NO ALBUM ART - using r14.2 on iMac running parallels
  • jonnyevo
    • Apr 2011
    • 28
    hi there.
    there seems to be no "internet" album art available when using r14.2 on an iMac running parallels.... there is occasionally album art, but ONLY that of AMG and the other three metadata databases -
    what i mean is that the artwork isn't being found from blogspots / online music shops (etc.) and the like.
    was using it fine on a pc running the same version of CDripper....
    any help appreciated!
    thanks. jonny.:smile2:
  • jonnyevo
    • Apr 2011
    • 28
    Re: NO ALBUM ART - using r14.2 on iMac running parallels
    just tried it on my fully registered version of reference r14.2 on my pc and it seems to get album art from the internet fine.......
    just not on my iMac running parallels.....
    HELP!!!:cry:
      • 46027
      Most likely a firewall blocking access
      • jonnyevo
        • Apr 2011
        • 28
        i don't have any firewalls/antivirus software installed - apart from windows firewall, which didn't solve the problem when i turned it off......
        • jonnyevo
          • Apr 2011
          • 28
          Any other ideas spoon?
          • jonnyevo
            • Apr 2011
            • 28
            OK, so i just installed kaspersky on windows 7, and allowed cd ripper through the firewall, and still no album art apart from AMG and GD3......... HELP!!!!!
            • jonnyevo
              • Apr 2011
              • 28
              ok. so i got rid of the antivirus on my mac, and album art is back!! but when i open the cd ripper main window, without a cd in the drive, the screen constantly - twice or more every second "flashes" or "stutters" as if it is rescanning or something, although it doesn't affect functionality it is a little annoying.... any ideas?
                • 46027
                Sorry I dont have any idea.
