Problem with Multi-Encoder and Multi-CD
  • balieu
    • Mar 2010
    Hi
    When I place a FLAC encoder inside the Multi Encoder and put the following in Dynamic:
    [album][IFMULTI] - Disc [disc][]\[track] - [title]
    Then the [IFMULTI] part is ignored, which isn't the case if the same settings are applied to a normal FLAC encoder (not part of a Multi Encoder).
    Also I have added the new playlist Writer DSP to the FLAC (inside the Multi Encoder), and it doesn't seem to run at all! And by the way also ignores [IFMULTI] (even if run outside Multi Encoder).
    The above wouldn't be a problem if the 'Multi-CD Add Disc to Album' Meta settings worked, but it is also ignored (which is why I tried with [IFMULTI] in the first place).
    I am using 13.4 and also tried in 14 beta, and running Windows 7 64bit.
    Michael
    • 46167
    Re: Problem with Multi-Encoder and Multi-CD
    Will mark as a possible bug.
    • balieu
      • Mar 2010
      Hi Spoon
      I have a precision to make about my earlier bug report.
      The 'Multi-CD Add Disc to Album' Meta settings work fine, also for Multi-Encoder.
      The problem is that some old multi disc CDs aren't recognized as such.
      They must lack some marker in their meta-data.
      This makes my problem with the Multi-Encoder much easier, since I can remove its dependence upon IFMULTI, which still isn't recognised inside it.
      Michael
        • 46167
        Before ripping you must check the disc number is x/y where x is the disc number and importantly y is the disc total.
