Cd rip problem- new machine win7
  • gchappel
    • Aug 2011
    I have been using cdripper for years- never a problem.
    New machine- win7x64. All drivers up to date. Newest version of ripper.
    ripper downloaded and installed normally.
    Put a cd in the cd/dvd drive- it recognizes the drive and disk, metatdata comes up for the tracks.
    The first time I inserted a cd, I got the message from accuraterip something along the lines of will calibrate the cd drive.
    I no longer get that message.
    When I try to rip, or play a cd, the ripper program just locks up. I get the endless spinning circle then program not responding.
    Task manager shows the application- not responding. When I use that to end task- nothing happens.
    When I go into processes a shut down the processes associated with ripper, it will, after several minutes, shut the program down.
    It will not, however release the cd/dvd drive, and at that point the drive is no longer listed under device manager.
    Drive works fine with anything else, plays audio disks through jr media center, etc.
    Any ideas? As you can probably tell I am well over my head in what I know about computers here- just want to listen to great tunes.
    Gary
    • 46160
    Re: Cd rip problem- new machine win7
    What is happening is the CD drive is crashing, which it should not do...
    You can try CD Ripper >> Options >> Communication set to 'Windows Built-in'
    • gchappel
      • Aug 2011
      Nope, still no luck??
      Hardware related?
      Sorry, in way over my head
      Gary
      • gchappel
        • Aug 2011
        If it helps any, this is the error message I got
        Thanks again- don't count the music, grabbed a disk of my wifes- I am a jazz guy myself.
        Gary
        Information ripping to FLAC, 'Track 1' to 'P:\music\music flac\aa aug 11\Glee Cast\Glee; The Music, Journey to Regionals\01 Glee Cast - Faithfully.flac'
        Track 1: ERROR Ripping LBA 0 to 20666 (4:35) in 13:21. Filename: P:\music\music flac\aa aug 11\Glee Cast\Glee; The Music, Journey to Regionals\01 Glee Cast - Faithfully.flac
        Unable to read CD, check CD disc (frame LBA 0 ripping 26 frames track end LBA 20666)
        • dbfan
          • Jan 2011
          • 937
          Try disabling your security software, it might be blocking dbpoweramp
