor got the most and seems to have done it correctly. I still had to do the metadata with separate programs.
    • Mike48
      • Sep 2012
      • 59
      My experience, also, is that DVD Audio Extractor is better than the others.
      • bjast
        • Mar 2011
        • 72
        Thanks for the input. I'll check this application out.
