secure rip settings greyed out
  • Sossity
    • Jan 2010
    • 162
    I have not used dbpoweramp for about 3 weeks, & I ripped a CD in it today, I wanted to go in & adjust the secure rip settings, but they are greyed out, I cannot click on it & choose the min & max passes. This has never happened before.
    • 46198
    Re: secure rip settings greyed out
    Check that in dBpoweramp Configuration it says:
    Registration Status: dBpoweramp Reference
    as this is required for the ultra passes.
    • Sossity
      • Jan 2010
      • 162
      I dont see anywhere for registration status, I dont know if mine has this, there is the options button at the top of the screen, which I click that opens up the CD ripper options, but no registration status. I clicked on the ID tag meta button as well, nothing there. Where exactly do I find this?
      I also notice that the profile options are greyed out as well. Why have I lost some functionality? I paid for this program in January, it is a little annoying, do I lose functions in the program if I am not using it constantly?
        • 46198
        Start >> Programs >> dBpoweramp Music Converter >> Configuration
        You would only loose functionality if you have not installed the registered version, or the Power Pack was purchased (and reference features would disable after the trial).
        • Sossity
          • Jan 2010
          • 162
          I got to this, & under the versions tab, it says dBpower music converter; registered reference release 13.3
            • 46198
            R13.4 is out, so uninstall all dbpoweramp, and reinstall (no settings will be lost):
            • Sossity
              • Jan 2010
              • 162
              http://www.dbpoweramp.com/registration/
              thanks for the link, this fixed it.
