What to do when a track won't rip
  • Sagona
    • Apr 2012
    • 8
    When ripping a stack of audio CDs to flac, I found one of the tracks on a CD won’t rip (error/insecure).
    I was using Ultra-Secure mode. The first thing I tried was to uncheck and re-rip but it didn't work. So I'm wondering, what's the best way to deal with these glitches, i.e. try what in what order?
    Re: What to do when a track won't rip
    Give the CD a clean, try in a different CD drive if you have, replace CD (in that order).
    • Porcus
      • Feb 2007
      • 792
      If you get errors like frame LBA xxx ripping 26 frames track end LBA yyy, and no audio output, then you might try a burst rip as a last resort. It will have errors, but it might at least get music through, and the error might not be annoying.
      (BTW, you should normally not let dBpoweramp interpolate over frames.)
      • Sagona
        • Apr 2012
        • 8
        Thanks all. Tried everything above (except replace CD; not much point). Burst rip is what it came down to. The track was tolerable to listen to.
