Problem with ripping CDs - all errors
  • jjhall5150
    • Sep 2009
    Hello.
    I have just started using dbpoweramp to rip my CD collection. I have everything setup correctly based on the setup guide.
    Everything has been working fine, but suddenly every CD I rip gives me ALL ERRORS on every track.
    I have uninstalled and re-installed the program twice, however my original settings still appear when trying the fresh downloaded version.
    Can someone please tell me how to fix this problem???
    Uninstall and re-install is not working
    Jim Hall
    jjhall@nycap.rr.com
  • EliC
    • 1175
    Re: Problem with ripping CDs - all errors
    can you post the log?
      Try the reset utility here: http://forum.dbpoweramp.com/showthread.php?t=13285
      • jjhall5150
        • Sep 2009
        Here is the error log.
        I am using a Plextor PX-Q840U
        Error ripping to mp3 (Lame), 'Track 1' to 'F:\Mp3 Library 320kbs\db test\Pat Benatar - Seven the Hard Way\Pat Benatar - Sex As a Weapon.mp3'
        Error unable to open File 'F:\Mp3 Library 320kbs\db test\Pat Benatar - Seven the Hard Way\Pat Benatar - Sex As a Weapon.mp3' for writing. [clEncoder::BeginConversion]
        Error ripping to mp3 (Lame), 'Track 2' to 'F:\Mp3 Library 320kbs\db test\Pat Benatar - Seven the Hard Way\Pat Benatar - Le Bel Age.mp3'
        Error unable to open File 'F:\Mp3 Library 320kbs\db test\Pat Benatar - Seven the Hard Way\Pat Benatar - Le Bel Age.mp3' for writing. [clEncoder::BeginConversion]
        Error ripping to mp3 (Lame), 'Track 3' to 'F:\Mp3 Library 320kbs\db test\Pat Benatar - Seven the Hard Way\Pat Benatar - Walking in the Underground.mp3'
        Error unable to open File 'F:\Mp3 Library 320kbs\db test\Pat Benatar - Seven the Hard Way\Pat Benatar - Walking in the Underground.mp3' for writing. [clEncoder::BeginConversion]
        Error ripping to mp3 (Lame), 'Track 4' to 'F:\Mp3 Library 320kbs\db test\Pat Benatar - Seven the Hard Way\Pat Benatar - Big Life.mp3'
        Error unable to open File 'F:\Mp3 Library 320kbs\db test\Pat Benatar - Seven the Hard Way\Pat Benatar - Big Life.mp3' for writing. [clEncoder::BeginConversion]
        Error ripping to mp3 (Lame), 'Track 5' to 'F:\Mp3 Library 320kbs\db test\Pat Benatar - Seven the Hard Way\Pat Benatar - Red Vision.mp3'
        Error unable to open File 'F:\Mp3 Library 320kbs\db test\Pat Benatar - Seven the Hard Way\Pat Benatar - Red Vision.mp3' for writing. [clEncoder::BeginConversion]
        Error ripping to mp3 (Lame), 'Track 6' to 'F:\Mp3 Library 320kbs\db test\Pat Benatar - Seven the Hard Way\Pat Benatar - 7 Rooms of Gloom.mp3'
        Error unable to open File 'F:\Mp3 Library 320kbs\db test\Pat Benatar - Seven the Hard Way\Pat Benatar - 7 Rooms of Gloom.mp3' for writing. [clEncoder::BeginConversion]
        Error ripping to mp3 (Lame), 'Track 7' to 'F:\Mp3 Library 320kbs\db test\Pat Benatar - Seven the Hard Way\Pat Benatar - Run Between the Raindrops.mp3'
        Error unable to open File 'F:\Mp3 Library 320kbs\db test\Pat Benatar - Seven the Hard Way\Pat Benatar - Run Between the Raindrops.mp3' for writing. [clEncoder::BeginConversion]
        Error ripping to mp3 (Lame), 'Track 8' to 'F:\Mp3 Library 320kbs\db test\Pat Benatar - Seven the Hard Way\Pat Benatar - Invincible (theme from 'The Legend of Billie Jean').mp3'
        Error unable to open File 'F:\Mp3 Library 320kbs\db test\Pat Benatar - Seven the Hard Way\Pat Benatar - Invincible (theme from 'The Legend of Billie Jean').mp3' for writing. [clEncoder::BeginConversion]
        Error ripping to mp3 (Lame), 'Track 9' to 'F:\Mp3 Library 320kbs\db test\Pat Benatar - Seven the Hard Way\Pat Benatar - The Art of Letting Go.mp3'
        Error unable to open File 'F:\Mp3 Library 320kbs\db test\Pat Benatar - Seven the Hard Way\Pat Benatar - The Art of Letting Go.mp3' for writing. [clEncoder::BeginConversion]
          What is your F: drive? An external drive, a network drive, or what? Have you tried to rip to a local drive, such as C: for testing?
          • EliC
            • 1175
            or is the drive full?
            • jjhall5150
              • Sep 2009
              I was able to fix the problem.
              What seems to have happened is that my computer somehow swapped the letters on my external drive and my CD/DVD writer.
              The same problem continued to happen after changing the location of the write directory.
              I had to uninstall with a totally clean start as listed to fix the problem.
              Seems to be working fine now. Not sure what happened, but I am guessing its more a Vista issue than a software issue
