Some Tracks will Not Rip
  • rogerdn
    • Mar 2011
    • 54
    I have used the ripper for about 50 albums and too often I get some tracks on the same CD that have errors after the title reading '.....Ignore. Aiff: Error failed to create output file...'. Since my Aiff rips are to my Mini (via cat5 cable) I assume the Mini is not getting the file. This latest CD has all tracks showing this error, yesterday I had four this way, rest were ok. OSX 10.6.7.
    Would appreciate help, just learning how to use this app.
    • 46198
    Re: Some Tracks will Not Rip
    Rip locally then manually copy, if the file cannot be created the network share is blocking it.
    • rogerdn
      • Mar 2011
      • 54
      Re Ripping Same Album
      Thks for the help. New question, when I re rip the identical album does it create a duplicate set of files or overwrite/update the originals ?
        • 46198
        Re: Re Ripping Same Album
        Overwrite the originals (if the metadata is the same).
