PerfectTunes accuraterip : track different length than cd original for all my library
  • PhilippeH
    • Nov 2012
    I have ripped all my library (1108 ablbums) using Windows Media PLayer on Windows 7, all in WMA losseless format.
    I have recently installed PerfectTunes accuraterip. It says for all my albums except 2 tracks corrupted : "Cannot Check : track different length than cd original".
    I have also tested an album ripped by someone else, afert converting it in WMA losseless, and the result is the same.
    Any idea ?
    • 46224
    Re: PerfectTunes accuraterip : track different length than cd original for all my lib
    WMA Lossless has a bug with any player which is not Microsofts own, in that some files decode and are missing samples off the end, if it is missing samples then it appears as though the file did not come from a CD.
    • PhilippeH
      • Nov 2012
      Is there a solution for AccurateRip to work with WMA Lossless ?
        • 46224
        If Microsoft fixed their public WMA decoder then the bug would go away, BTW we reported this to Microsoft 8 years ago...
