CD Ripper doesn't work
  • docles
    • Dec 2009
    • 12
    I am experiencing problems with CD Ripper.
    It seems to start with the GUI appearing, but as soon as I touch a buttom, then everything is blank. I then just need to kill the application.
    I did remove/restart and reinstalled the registered version. But still it does not work.
    Thanks for your support. Now the soft is useless.
    Docles
    • 46198
    Re: CD Ripper doesn't work
    How long did it work for? and what has recently changed on the system?
    • docles
      • Dec 2009
      • 12
      Hello,
      Actually, the soft has been working with regular errors since 1 year.
      Now since 2/3 weeks the soft is completely blocked.
      I did not change so much things on my computer unless regular system patch coming from Windows and other stuffs like that.
      Docles
        • 46198
        Clear it off totally:
        http://forum.dbpoweramp.com/showthread.php?t=13285
        Then reinstall and try ripping on default settings.
