Problem ripping Stevie Nicks track
  • Orangeboot
    • Aug 2011
    I was hoping someone might be able to give me some advice. I recently bought the new Stevie Nicks CD "In Your Dreams", the CD wasn't in Accurate rip so it dis a secure rip, all was fine until the last track, which took over 9 hrs to rip and then produced a 24Kb file (I was ripping to Apple Lossless).
    I'm not sure if this is copy protection or a disc fault - the disk is physically pristine - but I was wondering if anyone else had had the same problems with this.
    Any help appreciated.
    The log file is copied here;
    dBpoweramp Release 14 Digital Audio Extraction Log from Thursday, July 28, 2011 11:25 PM
    Drive & Settings
    Ripping with drive 'D: [MATSHITA - DVD-R UJ-875 ]', Drive offset: 102, Overread Lead-in/out: No
    Ultra:: Vary Drive Speed: No, Min Passes: 3, Max Passes: 6, Finish After Clean Passes: 2
    Encoder: Apple Lossless
    DSP Effects / Actions: -dspeffect1="ReplayGain=-albummode={qt}0{qt}" -dspeffect2="Audio CD - Hidden Track Silence Removal= -dbsilence={qt}-45{qt} -window={qt}4000{qt}"
    Extraction Log
    Track 14: Ripped LBA 293998 to 310350 (3:38) in 9:31:02. Filename: C:\Users\Administrator\Desktop\DB Rips\Stevie Nicks\In Your Dreams\14 Stevie Nicks - Cheaper Than Free.m4a
    Secure [Pass 1 & 2, Ultra 1 to 3]
    CRC32: 5D7D991F AccurateRip CRC: 00000000 (NEW) [DiscID: 014-0022dce3-0179d53a-c1102a0e-14]
    1 Tracks Ripped Securely
    Re: Problem ripping Stevie Nicks track
    I would not let the drive rip for 9 hours, it will do it no good. If you can try with a different DVD drive.
