same CRC, not accurate, 20 days later accurate - ?
  • Oliver
    • May 2011
    • 19
    Hi, I ripped a CD on 1st June and got (for Track1):
    Copy CRC 47108A7A
    Cannot be verified as accurate (confidence 2) [C315538D], AccurateRip returned [543FFFE6]
    I ripped the same CD 20 days later (same settings) and got (for Track1):
    Copy CRC 47108A7A
    Accurately ripped (confidence 2) [C315538D]
    This phenomenon with all other Tracks too.
    How can I understand this?
    HERE THE WHOLE LOGFILES:
    Exact Audio Copy V1.0 beta 1 from 15. November 2010
    EAC extraction logfile from 1. June 2011, 19:57
    The Spotnicks / Millenium Collection CD 2
    Used drive : SONY CD-RW CRX160E Adapter: 0 ID: 1
    Read mode : Secure
    Utilize accurate stream : Yes
    Defeat audio cache : Yes
    Make use of C2 pointers : No
    Read offset correction : 572
    Overread into Lead-In and Lead-Out : No
    Fill up missing offset samples with silence : Yes
    Delete leading and trailing silent blocks : No
    Null samples used in CRC calculations : Yes
    Used interface : Native Win32 interface for Win NT & 2000
    Gap handling : Not detected, thus appended to previous track
    Used output format : Internal WAV Routines
    Sample format : 44.100 Hz; 16 Bit; Stereo
    TOC of the extracted CD
    Track | Start | Length | Start sector | End sector
    1 | 0:00.00 | 3:11.36 | 0 | 14360
    2 | 3:11.36 | 2:04.52 | 14361 | 23712
    3 | 5:16.13 | 2:53.02 | 23713 | 36689
    4 | 8:09.15 | 3:25.10 | 36690 | 52074
    5 | 11:34.25 | 3:51.59 | 52075 | 69458
    6 | 15:26.09 | 3:14.38 | 69459 | 84046
    7 | 18:40.47 | 2:31.45 | 84047 | 95416
    8 | 21:12.17 | 3:12.34 | 95417 | 109850
    9 | 24:24.51 | 3:10.02 | 109851 | 124102
    10 | 27:34.53 | 2:48.55 | 124103 | 136757
    11 | 30:23.33 | 2:33.60 | 136758 | 148292
    12 | 32:57.18 | 4:40.15 | 148293 | 169307
    13 | 37:37.33 | 2:30.59 | 169308 | 180616
    14 | 40:08.17 | 2:50.02 | 180617 | 193368
    15 | 42:58.19 | 2:45.72 | 193369 | 205815
    16 | 45:44.16 | 2:55.15 | 205816 | 218955
    17 | 48:39.31 | 4:27.71 | 218956 | 239051
    Track 1
    Filename F:\- - CDs Berny\The Spotnicks - 1999 - millenium collection (2CD) - CD2\The Spotnicks - 1987 - Millenium Collection CD 2 - 01 - If You Could Read My Mind.wav
    Peak level 99.8 %
    Extraction speed 2.8 X
    Track quality 100.0 %
    Test CRC 47108A7A
    Copy CRC 47108A7A
    Copy OK
    EAC extraction logfile from 21. June 2011, 15:39
    The Spotnicks / Millenium Collection - CD2
    Read mode : Secure
    Track 1
    Filename L:\- - CDs Berny - neu\The Spotnicks - 1999 - millenium collection (2CD) - CD2 - COMPLETE,17,wav (ESMN)\The Spotnicks - 1987 - Millenium Collection - CD2 - 01 - If You Could Read My Mind.wav
    Peak level 99.8 %
    Test CRC 47108A7A
    Copy CRC 47108A7A
    Copy OK
    Re: same CRC, not accurate, 20 days later accurate - ?
    Did track 2 verify on the 1st July?
    • Oliver
      • May 2011
      • 19
      June, sorry
        Did track 2 verify on 1st June?
        • Oliver
          • May 2011
          • 19
          no, Track 2 was the same, and so all the others
          1.June:
          Track 2
          Peak level 99.8 %
          Extraction speed 2.7 X
          Test CRC E43FBA97
          Copy CRC E43FBA97
          Cannot be verified as accurate (confidence 2) [9A25D748], AccurateRip
          returned [9D036CED]
          Copy OK
          21 June:
          Track 2
          Peak level 99.8 %
          Extraction speed 2.6 X
          Test CRC E43FBA97
          Copy CRC E43FBA97
          Accurately ripped (confidence 2) [9A25D748]
          Copy OK
            There is no issue then, previously your pressing was not in AccurateRip, a few weeks later it is in AccurateRip and can verify.
            • Oliver
              • May 2011
              • 19
              What is another pressing?
              A re-release of an Album with changes?
                everytime a pressing plant makes a new batch of CDs, they can be a different "pressing"....not necessarily a new version of an album, just a batch of CDs made at a different time (or even a different plant).
