Error with reading very big track on Audio CD
  • Georg
    • Oct 2011
    Ripping a CD which contains one big track throws an exception after 99%: Runtime Error Visual C++ Library / CDGarb.exe / abnormal program termination. The program quits after clicking OK. The CD is working fine on the CD Player. What to do?
  • dbfan
    • Jan 2011
    • 937
    Re: Error with reading very big track on Audio CD
    Try ripping to test conversion as the encoder
    • Georg
      • Oct 2011
      After testing: It's not the encoder but the ripping process. Is it possible to debug the session?
        Not unless we are able to repeat it, you are ripping burst or secure? if secure then you might be running out of memory (as each pass requires half a GB of memory for a single track cd where the track takes up the whole cd).
