Issue ripping from DTS CD
  • chileboy
    • 96
    I have one (and only one) DTS 5.1 encoded CD (Steely Dan - Gaucho). It seemingly rips accurately to WAVs (the CD is in AR), and I have the proper codec installed so I can play the files in WMP. The only issue is that the first track has a short (< 1 second), loud static burst at the beginning, and the subsequent tracks all start with a more subdued pop. After that, they all play fine.
    I tried ripping to an MP3 and there are identical glitches at the beginning.
    Any advice is appreciated.
    Re: Issue ripping from DTS CD
    Try disabling ID Tagging for Wave (dbpoweramp configuration >> codecs >> adavanced settings)
    But it sounds like it could be an issue with the dts decode and short tracks
    • chileboy
      • 96
      Didn't resolve the issue.
      Do you mean with the decoder I have installed on my PC, or dbpa component? Because originally I had no decoder installed, I only got white noise, but the static burst was there. I also tried copying one of the MP3s to my iPod, and it exhibited the same behaviour.
      How short do you mean by "short tracks"? They are all about 4 - 7 minutes.
      Thanks Spoon.
        This one.
        • chileboy
          • 96
          This one.
          OK, but again, that doesn't make sense, as originally I HAD no decoder installed, and the static was present - so how could it be originating from a non-existent decoding?
          I also ripped to a .flac and copied it to my iPod (which is running Rockbox), and had the same symptom.
          Or am I missing something? :confused:
            Static noise is the undecoded DTS file, your player needs to be able to decode DTS to get any sound, dBpoweramp does not decode the DTS
            • chileboy
              • 96
              Yes, I understand that, but as I said in my original post, I have a decoder installed now and after the initial 1-second "pop", the files play back flawlessly.
              I'm not saying it's not my decoder, was just asking here for some direction, and to be sure there wasn't something I was overlooking in the ripping process. Since that appears to not be the case, I will tinker with it some more and see if I can figure out whats going on.
              Thanks for the input.
                If AccurateRip verified it, the rip is without error.
                • chileboy
                  • 96
                  You were absolutely right Spoon. I re-ripped to .flac and installed the dts component for foobar2000 and it played back fine in that.
