Accuratrip not in database (please help)
  • damoresh
    • Jul 2009
    • 21
    I use dBpoweramp Music Converter Reference 13.2 whenever i insert indian Bollywood cds the connecting accuraterip starts and it goes after ripping i get Accuraterip not in database why is it so i tried it with many cds whats the problem is it that only if that cd was in its database then only it will verify if it is not what can i do how can i check whether it is correctly ripped or not please help me
    • 46166
    Re: Accuratrip not in database (please help)
    If it is not in the database you have to rely on the CD Drive doing secure ripping.
    • Vexzilla
      • Nov 2004
      • 27
      I think I may be having the same problem.
      When only using 1 cpu on my pc I get accuraterip crc's at the end of ripping.
      If I use both my cpu's all tracks ripped report 'Not in AccurateRip.'
      Is this a bug or am I missing a setting somewhere?
      ~It's all dick.~
      John Lennon
        • 46166
        The CRCs change? between the two?
        • Vexzilla
          • Nov 2004
          • 27
          was running on win 7....ran cdgrab in xp sp2 compatibility mode and ran as administrator for all users....now working fine......sorry to alarm
          ~It's all dick.~
          John Lennon
            • 46166
            If you run it in normal mode it does not work for you on Windows 7? there is a chance that the retrieval of the accuaraterip result failed on that one instance.
            • Vexzilla
              • Nov 2004
              • 27
              I don't think so. Had same problem with dbpoweramp reference trial on win xp also.
              ~It's all dick.~
              John Lennon
                • 46166
                On XP there is no compatibility option.
