EAC accurate rip - "no use of null samples for CRC calculations"
  • Oliver
    • May 2011
    • 19
    should this be enabled or disabled in EAC:
    "no use of null samples for CRC calculations" ???????????
    I got a different CRC checksums when I checked or unchecked this option,
    but in both cases an accurate rip result with a confidence of 11.
    So to check or uncheck this option, makes different CRC checksums but has no influence on the verification with the accurate rip database! ???
    Is that correct?
    Re: EAC accurate rip - "no use of null samples for CRC calculations"
    AccurateRip is not effected by this option.
    • Oliver
      • May 2011
      • 19
      OK.
      What if I dont have Internet connection and rip CDs.
      Where can I find the AR Result in the Internet afterwards to compare it, the CRCs?
      Are these CRCs with or without "Null Samples" ?
      So shoul I disable or enable this option to get the same CRC that I will find in the Internet/Database or wherever... ?
        AccruateRip uses its own CRCs, there is no option for Null samples. If you are not connected to the internet AccurateRip cannot verify.
