Is it possible to get AccurateRip CRC from ripped track?
  • linkRed
    • Mar 2012
    Say, I have downloaded an album in lossless, accurately ripped, allfine.
    But how do I check if these tracks are the files that were ripped? Is there a way I could get their AccurateRip CRC without rewriting the album on a CD and ripping it again myself?
    Re: Is it possible to get AccurateRip CRC from ripped track?
    not sure about dbpa, but I know in foobar2000, load up album files, right click, select Utilities, then verify album with accuraterip.
    • eaglescout1998
      • Apr 2009
      • 203
      Unless your CD buring program has write offset correction, burning the tracks to CD would be a waste of time.
      If you have Foobar, there is a plugin that can scan an entire album (not individual tracks) and verify them with the AccurateRip database.
      • drjenkins
        • Feb 2006
        • 42
        CUETools will verify ripped FLACS against AccurateRip:
