Plextor PX-40 TSI / Ultraplex 40 max
  • S0nic
    • Oct 2012
    • 32
    #31
    Re: Plextor PX-40 TSI / Ultraplex 40 max
    here is resultats
    • pablogm123
      • May 2012
      • 86
      #32
      The Sony drive? As expected, doesn't cache audio data (a very good thing when reripping bad frames).
      • S0nic
        • Oct 2012
        • 32
        #33
        this is all for plextor when i finish with plextor then we go to liteon and sony (sony still not have at home only liteon)
        • pablogm123
          • May 2012
          • 86
          #34
          All good then.
          • S0nic
            • Oct 2012
            • 32
            #35
            Originally posted by pablogm123
            All good then.
            ok i will do the same for liteon only without FUA
            • S0nic
              • Oct 2012
              • 32
              #36
              when i recieve sony from ebay i will send you message so then we can make setup for him and liteon ... it will be in next 10 days
              • S0nic
                • Oct 2012
                • 32
                #37
                Pablogm i recieve sony , how i must set settings?
                • pablogm123
                  • May 2012
                  • 86
                  #38
                  Try the same settings that you configured for Plextor drive, but without FUA and read speed 40x. Test if actually doesn't cache audio data. If doesn't cache audio data: 0 KB.
                  • S0nic
                    • Oct 2012
                    • 32
                    #39
                    speed 10x ?
                    • S0nic
                      • Oct 2012
                      • 32
                      #40
                      this is resultat how much to set cache?
                      • pablogm123
                        • May 2012
                        • 86
                        #41
                        No, 20x/40x. I have tested similar drives, and they works better at higher speeds. And 10x is very slow, is actually 4x-10x CAV, not 10x CLV.
                        If the test says that the drive caches 6 KB, enter this amount.
                        • S0nic
                          • Oct 2012
                          • 32
                          #42
                          ok thanks, optirac rip just fine , he rip cd'a what liteOn does not
                          • S0nic
                            • Oct 2012
                            • 32
                            #43
                            i try now to do cache test again , with 40x and now they don't find cache try with few cd's same thing?
                            • pablogm123
                              • May 2012
                              • 86
                              #44
                              I would trust in the last result, it is needed run the test at max speed. A possible proof is rip a CD heavily damaged, without C2 pointers. Let it to re-rip a few of frames, cancel and check the log. If detects missmatches, all OK, because the drive doesn't cache, and reads from CD (which returns different data each), not from cache (which would return the same data).
                              • S0nic
                                • Oct 2012
                                • 32
                                #45
                                i do test again with same cd with 40x and do that 2 times and i finally get same resultat of 6 , so i set like that
