Problems with PerfectMeta?
  • eaglescout1998
    • Apr 2009
    • 203
    This morning I noticed it was taking a significantly longer time to retrieve track information... and it's only retrieving from GD3 and Freedb. AMG and MusicBrainz are "ghosted" whenever I click on the Review Metadata button.
  • ThirdOne
    Re: Problems with PerfectMeta?
    I've got the same problem! I presently use the trial version on an iMac running Windows XP under BootCamp and Parallels Desktop.
    In both getting the media data will take more time than ripping the whole CD.
    This is an absolutely no go for this program.
    I discovered another one by inserting an new CD. Sometimes it will be detected, sometimes not. The RETRY-Button will mount the CD in one second, afterwords it takes a few minutes to get the meta-data.
    Does anybody know some workaround?
    Harald
    • burnman
      • Jun 2011
      I'm seeing issues with this as of this morning as well.
        • 46198
        Install R14.2 from the beta section
        • eaglescout1998
          • Apr 2009
          • 203
          14.2 is already installed. I think AMG is having some issues. I de-selected it and the speed was back to normal.
            • 46198
            Yes they are at the moment, it does eventually work but is slow.
            • eaglescout1998
              • Apr 2009
              • 203
              AMG seems to be working now. They must have worked the kinks out of their system.
