Problems with capitalization
  • ecoutez
    • Jun 2008
    I have been using the trial version of CD Ripper and will likely register for the full version. However, I have a problem with the capitalization on the composer tags. It is set up to "Lowercase Except First Letter". This works fine for most tags but if there is more than one composer then it will produce the following:
    John Lennon;paul McCartney
    Is there anyway to set it up so that the "paul" would real "Paul"?
    Many thanks in advance,
    Ecoutez
  • ecoutez
    • Jun 2008
    Re: Problems with capitalization
    Bump in case anyone can help, otherwise will let it go. Thanks again!
      Seems like a bug, I will mark it down.
