Problem Since updating to R13.5
  • Morden
    • Jun 2010
    Hi
    Since updating to R13.5 I appear to have lost functionality.
    I cannot set secure rip settings as when I go to options teh settings are greayed out. and the program only works on a single CPU core when I have a quad and it did multi core rips previously.
    Have I broken it when I upgraded ?
    I did not use auto upgrade and installed manually over top of existing install.
    Any help would be appreciated
    Re: Problem Since updating to R13.5
    You possibly have installed the non-registered version, install the registered version through:
    • Morden
      • Jun 2010
      Thanks for the advice.
      Thats fixed the problem. :smile2:
