Difference between "unrecoverable" and "insecure"?
  • pjc2
    • Nov 2009
    • 62
    I turned on aborting after 1 unrecoverable frame, and now I'm getting some puzzling results:
    In one instance, it produced an accurate rip after re-ripping 4 frames, the third of which said:
    Re-rip Frame: xxxxxx (00:yy:zz.abc). Insecure (c2 dropped 25) [c2 best match]
    But the manual says that the "After Unrecoverable Frames...aborts ripping if the track is insecure."
    On a few different discs, I had tracks abort after the first attempted rerip with the following message:
    ** Reached Maximum 1 Unrecoverable Frames For This Track
    Why the difference? Is this because it was the first re-rip (rather than the third) that was insecure?
    Or does the C2-best-match mean that it's considered "recoverable"? (I think when "c2 best match" doesn't appear, it means that C2 dropped all 34 attempted reads. Conversely, I think the "c2 best match" in the first example above indicates that 9 of the reads weren't dropped by C2 -- and were presumably identical.)
  • pjc2
    • Nov 2009
    • 62
    Re: Difference between "unrecoverable" and "insecure"?
    Since I didn't get a response, I fiddled with the settings, and I think I've found the answer:
    This is indeed considered recoverable, since out of the 34 attempted rereads, 9 weren't dropped by C2, and most (all?) of those matched. So while it's not "secure" since it doesn't meet the 10-matched threshold, it's still recoverable.
    By increasing the maximum number of unrecoverable frames to 2, I was able to see what dBpoweramp considers "unrecoverable":
    ** Reached Maximum 2 Unrecoverable Frames For This Track
    Re-rip Frame: xxxxxx (00:yy:zz.abc). Insecure (c2 dropped 34)
    In this case, all 34 read attempts were thrown out by C2 error detection, so there wasn't any read that was considered valid. Hence the frame is considered unrecoverable.
      • 46198
      Correct, this is where the ripper would trust the c2 pointers, it could be wrong though, but unlikely that a consistent error would repeat 9 times and have c2 verification also.
