Plextor Premium 2 Offset Configuration
  • mat1024
    • Nov 2009
    Hi Everyone,
    Accuraterip is trying to configure the offset of a Plextor Premium 2 drive.
    It displays:
    Accuraterip needs to verify the offset generated, for this it needs 3 Key Discs that give the same offset, please insert another 'Key Disc'. [ Calculated offset value: +128 samples, +512 bytes ]
    How can I find, or create three key discs for this purpose?
    Many thanks,
  • Thg6276
    • Aug 2008
    • 187
    Re: Plextor Premium 2 Offset Configuration
    You just insert in your plextor drive one of this cd
    and normally all is ok after
    • mat1024
      • Nov 2009
      Thg6276,
      Thank you for your reply.
      Accuraterip displays it is properly configured.
      Another question: after successful detection of C2 error pointers, and considering that the drive is external, shall I tick the
      8KB Transfers (C2 Pointers over USB/Firewire)
      option?
      Many thanks,
      • Thg6276
        • Aug 2008
        • 187
        See this
        • mat1024
          • Nov 2009
          Thg6276,
          Thank you for your help.
