Help to setting up for dBpoweramp. Thanks!!!
  • t10
    • Jul 2009
    I am new to dBpoweramp. Would you all advise how to setup the dBpoweramp in order to have the best quality for ripping CDs to FLAC format in terms of time. I learnt that it needs 15 to 20 mins to rip a CD. However, I only used about less than 8 mins for the task.
    I wonder if my setup is not probably done. I set the compression level to 8.
    Thanks in advance!!!
    David
    Re: Help to setting up for dBpoweramp. Thanks!!!
    See:
    • t10
      • Jul 2009
      Hi Spoon,
      Thanks for your advice.
      However, I ticked "Mark Track as Error if Insecure", it appeared "insecure" after ripping some CDs, like "Kenny G Live", etc. If I don't want this option, it appeared "Accurate" as compared with other rippers.
      As such, I am confused if I should ticked this option to get the best ripping.
      David
        You do not have to check it if you do not want.
