accurate of 50 but track small noise ?
  • Gbeer7
    • Mar 2011
    • 165
    Hi All,
    I ripped a track a while ago, (Ryan Adams - Gold) and on all tracks got a accurate result of 50. When listening to track 8, Nobody Girl, at 9:07 into the track sounds like a very small nosie that drops out on one speaker. Very slight and very quick ! Is this part of the track or something else ? I'm a bit of a worrier !!
    • 46198
    Re: accurate of 50 but track small noise ?
    If other people have the same result, then it is part of the mastering process.
    • Gbeer7
      • Mar 2011
      • 165
      ok, then its part of the track ? Did try listening to it on youtube the track to compare, didn't seem to make the same noise. Although the quality wasn't as good.
        • 46198
        Yes is part of the track.
        It is impossible (even with manufacturing defect) for 50 people to get the same defect.
        • Gbeer7
          • Mar 2011
          • 165
          So i'm pretty safe spoon this is as it should be ? (Sorry, just worry !)
          • Gbeer7
            • Mar 2011
            • 165
            Sorry spoon, wouldn't be a harddrive fault, like a bad sector or something ? Or its part of the track and stop worrying ?
              • 46198
              You could rip it again to a 2nd file, the HDD would notr give the same fault in 2 separate files, also if ripping to FLAC it has an inbuilt CRC which highlights errors (if convert the FLAC to test conversion).
              • Gbeer7
                • Mar 2011
                • 165
                But surely if it got an accurate of 50, i'm pretty safe its ok ? Bit concerned now.
                Does the CRC say if the file has a problem if its been there for a while ? And would the CRC show an error if you got a accurate rip of 50 ?
                  • 46198
                  The built in protection of FLAC is independent of AccurateRip, it basically allows FLAC to self detect if a file has corrupted over time.
                  • Gbeer7
                    • Mar 2011
                    • 165
                    How do i test the file then ? Is it likely do you think there is a problem ? Is it common ?
                      • 46198
                      Take the file, right click >> Convert To and select 'Test conversion', if completes without any error messages the file is not corrupted.
                      • Gbeer7
                        • Mar 2011
                        • 165
                        If it completed without an error then the track is as it should be the "noise" i hear is normal ?
                        • bhoar
                          • Sep 2006
                          • 1173
                          If you listen to the CD on your computer with headphones (play it with media player, vlc, etc.), do you hear the same drop out? How about on a non-computer CD player?
                          Brendan
                          • Gbeer7
                            • Mar 2011
                            • 165
                            I don't have the CD ad the moment as i've lent it out. I'm guessing if this "noise" is on the CD then it correct to have it on the rip and what with an accuarte result of 50 it would indicate that this is normal and nothing to worry about ?
                              • 6189
                              correct. If the problem is on original CD (and this can be the case more often than one would guess), then the problem shows up on a accurate rip. Nothing to worry about.....
