Problem with ID Tag Processing
  • technik-bastian
    • Apr 2009
    The CD Ripper (Reference R14) is writing the Album Artist in the tag BAND when ripping to mp3. But I want it to store that in the tag ALBUMARTIST.
    I tried to manage that with the ID Tag Processing and used Manipulation>Rule based Manipulation with the following rule:
    IF tagname=BAND
    SET tagname=ALBUMARTIST
    But that doesn't show any effect. I use Multi-CPU force (works fine) and Playlist Writer parallel and the Playlist Writer is not working too.
    Any suggestions?
    Re: Problem with ID Tag Processing
    It is not possible to store as 'AlbumArtist' as there is no such tag in id3v2. Band is the one everyone (iTunes, WMP) use to store Album artist in mp3.
    • technik-bastian
      • Apr 2009
      Ok, but why is the Playlist writer not working either?
      Ok, thank you. Think I got mixed up with the Vorbis comment tags.
      Can anybody tell me, while my Playlist writer is not working?
      I want it to store a m3u-Playlist and store it in the folder where the first title is stored. I use it with the multi-encoder...
        Re: Ok, but why is the Playlist writer not working either?
        Try it without multi encoder until you get it working as should then try in multi-encoder.
        • technik-bastian
          • Apr 2009
          It's working without the multi-encoder - but not with it...
            Possible bug noted
            • Quint
              • Nov 2010
              Bump that bug using Multi-encoder - Playlist writer doesn't generate lists for me either.
              Any way I can generate a playlist *after* I've ripped my collection? I'd rather press on with ripping until a fix is found.
              Love the product.
              • Yahw3y
                • Dec 2010
                I'm having the same problem with the playlists not being created when using multi encoder. Is there a workaround for this issue?
                  Not currently possible.
