Avoiding overwrites with same track names?
  • Techbadger
    • Mar 2012
    Hello Rippers!
    This problem is popping up now I am ripping remastered CDs with "Bonus and alternative" tracks...
    One of the bonus tracks has the same name as one of the regular tracks so the output Flac file is the same as one of the already ripped track and it overwrites the existing one.
    Is there a setting in dbpoweramp I am missing to automatically put a (2) or something in the file name to prevent overwriting?
    Thanks!
    • 45124
    Re: Avoiding overwrites with same track names?
    For disc 2, right click on the track number (for any of the tracks) and add a track number offset, then make sure your naming has track number in the naming value (the default does).
    • Techbadger
      • Mar 2012
      Thanks, what I have been doing. Any way to make DBPowerAmp do this automatically if it encounters an output file that is going to overwrite an existing file?
        • 45124
        No, you should set the naming so each album is separate, so have an album name in the file name or folder.
        • Porcus
          • Feb 2007
          • 792
          - You can use discnumber as part of your naming scheme. (Wrap it in a test for TOTALDISCS greater than 1.)
          Catch: you need to ensure that discnumber is correct. (If you use batch ripper, then you must trust the metadata provider to provide this. Not always the case.)
          - You can use [cddb_id] as part of your naming scheme. E.g. Artist - Year - Album title - CDDB_ID/(put the tracks here).
          Then overwriting would only take place if these data are all identical. That could by chance happen if a CD single is released in different mixes with the same length, and you don't put e.g. (radio version) or (remix) in the album title.
          - To be damn sure: use [unique] in your naming scheme. That's if you are paranoid. Of course, if you are sure that all folder names have this n-char string at the end, you can write a script (or use e.g. Bulk Rename Utility) afterwards to strip the last n characters (without overwrite).
          • Techbadger
            • Mar 2012
            But that is the problem, the tracks have the same name on the same album. One in the regular track list and another (or two or three) in the "extras" section with the same name. Alternative takes but they still list it with the same name so the last alternative is the last one to overwrite the other ones.
            • Arnold_Layne
              • Nov 2009
              • 38
              Two options: Edit the metadata to include "alternate take 1" or something similar to the track name
              Or, use track numbers in your naming scheme.
              • Techbadger
                • Mar 2012
                That's what I am doing now.
                But when doing mass-ripping (6 drives) it really slows things down. I was hoping there was a way to automate that in DBPowerAmp.
                • Porcus
                  • Feb 2007
                  • 792
                  As I said, use [cddb_id] (may fail on e.g. remasters) or [unique] to the end of your folder name.
                  • Arnold_Layne
                    • Nov 2009
                    • 38
                    Normally when I use smart metadata, songs that are "alternate takes" are listed as such
                    A_L
