Audio CD not recognized
  • jangk
    • Aug 2010
    • 20
    Hello,
    I am ripping a series of Audio CDs to FLAC, and I am encountering a problem, dBpoweramp not recognizing some audio-CDs.
    The CDs are ok, since other programs are able to read and play these CDs, and even retrieve tag information.
    It is not, that the CDs are damaged or so, they play fine on other programs (Winamp, software CD-player, EAC, ...)
    Is there a setting I miss, enabling dBpoweramp to be less critical in recognizing CDs?
    Thank you and best regards
    • 46198
    Re: Audio CD not recognized
    CD Ripper just shows the Insert CD page?
    • jangk
      • Aug 2010
      • 20
      Yes,
      the ripper asks for <Insert Audio CD>
      and pushing on "Retry" doesn't help either.
        • 46198
        R13.4 had a bug with single track CDs, make sure you are using R13.5
        • jangk
          • Aug 2010
          • 20
          So I have now installed R3.15 and everything looks fine.
          The problems were with 1-track-CDs indeed!
          BTW, where can I find the release Nr in dBpoweramp?
          Thank you for your help!
            • 46198
            dBpoweramp Configuration
            • jangk
              • Aug 2010
              • 20
              OK, found it :smile2: :smile2: :smile2:
              Thank you for your perfect service !
              Jean
