Problem with the button Review Metadata
  • Thg6276
    • Aug 2008
    • 187
    dBpoweramp 14.2
    I have problem with the button Review Metadata
    This message appears :
    Metadata was not retrieved from the Internet (most likely from Local HDD cache)
    Press the metadata button to refetch from the Internet
    After have clickED on the mata button at the top it is ok.
    But it is the same thing for each disc
    What's wrong ?
    • 46198
    Re: Problem with the button Review Metadata
    Make sure that perfect meta has a check mark, and that you have dBpoweramp Reference, or an active perfectmeta license (in dbpoweramp configuration).
    • Thg6276
      • Aug 2008
      • 187
      Thanks Spoon
      perfect meta has a check mark : yes
      you have dBpoweramp Reference : yes
      active perfectmeta license (in dbpoweramp configuration) : yes
        • 46198
        Insert a popular CD, Clear the album name and artist name, then select meta drop menu >> retrieve from >> AMG
        did it fill the album name in?
