@ Spoon: Errors in AccurateRipID calculations in beta versions?
  • Porcus
    • Feb 2007
    • 792
    I am playing around with CUETools now, and it seems it sometimes comes up with a distinctly different AccurateRip-ID than what is written to my tags. (And yes, these CDs are audio-only without HTOA.)
    Before I submit bug reports to the developer:
    * I know that at least one R13 beta had erroneous calculations for single track CDs, but I do not know of other errors. Can you please clarify whether there were others?
    * Did any R13 at any stage produce files which would lead to a different TOC than from the CD?
    * Have any R13 beta submissions been purged as result of this?
    • 45042
    Re: @ Spoon: Errors in AccurateRipID calculations in beta versions?
    1) Not effecting AccurateRip
    2) No
    3) Not required.
    What you are seeing is if you have an enhanced audio CD, CUETools does not know the length of the data section, so it cannot calculate the Disc ID for that disc.
    • Porcus
      • Feb 2007
      • 792
      To be precise: Not affecting the AccurateRipID tag? (Except for the obvious error on single-track CDs?) I am not asking about the accuracy count tag.
      I have taken care to consider only CDs which do not have any apparent data files, but my only way of knowing is to check that the only "files" are Track01.cda, Track02.cda, and so on. Is this test sufficient? Could I then be safe that they are not EnhancedCDs?
        • 45042
        >on single-track CDs
        This was an error of the track listing, way before AccurateRip, in R13.3 it would not list single track CDs, let alone rip them.
        Also if the disc does not start at frame 150 (2 seconds in) then CueTools would not generate the correct disc ID.
        • Porcus
          • Feb 2007
          • 792
          Ah. And there is no way to tell, I suppose. Thanks for the clarification.
          Wishlist item here: http://forum.dbpoweramp.com/showthre...oper*post96859
