Ripper speed
  • fugno
    • Apr 2009
    Ripper speed
    I ripped a CD to wave and the high frequances are distorted.I thought maybe the CD is bad so I ripped it with EAC and came out perfect.Is there a way to slow down the ripper speed?EAC rips a noticeably slower speed and I figured that had something to do with it.
    Keep up the good work,Blake
    • 46198
    Re: Ripper speed
    Is the CD in accuraterip? does accuraterip verify it?
    • fugno
      • Apr 2009
      Re: Ripper speed
      Yes and yes.I ripped a couple of HDCD's and they sound great.
        • 46198
        Re: Ripper speed
        If AccurateRip verifies a Rip then it is 100% bit for bit correct, nothing in the higer frequencies should be wrong (unless the compression codec is setup wrong).
