Identifying where the problem is on an insecure rip
  • skypilotpete
    • May 2009
    • 37
    I rip quite a few library audiobook CDs. The sound quality is not nearly as important as it is with music - the main thing is that the ripped files can be understood and no words are missing. A few pops and clicks don't matter. I have set my secure rip settings at a maximum of 10 retrys for individual bad frames and a track abort after 3 minutes, so that ripping a well-used CD does not take forever. My intention is then to check the tracks that end up labelled "insecure" to see how bad they really are. So far, whenever I have done this, I haven't been able to hear any problems at all, except for a few tiny clicks in gaps between words.
    Can anyone tell me if there is any easy way to identify where the bad frames are in the insecure tracks? Sometimes there are just too many to listen to in real time. I have tried opening them in Total Recorder and looking at the sound image in the editing window, to see if anything unusual stands out, but so far this hasn't enabled me to find anything problematic (other than the above mentioned tiny clicks). Perhaps that's because all the errors so far have been minor. Perhaps major problems would indeed leap out at me, but I would appreciate some advice as to whether there is a better way to do this checking.
    Also, is there any rule of thumb that would say how many frames need to be re-ripped before problems become so serious as to result in words not being able to be understood?
    I am running Windows 7 64, dBpoweramp 14.2 Reference
    Re: Identifying where the problem is on an insecure rip
    When an error is encountered most CD Drives interpolate, that is it silences that area, this interpolation can be a few samples long, or half a second long. Such silences are hard to spot...
    • Porcus
      • Feb 2007
      • 792
      If you use secure settings and full logging, then the log file should tell you where the re-reading is done. Example line (with C2):
      Re-rip Frame: 26222 (00:00:47,053) matched 10 / 14 (c2 dropped 17)
      Here you see the position of the re-ripped frame.
      If the track aborts and you re-read in burst mode, on the other hand ...
      • skypilotpete
        • May 2009
        • 37
        Thanks - that's very helpful.
