Ability to adjust album art compression rate
  • Ucodia
    • Apr 2012
    • 15
    I realised recently that when you pick a high resolution album art from internet (GD3 for example), and that you scale it down to a lower resolution, the size of the album art file can increase. This typically happens when you save a JPEG file with a higher quality setting than the original file. I imagine that dbPoweramp stores the picture into the ID3 tag using the JPEG format. So I was thinking, would it be possible to choose what compression level we want to use for album arts when the software scale them?
    • 45040
    Re: Ability to adjust album art compression rate
    There is the wish list section of the forum.
