Help, "clicking noise" between tracks (.wav)
  • ducnalf
    • Jan 2010
    Hello, Yes I am new here and asking for help.
    When playing the .wav files with the WD Media player via S/PDIF optic cable to the Lexicon (MC80), I get between the tracks like a "fine clicking noise". (Pink Floyd - The Wall cd1+2 as well as others ... ??)
    I used the fully set-up dbPoweramp (Windows 7) to rip the CD with 48K / 24 bit and had no errors.
    Anybody any ideas ... Help very appreciated.:komisch9:
    Re: Help, "clicking noise" between tracks (.wav)
    It might be the ID Tags in the wave file which your WD media player cannot handle, remove the ID Tags from the wave file.
    • ducnalf
      • Jan 2010
      First, thankyou for your effort.
      I tried first at 44.1/16 --> the same.
      I removed all meta data --> the same.
      I unpluged the toslink from the media player to the Lexicon and pluged in the analog(red+white)cable-->the same.
      I upgraded the firmware to the latest version on the WD Media player --> the same.
      I played the files/tracks with the Windows media player from the same harddisk --> and a smooth transition from tarck one to track 2.
      My next step will be trying an other/different Multi Media Player ... ?? like a Magig Pixel MD200 Mediabox ??
      (http://www.pixelmagicsystems.com/sup...es/hd_mediabox...)
      Or is there anything more promising out there?
      Have a nice weekend ...
      WD hard disk --> Multimedia Player--(audio via toslink)-->Lexicon MC8-->7 channel Rotel Amps-->7xB&W+sub
      --(Video via HDMI)-->42" LCD Sony
      It is a pleasure to listen to! (and i can`t hear any jitter ...)
      :komisch12
