Difference with same track but with same CD Ripper
  • Thg6276
    • Aug 2008
    • 187
    Good day.
    Something's strange with some discs.
    There is a difference : accurate in some conditions, secure warning in other conditon but absolutely with the same CD / same CD Drive / same settings (Secure rip)
    I explain with an example :
    DbPoweramp V 14.2 (up to date)
    Same CD Drive for the two cases : Plextor Premium 2 (IDE)
    A) The Plextor inside an old computer under Windows XP / 32 bits
    LOG FILE
    dBpoweramp Release 14.2 Digital Audio Extraction Log from vendredi 2 mars 2012 09:45
    Drive & Settings
    Ripping with drive 'E: [PLEXTOR - CD-R PREMIUM2 ]', Drive offset: 30, Overread Lead-in/out: Yes
    AccurateRip: Active, Using C2: Yes, Cache: None, FUA Cache Invalidate: Yes
    Encoder: FLAC -compression-level-8 -verify
    DSP Effects / Actions: -dspeffect1="HDCD=" -dspeffect2="Move Destination File on Error= -root={qt}C:\Documents and Settings\Thierry\Mes documents\Ma musique\{qt} -naming={qt}_Error\[artist] - [album] - [track] - [title]{qt}"
    Extraction Log
    Track 2: Ripped LBA 17129 to 33687 (3:40) in 0:10. Filename: C:\Documents and Settings\PropriƩtaire\Mes documents\Ma musique\The Stranglers\All Live And All Of The Night\02 Was It You.flac
    Secure (Warning) [Pass 1, Re-Rip 1 Frames] CRC32: 1743001D AccurateRip CRC: 630B3506 (CRCv2) [DiscID: 021-003ebec8-03b146e1-46123015-2]
    Re-rip Frame: 33687 (00:03:40.773) matched 10 / 11
    1 Tracks Ripped Securely (Warning: sectors had to be re-ripped)
    B) The Plextor connected in USD 2.0 via an External Case (IDE) under Windows 7 / 64 bits
    LOG FILE
    dBpoweramp Release 14.2 Digital Audio Extraction Log from vendredi 2 mars 2012 10:29
    Drive & Settings
    Ripping with drive 'H: [PLEXTOR - CD-R PREMIUM2 ]', Drive offset: 30, Overread Lead-in/out: Yes
    DSP Effects / Actions: -dspeffect1="HDCD=" -dspeffect2="Move Destination File on Error= -root={qt}C:\Users\Thierry\Saved Games\{qt} -naming={qt}_Error\[artist] - [album] - [track] - [title]{qt}"
    Extraction Log
    Track 2: Ripped LBA 17129 to 33687 (3:40) in 0:10. Filename: C:\Users\Thierry\Music\The Stranglers\All Live and All of the Night\02 Was It You.flac
    AccurateRip: Accurate (confidence 2) [Pass 1]
    CRC32: 8BC8E832 AccurateRip CRC: EB06F757 (CRCv2) [DiscID: 021-003ebec8-03b146e1-46123015-2]
    AccurateRip Verified Confidence 2 [CRCv2 eb06f757]
    AccurateRip Verified Confidence 6 [CRCv1 1249379f]
    1 Tracks Ripped Accurately
    Is somebody has an explanation ?
    • 46198
    Re: Difference with same track but with same CD Ripper
    The first drive had a ripping error, the 2nd did not (as verified by accuraterip)
    • Thg6276
      • Aug 2008
      • 187
      Thank you Spoon
      How is it possible with the same cd and same cd drive ?
      I've repeated again this afternoon and it is the same story
      One error with the Plextor inside the computer XP
      Nothing when the Plextor is as an external drive with Windows 7
        • 46198
        I cannot explain it, only report on the results given by the drive.
        • Porcus
          • Feb 2007
          • 792
          This is not what you were asking about, but: as long as you rip to lossless, I would advise against using HDCD detection. The HDCD flag is in the signal, so you could always detect it later. Furthermore, you may end up having different volume adjustments for different tracks on the same CD, even with CDs which are not using any HDCD features and should best be left as they are.
          (And should you encounter one of the very few CDs which use all HDCD features, then in fact, at least one of these is lost when applying the software version. Nobody knows whether it will be captured by [insert name] HDCD-capable DAC either, but so may -- in principle -- be the case.)
