AMG/Musicbrainz metadata retrieval problem
  • awnm
    • Aug 2006
    • 27
    We are using CD Ripper, and having problems retrieving metadata from AMG & Musicbrainz (freedb & GD3 work ok). Basically no metadata is retrieved from those sources, the CD Ripper screen goes blank white for about one minute, then returns with just the freedb/GD3 data. I've attached debug output below, but there is no indication of error in there.
    From the fact that only AMG & Musicbrainz fail, and reading through some other threads, it would appear this is a problem with our configuration. However we need some assistance in tracking down where the problem lies so we can reconfigure.
    The PC environment is: XP SP2, McAfee VirusScan Enterprise 8.5i, behind a corporate firewall & proxy.
    Any assistance would be appreciated.
    Code:
    Using SCSI PassThrough  [clCDDA::SetCommunication]
    ->->  [frmMain::RefreshTrackListing]
      Quitting Meta Thread: Quit
      ->->  [clCDDA::ReturnDriveList]
        Got drive C:\  ** not CD Rom, type: 3  [cddaSCSIPassTru::FillDriveList]
        Got drive D:\  ** not CD Rom, type: 3  [cddaSCSIPassTru::FillDriveList]
        Got drive F:\  ** not CD Rom, type: 4  [cddaSCSIPassTru::FillDriveList]
        Got drive G:\  ** not CD Rom, type: 4  [cddaSCSIPassTru::FillDriveList]
        Got drive L:\  ** not CD Rom, type: 4  [cddaSCSIPassTru::FillDriveList]
        Got drive P:\  ** not CD Rom, type: 4  [cddaSCSIPassTru::FillDriveList]
        Got drive S:\  ** not CD Rom, type: 4  [cddaSCSIPassTru::FillDriveList]
        Got drive Y:\  CD ROM  [cddaSCSIPassTru::FillDriveList]
      <-<-  [clCDDA::ReturnDriveList]
      ->->  [clCDDA::ReadTOC]
        LBA FirstIndex: 1 last Index: 16
          Type: Audio Track 1  LBA Address: 0  Length: 00:03:08.426
          Type: Audio Track 2  LBA Address: 14132  Length: 00:03:42.507
          Type: Audio Track 3  LBA Address: 30820  Length: 00:03:21.760
          Type: Audio Track 4  LBA Address: 45952  Length: 00:03:58.467
          Type: Audio Track 5  LBA Address: 63837  Length: 00:02:40.400
          Type: Audio Track 6  LBA Address: 75867  Length: 00:04:15.066
          Type: Audio Track 7  LBA Address: 94997  Length: 00:03:34.174
          Type: Audio Track 8  LBA Address: 111060  Length: 00:03:28.826
          Type: Audio Track 9  LBA Address: 126722  Length: 00:04:40.307
          Type: Audio Track 10  LBA Address: 147745  Length: 00:04:18.133
          Type: Audio Track 11  LBA Address: 167105  Length: 00:03:19.334
          Type: Audio Track 12  LBA Address: 182055  Length: 00:02:53.666
          Type: Audio Track 13  LBA Address: 195080  Length: 00:03:27.800
          Type: Audio Track 14  LBA Address: 210665  Length: 00:02:48.600
          Type: Audio Track 15  LBA Address: 223310  Length: 00:06:19.134
          Type: Audio Track 16  LBA Address: 251745  Length: 00:03:30.360
          Type: Lead Out  LBA Address: 267522
        MSF FirstIndex: 1 last Index: 16
          Type: Audio Track 1  MSF: 0/2/0  Length: 00:03:08.426
          Type: Audio Track 2  MSF: 3/10/32  Length: 00:03:42.507
          Type: Audio Track 3  MSF: 6/52/70  Length: 00:03:21.760
          Type: Audio Track 4  MSF: 10/14/52  Length: 00:03:58.467
          Type: Audio Track 5  MSF: 14/13/12  Length: 00:02:40.400
          Type: Audio Track 6  MSF: 16/53/42  Length: 00:04:15.066
          Type: Audio Track 7  MSF: 21/8/47  Length: 00:03:34.174
          Type: Audio Track 8  MSF: 24/42/60  Length: 00:03:28.826
          Type: Audio Track 9  MSF: 28/11/47  Length: 00:04:40.307
          Type: Audio Track 10  MSF: 32/51/70  Length: 00:04:18.133
          Type: Audio Track 11  MSF: 37/10/5  Length: 00:03:19.334
          Type: Audio Track 12  MSF: 40/29/30  Length: 00:02:53.666
          Type: Audio Track 13  MSF: 43/23/5  Length: 00:03:27.800
          Type: Audio Track 14  MSF: 46/50/65  Length: 00:02:48.600
          Type: Audio Track 15  MSF: 49/39/35  Length: 00:06:19.134
          Type: Audio Track 16  MSF: 55/58/45  Length: 00:03:30.360
          Type: Lead Out  MSF: 59/28/72
      <-<-  [clCDDA::ReadTOC]
      ->->  [frmMain::GetMeta]
        ->->  [clMetaData::GetMetaData]
          ->->  [clMetadBCache::GetMetaData]
          <-<-  [clMetadBCache::GetMetaData]
        <-<-  [clMetaData::GetMetaData]
        ->->  [frmMain::MetaDataGot]
          Meta Final Pass
        <-<-  [frmMain::MetaDataGot]
      <-<-  [frmMain::GetMeta]
    <-<-  [frmMain::RefreshTrackListing]
        ->->  [clMetaData::GetIntelMetaData]
          ->->  [clMetaData::DoMetaDataRules]
          <-<-  [clMetaData::DoMetaDataRules]
        <-<-  [clMetaData::GetIntelMetaData]
        Meta Final Pass
    ->->  [clMetaData::SaveMetaData]
      ->->  [clMetadBCache::SaveMetaData]
      <-<-  [clMetadBCache::SaveMetaData]
    <-<-  [clMetaData::SaveMetaData]
    Re: AMG/Musicbrainz metadata retrieval problem
    If you can try from not behind the corporate firewall & proxy, it would highlight it as the problem.
    • awnm
      • Aug 2006
      • 27
      It works fine when not behind the firewall/proxy, so that would seem to be the problem. (The AV software was still enabled when it worked on the non corporate connection, so that's not it)
      What we need is some info on what ports or protocols etc are in use so we can unblock or trace. From other threads, I understand that it all uses port 80 (which is open and works for freedb/GD3).
      So any info you can provide on what we should be looking for to work out why why AMG/Musicbrainz are failing would be much appreciated.
        The data needs to pass untouched, even adding an extra header to the HTTP (as a proxy might) will stop amg from working...
        • awnm
          • Aug 2006
          • 27
          Right, so is there any easy way to debug/dump what is coming out of CD Ripper so we can compare what is coming out of the proxy?
          Or can you provide a generic sample of a standard request that is sent to AMG & Musicbrainz?
            You could use Wireshark out side the firewall, to capture the network packets, then use it within the firewall with the same disc.
