Ripping to Ogg, problems?
  • 19kylegreer96
    • Sep 2012
    Hello,
    When I rip tracks to Ogg Vorbis vbr, db cannot read the details of the written ogg file in windows, it says the bitrate is 0kbps, I would like to know what bitrate the codec chooses for my files and cd's, just wondering why this happens, doesn't happen with any other codec.
    -Kyle
    Re: Ripping to Ogg, problems?
    dBpoweramp Music Converter cannot read the bitrate? you are using a modern release of dBpoweramp (R14)?
    • 19kylegreer96
      • Sep 2012
      Yeah, I'm on 14.2 off the top of my head not sure, and when I view the files audio properties db poweramp doesn't show anything, and it says bitrate: 0kbps :s
        What about the popup information, if you hold he mouse over the file, it shows 0kbps also?
        • 19kylegreer96
          • Sep 2012
          That's how I discovered the problem, it's wired but yeah, I tried viewing the file in properties but to no avail
            Try R14.3 it is out now, uninstall old version, reboot, install new.
