TEAC DV-W5000E problems with Accuraterip
  • Clegane
    • Aug 2009
    • 20
    I've tried a couple of key discs and every time I get the message:
    The Key Disc cannot be used for offset detection (it does not match the one stored in AccurateRips database), please try a different Key Disc.
    I have used key discs with several different drives, my discs are not the problem.
    As for technical details:
    dbPoweramp:
    Drive read cache: 94 kB
    FUA detected
    cachex:
    Buffer size: 2000 kB, read cache is enabled
    Supported read commands: BEh
    Testing cache line size:
    124 kB / 54 sectors
    124 kB / 54 sectors
    124 kB / 54 sectors
    124 kB / 54 sectors
    124 kB / 54 sectors
    124 kB / 54 sectors
    124 kB / 54 sectors
    124 kB / 54 sectors
    124 kB / 54 sectors
    124 kB / 54 sectors
    Those are far better results than I have obtained with other modern disc drives.
    Re: TEAC DV-W5000E problems with Accuraterip
    If the drive is not in the AccurateRip database, then you need 3 matching offsets, from discs without multiple pressings.
    • Clegane
      • Aug 2009
      • 20
      What message will I receive when I have inserted a key disc that is acceptable to Accuraterip? I've tried 3 key discs now.
      It's an impossibly narrow list to avoid CDs with multiple pressings. Everything seams to get remastered eventually. Most popular CDs are issued in Japan with a bonus track. In the 80's only Atlantic Records would issue CDs with the same mastering in every country. The dbPoweramp engineers may be computer enthusiasts (although I've yet to see an explanation of how they managed to leave the only DVD burner currently in production that's worth a damn out of the Accuraterip database), but they clearly know nothing about music collecting.
      It's lousy that this quirk of Accuraterip prevents me from using it with this disc drive. Why not at least add a manual override command where I can say "Get the offset from this one CD right now because I told you so". If that makes me ineligible for new CD submissions, fine.
      • Clegane
        • Aug 2009
        • 20
        If you are going to restrict the eligible key discs for a drive that is not yet in the database, then you should provide a list of such restricted discs.
        • bhoar
          • Sep 2006
          • 1173
          The reason is that there are drives out there without a reliable offset position. Pull out 30 CDs and manually feed them until it finds three matches.
          -brendan
          • Clegane
            • Aug 2009
            • 20
            I found the matches I needed. But
            2 of my old standbys, Back in Black and 5150 were rejected
            1) the first CD I got a match with was Ritchie Blackmore's Rainbow - Stranger in Us All. I am stunned this obscurity is a key CD. The version I used is a Japanese issue with an extra song at the end.
            2) the 2nd CD I got a match with was Whitesnake - Slide It In. A CD whose original Japanese and European issue have an alternate mix to the original American one.
            3) The 3rd CD was KISS Gold, a 40 song compilation. I will agree, that information will be exactly the same across all time and space. If you remaster a compilation, you have a new compilation.
            • Tigerman
              • Mar 2005
              • 157
              How more popular a cd is, how more likely it has multiple pressings.
              "Happiness is nothing more than good health and a bad memory."
              Albert Schweitzer (1875 - 1965)
