Ripping problem
  • schmitty
    • Mar 2010
    • 47
    Ripping problem
    Hello,
    First of all, wonderful program. I am having a prolem with ripping, the ripped files, whether they are WAVs or MP3s seem to slowly fade out near the end of the track when the track doesn't actually fade out and the ones that do fade out don't fade out completely, they seem to cut part way through the fade even though listening to the CD they are complete tracks. It also took me a lot of trial and error to get the tracks which do not fade out to rip completely, ie. The Romantics - What I Like About You, this is also one of the tracks which I referred to above with the fade out problem.
    Any help would be appreciated.
    Schmitty
    Re: Ripping problem
    In CD Ripper open the DSP Tab and make sure you have no effects running, such as fade.
    • schmitty
      • Mar 2010
      • 47
      Re: Ripping problem
      there are no dsp effects
      Schmitty
        Re: Ripping problem
        Check your audio player is not doing the fade, because CD Ripper will not change the audio data if ripping to lossless.
