c2 - Re-Rip frame setting
  • Moll
    • May 2010
    Great product!
    Configuring the dBpoweramp CD Ripper, I have tried to activate the c2 support. Trying with a painted CD as defined the guidance my computer confirmed my CD drive supports c2, but when ripping I then get errors because it has to rerip a quantity of frames exceeding 100. Now it is clear I can just increase the value, and setting it to 500 it then works fine, but my question is whether it then would be better just to leave out the c2 check?
    I don’t believe the original cd drive in my computer is a good quality so another option is to buy a better one.
    dBpoweramp Release 13.5 Digital Audio Extraction Log from 29. maj 2010 5:34
    Drive & Settings
    Ripping with drive 'E: [HL-DT-ST - DVD-RAM GH15L ]', Drive offset: 667, Overread Lead-in/out: No
    AccurateRip: Active, Using C2: Yes, Cache: 39 KB, FUA Cache Invalidate: No
    Ultra:: Vary Drive Speed: No, Min Passes: 1, Max Passes: 2, Finish After Clean Passes: 1
    Bad Sector Re-rip:: Drive Speed: Max, Maximum Re-reads: 60
    Encoder: FLAC -compression-level-5
    DSP Effects / Actions: -dspeffect1="ReplayGain=-albummode={qt}0{qt}" -dspeffect2="Audio CD - Hidden Track Silence Removal= -dbsilence={qt}-45{qt} -window={qt}4000{qt}"
    Extraction Log
    Track 1: Ripped LBA 0 to 22840 (5:04) in 0:32. Filename: C:\Users\Moll\Music\Billy Joel\Songs in the Attic\Billy Joel - 01 - Miami 2017 (Seen the Lights Go out on Broadway).flac
    Insecure [Pass 1, Ultra 1 to 1, Re-Rip 163 Frames]
    ** Aborted: Have to ReRip 163 Frames, Re-Rip Limit Set to 100 Frames
    Re: c2 - Re-Rip frame setting
    No, the abort option is nothing to do with c2, just there to speed up ripping (as normally if there are 163 bad frames, you are not going to get a secure rip).
    • Moll
      • May 2010
      Okay, thanks.
      Replacing the original HP drive with an new PLEXTOR drive has solved the problem. I have now ripped 20 CD’s without any failures.
      dBpoweramp Release 13.5 Digital Audio Extraction Log from 5. juni 2010 6:13
      Drive & Settings
      Ripping with drive 'E: [PLEXTOR - DVDR PX-880SA ]', Drive offset: 6, Overread Lead-in/out: No
      AccurateRip: Active, Using C2: Yes, Cache: None, FUA Cache Invalidate: No
      Extraction Log
      Track 1: Ripped LBA 0 to 18622 (4:08) in 0:35. Filename: C:\Users\Moll\Music\Bruce Springsteen\The Rising\Bruce Springsteen - 01 - Lonesome Day.flac
      AccurateRip: Accurate (confidence 4) [Pass 1]
      CRC32: 6F4DFA60 AccurateRip CRC: 208C3C18 [DiscID: 015-0026a157-01b9f7fb-ce11190f-1]
