Best way to rip XRCDs Accuraterip or Secure
  • mariudan
    • Jul 2009
    Hi All,
    I have a lot of XRCD discs to rip and looking for the best audio quality.
    Here is how I want to approach this:
    FLAC format
    Secure ripping (not accuraterip because it is comparing the information with different versions of the disc wich are not XRCD)
    4x speed
    Millennium CD-Carbon Mat
    CD-Rom drive is Plextor Premium Plexwriter
    If anybody can help with this situation I would really appreciate it. I could not find anything on this forum about XRCD discs.
    Great forum.
    Mariudan
  • EliC
    • 1175
    Re: Best way to rip XRCDs Accuraterip or Secure
    accurate rip is fine as it will only compare with other matching CDs (you will only be comparing with other XRCDs)
    Do you have any XRCD and standard CDs that are the same album. I am curious to know if the TOCs are the same after different masterings.
    • mariudan
      • Jul 2009
      these two CDs have the same TOC and I think dbpoweramp does not differentiate between the two releases.
      http://www.amazon.com/Famous-Blue-Ra.../dp/B001APH0UC Cisco GCD8011-2 Gold Edition
      http://www.amazon.com/Famous-Blue-Ra.../dp/B000OPO6WY
      Mariudan
      • Porcus
        • Feb 2007
        • 792
        XRCDs are just ordinary CDs. The "XRCD" thing is just the mastering process, like Sony's SBM. http://en.wikipedia.org/wiki/Extende...n_Compact_Disc
        Turn AccurateRip on, somebody might have ripped it before you.
        • EliC
          • 1175
          yes, but a cd with a different mastering will not match AR for discs with non-XRCD mastering. As I said above, accurate rip is fine as it will only compare with other matching CDs (you will only be comparing with other XRCDs).
