Preventing Secure Rip Aborts
  • pangit
    • Mar 2009
    • 17
    #31
    Re: Preventing Secure Rip Aborts
    Thanks for the response Spoon.
    I have never had the abort setting on, but I did try turning off all the DSP effects, which made no difference whatsoever. Here's the log from another example I tried four times tonight, which consistently resulted in an abort and an 18Kb file:
    ATTEMPT #1
    dBpoweramp Release 13.2 Digital Audio Extraction Log from Monday, May 11, 2009 8:50 PM
    Drive & Settings
    Ripping with drive 'D: [HL-DT-ST - DVDRAM GH22LS40 ]', Drive offset: 667, Overread Lead-in/out: No
    AccurateRip: Active, Using C2: Yes, Cache: None, FUA Cache Invalidate: Yes
    Ultra:: Vary Drive Speed: Yes, Min Passes: 1, Max Passes: 4, Finish After Clean Passes: 2
    Bad Sector Re-rip:: Drive Speed: Max, Maximum Re-reads: 100
    Encoder: FLAC -compression-level-7 -verify
    DSP Effects / Actions: -dspeffect1="Audio CD - Hidden Track Silence Removal= -digsilence -dbsilence={qt}-45{qt} -window={qt}4000{qt}" -dspeffect2="Audio CD - Silence Track Deletion= -digsilence -dbsilence={qt}-45{qt}" -dspeffect3="HDCD=" -dspeffect4="ReplayGain=-albummode={qt}0{qt}"
    Extraction Log
    Track 6: Ripped LBA 186325 to 245444 (13:08) in 2:03. Filename: F:\Redbook\Dave Holland Quintet\Not for Nothin'\Dave Holland Quintet - 06 - What Goes Around.flac
    AccurateRip: Inaccurate (confidence 32) Insecure [Pass 1, Ultra 1 to 1, Re-Rip 4 Frames]
    CRC32: D4033ECD AccurateRip CRC: 34C04E95 [DiscID: 009-001adb65-00c1847d-7b111909-6]
    Re-rip Frame: 211643 (00:05:37.560). Insecure (c2 dropped 100)
    Re-rip Frame: 211736 (00:05:38.800). Insecure (c2 dropped 100)
    Re-rip Frame: 234095 (00:10:36.920) matched 10 / 11
    Re-rip Frame: 234096 (00:10:36.933) matched 10 / 11
    ATTEMPT #2
    dBpoweramp Release 13.2 Digital Audio Extraction Log from Monday, May 11, 2009 9:05 PM
    Drive & Settings
    Extraction Log
    Track 6: Ripped LBA 186325 to 245444 (13:08) in 2:10. Filename: F:\Redbook\Dave Holland Quintet\Not for Nothin'\Dave Holland Quintet - 06 - What Goes Around.flac
    AccurateRip: Inaccurate (confidence 32) Insecure [Pass 1, Ultra 1 to 1, Re-Rip 5 Frames]
    CRC32: F395D637 AccurateRip CRC: 083C4E95 [DiscID: 009-001adb65-00c1847d-7b111909-6]
    Re-rip Frame: 211643 (00:05:37.560) matched 10 / 11
    Re-rip Frame: 212370 (00:05:47.253) matched 10 / 11
    Re-rip Frame: 234095 (00:10:36.920). Insecure (c2 dropped 100)
    Re-rip Frame: 234096 (00:10:36.933). Insecure (c2 dropped 100)
    1 Tracks Ripped Inaccurately
    ATTEMPT #3
    dBpoweramp Release 13.2 Digital Audio Extraction Log from Monday, May 11, 2009 9:13 PM
    Drive & Settings
    Extraction Log
    Track 6: Ripped LBA 186325 to 245444 (13:08) in 3:07. Filename: F:\Redbook\Dave Holland Quintet\Not for Nothin'\Dave Holland Quintet - 06 - What Goes Around.flac
    AccurateRip: Inaccurate (confidence 32) Insecure [Pass 1, Ultra 1 to 2, Re-Rip 14 Frames]
    Re-rip Frame: 211419 (00:05:34.573) matched 10 / 11
    Re-rip Frame: 211420 (00:05:34.586) matched 10 / 11
    Re-rip Frame: 211476 (00:05:35.333) matched 10 / 11
    Re-rip Frame: 211513 (00:05:35.826) matched 10 / 11
    Re-rip Frame: 211605 (00:05:37.053) matched 10 / 11
    Re-rip Frame: 211661 (00:05:37.800) matched 10 / 11
    Re-rip Frame: 212202 (00:05:45.013) matched 10 / 11
    Re-rip Frame: 212388 (00:05:47.493) matched 10 / 11
    Re-rip Frame: 234095 (00:10:36.920) matched 10 / 12
    Re-rip Frame: 234096 (00:10:36.933) matched 10 / 12
    Re-rip Frame: 234269 (00:10:39.240) matched 10 / 11
    Re-rip Frame: 234270 (00:10:39.253) matched 10 / 11
    ATTEMPT #4 (DSP effects OFF)
    dBpoweramp Release 13.2 Digital Audio Extraction Log from Monday, May 11, 2009 9:18 PM
    Drive & Settings
    Extraction Log
    Track 6: Ripped LBA 186325 to 245444 (13:08) in 3:04. Filename: F:\Redbook\Dave Holland Quintet\Not for Nothin'\Dave Holland Quintet - 06 - What Goes Around.flac
    AccurateRip: Inaccurate (confidence 32) Insecure [Pass 1, Ultra 1 to 2, Re-Rip 9 Frames]
    Re-rip Frame: 204261 (00:03:59.133) matched 10 / 11
    Re-rip Frame: 210490 (00:05:22.186) matched 10 / 11
    So.... what now? :(
      • 44051
      #32
      you can burst rip track 6, I have marked it down as a bug to look at shortly.
      • pangit
        • Mar 2009
        • 17
        #33
        Cool! I really look forward to the fix for this problem.
          • 44051
          #34
          Those who suffer 13KB files, Please try R13.3 beta:
          Changes: Secure ripper - fixed issue which could lead to 18KB files from an unsecure rip with c2 pointers MusicBrainz performance improved New option: CD Ripping >> Options >> Secure Settings >> 8KB Transfers (c2 Pointers over USB / Firewire) All programs - menu selection improved (grey bar removed, uses
          • pangit
            • Mar 2009
            • 17
            #35
            Thanks for the notice of the beta version Spoon; I downloaded it an installed it today. I pulled out a disc that has causes errors and re-rips on nearly every track in the past (with version 13.2 and earlier) to test 13.3. FYI, this disc is in excellent shape visually - very few scratches or other anomalies that you'd intuitively expect to result in rip errors.
            Unfortunately the result with 13.3 beta is effectively the same as before; I get useless 54Kb files for all of the error tracks. You mentioned 13Kb files specifically, but I have found that the actual size of the bad files varies for me - the only similarity is that they're dramatically smaller than they should be, and none of them will play. No abort on error function is turned on. I tried ripping this disc twice and got nearly identical results each time.
            Oddly, this beta version didn't write a log file to the output directory for either attempt, even though the setting to do that is turned on. I had to copy and paste the output result log below from the result dialog after the rip was done.
            Code:
            BEGIN LOG
            Information ripping to FLAC, 'Track 1' to 'F:\Redbook\Various Artists\TEST RIP\01 Eric Tingstad - Monongahela.flac'
               Track 1:  Ripped LBA 0 to 14923 (3:18) in 1:07. Filename: F:\Redbook\Various Artists\TEST RIP\01 Eric Tingstad - Monongahela.flac
                 AccurateRip: Inaccurate (confidence 1)   Insecure  [Pass 1, Ultra 1 to 1, Re-Rip 5 Frames]
                 CRC32: 0C4D588F     AccurateRip CRC: 986AE7B2     [DiscID: 013-0018eea1-00f7d050-930bcb0d-1]
                   Re-rip Frame: 660 (00:00:08.786) matched 10 / 11
                   Re-rip Frame: 1123 (00:00:14.960) matched 10 / 12
                   Re-rip Frame: 1124 (00:00:14.973) matched 10 / 12
                   Re-rip Frame: 1607 (00:00:21.413) matched 10 / 11
                   Re-rip Frame: 7711 (00:01:42.800). Insecure  (c2 dropped 100)
            Information ripping to FLAC, 'Track 2' to 'F:\Redbook\Various Artists\TEST RIP\02 David L. White - Barcelona.flac'
               Track 2:  Ripped LBA 14923 to 39088 (5:22) in 1:42. Filename: F:\Redbook\Various Artists\TEST RIP\02 David L. White - Barcelona.flac
                 AccurateRip: Inaccurate (confidence 1)   Insecure  [Pass 1, Ultra 1 to 1, Re-Rip 14 Frames]
                 CRC32: 8B3BCF68     AccurateRip CRC: 3E6C83C3     [DiscID: 013-0018eea1-00f7d050-930bcb0d-2]
                   Re-rip Frame: 15898 (00:00:12.986) matched 10 / 11
                   Re-rip Frame: 20395 (00:01:12.946) matched 10 / 11
                   Re-rip Frame: 20406 (00:01:13.093) matched 10 / 12
                   Re-rip Frame: 20417 (00:01:13.240) matched 10 / 11
                   Re-rip Frame: 25023 (00:02:14.653) matched 10 / 11
                   Re-rip Frame: 25928 (00:02:26.720) matched 10 / 11
                   Re-rip Frame: 27783 (00:02:51.453) matched 10 / 11
                   Re-rip Frame: 29274 (00:03:11.333). Insecure  (c2 dropped 100)
                   Re-rip Frame: 29276 (00:03:11.360). Insecure  (c2 dropped 100)
                   Re-rip Frame: 29423 (00:03:13.320). Insecure  (c2 dropped 100)
                   Re-rip Frame: 30719 (00:03:30.600). Insecure  (c2 dropped 100)
                   Re-rip Frame: 33858 (00:04:12.453). Insecure  (c2 dropped 100)
                   Re-rip Frame: 34708 (00:04:23.786) matched 10 / 11
                   Re-rip Frame: 36461 (00:04:47.160) matched 10 / 11
            Information ripping to FLAC, 'Track 4' to 'F:\Redbook\Various Artists\TEST RIP\04 William Ellwood - Light a Candle.flac'
               Track 4:  Ripped LBA 53238 to 75833 (5:01) in 1:26. Filename: F:\Redbook\Various Artists\TEST RIP\04 William Ellwood - Light a Candle.flac
                 AccurateRip: Inaccurate (confidence 1)   Insecure  [Pass 1, Ultra 1 to 1, Re-Rip 15 Frames]
                 CRC32: 9A409B46     AccurateRip CRC: C1561171     [DiscID: 013-0018eea1-00f7d050-930bcb0d-4]
                   Re-rip Frame: 54519 (00:00:17.066) matched 10 / 11
                   Re-rip Frame: 54994 (00:00:23.400) matched 10 / 12
                   Re-rip Frame: 60660 (00:01:38.946) matched 10 / 11
                   Re-rip Frame: 60673 (00:01:39.120) matched 10 / 11
                   Re-rip Frame: 60686 (00:01:39.293). Insecure  (c2 dropped 100)
                   Re-rip Frame: 61119 (00:01:45.066) matched 10 / 12
                   Re-rip Frame: 62317 (00:02:01.040) matched 10 / 11
                   Re-rip Frame: 62342 (00:02:01.373) matched 10 / 11
                   Re-rip Frame: 66178 (00:02:52.520) matched 10 / 11
                   Re-rip Frame: 66192 (00:02:52.706). Insecure  (c2 dropped 100)
                   Re-rip Frame: 66794 (00:03:00.733). Insecure  (c2 dropped 100)
                   Re-rip Frame: 67275 (00:03:07.146). Insecure  (c2 dropped 100)
                   Re-rip Frame: 70539 (00:03:50.666) matched 10 / 11
                   Re-rip Frame: 70540 (00:03:50.680) matched 10 / 11
                   Re-rip Frame: 70838 (00:03:54.653). Insecure  (c2 dropped 100)
            Information ripping to FLAC, 'Track 3' to 'F:\Redbook\Various Artists\TEST RIP\03 Martin Kolbe - Bye Bye Lullaby.flac'
               Track 3:  Ripped LBA 39088 to 53238 (3:08) in 0:50. Filename: F:\Redbook\Various Artists\TEST RIP\03 Martin Kolbe - Bye Bye Lullaby.flac
                 AccurateRip: Accurate (confidence 1)     [Pass 1, Ultra 1 to 1, Re-Rip 5 Frames]
                 CRC32: 69A1813A     AccurateRip CRC: 7D480A63     [DiscID: 013-0018eea1-00f7d050-930bcb0d-3]
                   Re-rip Frame: 41585 (00:00:33.280) matched 10 / 11
                   Re-rip Frame: 46562 (00:01:39.640) matched 10 / 11
                   Re-rip Frame: 46563 (00:01:39.653) matched 10 / 11
                   Re-rip Frame: 47170 (00:01:47.746). Insecure  (c2 dropped 100)
                   Re-rip Frame: 52237 (00:02:55.306) matched 10 / 11
            Information ripping to FLAC, 'Track 5' to 'F:\Redbook\Various Artists\TEST RIP\05 Ralf Illenberger - Inner Movement.flac'
               Track 5:  Ripped LBA 75833 to 93493 (3:55) in 1:07. Filename: F:\Redbook\Various Artists\TEST RIP\05 Ralf Illenberger - Inner Movement.flac
                 AccurateRip: Inaccurate (confidence 1)   Insecure  [Pass 1, Ultra 1 to 1, Re-Rip 13 Frames]
                 CRC32: 22934F8D     AccurateRip CRC: F269A467     [DiscID: 013-0018eea1-00f7d050-930bcb0d-5]
                   Re-rip Frame: 77666 (00:00:24.426) matched 10 / 11
                   Re-rip Frame: 78290 (00:00:32.746). Insecure  (c2 dropped 100)
                   Re-rip Frame: 78472 (00:00:35.173). Insecure  (c2 dropped 100)
                   Re-rip Frame: 78901 (00:00:40.893). Insecure  (c2 dropped 100)
                   Re-rip Frame: 78902 (00:00:40.906). Insecure  (c2 dropped 100)
                   Re-rip Frame: 79237 (00:00:45.373) matched 10 / 11
                   Re-rip Frame: 79433 (00:00:47.986) matched 10 / 11
                   Re-rip Frame: 87024 (00:02:29.200). Insecure  (c2 dropped 100)
                   Re-rip Frame: 87941 (00:02:41.426). Insecure  (c2 dropped 100)
                   Re-rip Frame: 89480 (00:03:01.946) matched 10 / 11
                   Re-rip Frame: 90504 (00:03:15.600). Insecure  (c2 dropped 100)
                   Re-rip Frame: 90765 (00:03:19.080) matched 10 / 11
                   Re-rip Frame: 91692 (00:03:31.440). Insecure  (c2 dropped 100)
            Information ripping to FLAC, 'Track 6' to 'F:\Redbook\Various Artists\TEST RIP\06 Sheldon Mirowitz - Leaving Home.flac'
               Track 6:  Ripped LBA 93493 to 110923 (3:52) in 1:16. Filename: F:\Redbook\Various Artists\TEST RIP\06 Sheldon Mirowitz - Leaving Home.flac
                 AccurateRip: Inaccurate (confidence 1)   Insecure  [Pass 1, Ultra 1 to 1, Re-Rip 22 Frames]
                 CRC32: EC6DB4C9     AccurateRip CRC: DEA29A73     [DiscID: 013-0018eea1-00f7d050-930bcb0d-6]
                   Re-rip Frame: 94605 (00:00:14.813). Insecure  (c2 dropped 100)
                   Re-rip Frame: 95498 (00:00:26.720). Insecure  (c2 dropped 100)
                   Re-rip Frame: 95527 (00:00:27.106). Insecure  (c2 dropped 100)
                   Re-rip Frame: 96408 (00:00:38.853) matched 10 / 11
                   Re-rip Frame: 98162 (00:01:02.240) matched 10 / 12
                   Re-rip Frame: 101535 (00:01:47.213). Insecure  (c2 dropped 100)
                   Re-rip Frame: 101578 (00:01:47.786) matched 10 / 12
                   Re-rip Frame: 101592 (00:01:47.973) matched 10 / 11
                   Re-rip Frame: 101593 (00:01:47.986) matched 10 / 11
                   Re-rip Frame: 102594 (00:02:01.333) matched 10 / 11
                   Re-rip Frame: 102596 (00:02:01.360). Insecure  (c2 dropped 100)
                   Re-rip Frame: 102670 (00:02:02.346). Insecure  (c2 dropped 100)
                   Re-rip Frame: 105842 (00:02:44.640) matched 10 / 11
                   Re-rip Frame: 105871 (00:02:45.026). Insecure  (c2 dropped 100)
                   Re-rip Frame: 105872 (00:02:45.040) matched 10 / 12
                   Re-rip Frame: 106220 (00:02:49.680). Insecure  (c2 dropped 100)
                   Re-rip Frame: 106280 (00:02:50.480) matched 10 / 11
                   Re-rip Frame: 107566 (00:03:07.626) matched 10 / 11
                   Re-rip Frame: 108284 (00:03:17.200). Insecure  (c2 dropped 100)
                   Re-rip Frame: 109409 (00:03:32.200). Insecure  (c2 dropped 100)
                   Re-rip Frame: 110369 (00:03:45.000) matched 10 / 12
                   Re-rip Frame: 110829 (00:03:51.133) matched 10 / 10
            Information ripping to FLAC, 'Track 7' to 'F:\Redbook\Various Artists\TEST RIP\07 Simon Wyberg - Nocturne Mariah's Watermill.flac'
               Track 7:  Ripped LBA 110923 to 124755 (3:04) in 1:05. Filename: F:\Redbook\Various Artists\TEST RIP\07 Simon Wyberg - Nocturne Mariah's Watermill.flac
                 AccurateRip: Inaccurate (confidence 1)   Insecure  [Pass 1, Ultra 1 to 1, Re-Rip 25 Frames]
                 CRC32: E92712D3     AccurateRip CRC: 2FEBEF71     [DiscID: 013-0018eea1-00f7d050-930bcb0d-7]
                   Re-rip Frame: 111659 (00:00:09.800). Insecure  (c2 dropped 100)
                   Re-rip Frame: 114396 (00:00:46.293) matched 10 / 11
                   Re-rip Frame: 114629 (00:00:49.400) matched 10 / 11
                   Re-rip Frame: 114645 (00:00:49.613). Insecure  (c2 dropped 100)
                   Re-rip Frame: 114660 (00:00:49.813). Insecure  (c2 dropped 100)
                   Re-rip Frame: 116242 (00:01:10.906). Insecure  (c2 dropped 100)
                   Re-rip Frame: 116273 (00:01:11.320) matched 10 / 12
                   Re-rip Frame: 116365 (00:01:12.546). Insecure  (c2 dropped 100)
                   Re-rip Frame: 116380 (00:01:12.746). Insecure  (c2 dropped 100)
                   Re-rip Frame: 116659 (00:01:16.466) matched 10 / 11
                   Re-rip Frame: 117375 (00:01:26.013) matched 10 / 11
                   Re-rip Frame: 117451 (00:01:27.026) matched 10 / 11
                   Re-rip Frame: 118091 (00:01:35.560) matched 10 / 11
                   Re-rip Frame: 118294 (00:01:38.266) matched 10 / 12
                   Re-rip Frame: 119014 (00:01:47.866) matched 10 / 11
                   Re-rip Frame: 119499 (00:01:54.333). Insecure  (c2 dropped 100)
                   Re-rip Frame: 119702 (00:01:57.040) matched 10 / 11
                   Re-rip Frame: 120093 (00:02:02.253). Insecure  (c2 dropped 100)
                   Re-rip Frame: 120860 (00:02:12.480) matched 10 / 11
                   Re-rip Frame: 120861 (00:02:12.493). Insecure  (c2 dropped 100)
                   Re-rip Frame: 121380 (00:02:19.413). Insecure  (c2 dropped 100)
                   Re-rip Frame: 121758 (00:02:24.453). Insecure  (c2 dropped 100)
                   Re-rip Frame: 123021 (00:02:41.293) matched 10 / 11
                   Re-rip Frame: 123051 (00:02:41.693). Insecure  (c2 dropped 100)
                   Re-rip Frame: 123922 (00:02:53.306). Insecure  (c2 dropped 100)
            Information ripping to FLAC, 'Track 8' to 'F:\Redbook\Various Artists\TEST RIP\08 Simon Wynberg - Mariah's Watermill.flac'
               Track 8:  Ripped LBA 124755 to 145413 (4:35) in 1:32. Filename: F:\Redbook\Various Artists\TEST RIP\08 Simon Wynberg - Mariah's Watermill.flac
                 AccurateRip: Inaccurate (confidence 1)   Insecure  [Pass 1, Ultra 1 to 1, Re-Rip 33 Frames]
                 CRC32: 12A0DDB3     AccurateRip CRC: 4C5221EC     [DiscID: 013-0018eea1-00f7d050-930bcb0d-8]
                   Re-rip Frame: 127756 (00:00:40.000) matched 10 / 11
                   Re-rip Frame: 127787 (00:00:40.413) matched 10 / 12
                   Re-rip Frame: 128649 (00:00:51.906). Insecure  (c2 dropped 100)
                   Re-rip Frame: 129228 (00:00:59.626). Insecure  (c2 dropped 100)
                   Re-rip Frame: 130239 (00:01:13.106). Insecure  (c2 dropped 100)
                   Re-rip Frame: 131203 (00:01:25.960) matched 10 / 11
                   Re-rip Frame: 131447 (00:01:29.213) matched 10 / 11
                   Re-rip Frame: 133094 (00:01:51.173). Insecure  (c2 dropped 100)
                   Re-rip Frame: 133370 (00:01:54.853). Insecure  (c2 dropped 100)
                   Re-rip Frame: 133498 (00:01:56.560) matched 10 / 11
                   Re-rip Frame: 135838 (00:02:27.760) matched 10 / 11
                   Re-rip Frame: 136098 (00:02:31.226). Insecure  (c2 dropped 100)
                   Re-rip Frame: 136655 (00:02:38.653). Insecure  (c2 dropped 100)
                   Re-rip Frame: 137275 (00:02:46.920) matched 10 / 12
                   Re-rip Frame: 137977 (00:02:56.280). Insecure  (c2 dropped 100)
                   Re-rip Frame: 138010 (00:02:56.720) matched 10 / 11
                   Re-rip Frame: 140160 (00:03:25.386). Insecure  (c2 dropped 100)
                   Re-rip Frame: 140161 (00:03:25.400) matched 10 / 11
                   Re-rip Frame: 140590 (00:03:31.120). Insecure  (c2 dropped 100)
                   Re-rip Frame: 141149 (00:03:38.573). Insecure  (c2 dropped 100)
                   Re-rip Frame: 141596 (00:03:44.533). Insecure  (c2 dropped 100)
                   Re-rip Frame: 141779 (00:03:46.973) matched 10 / 11
                   Re-rip Frame: 142305 (00:03:53.986) matched 10 / 11
                   Re-rip Frame: 143397 (00:04:08.546) matched 10 / 10
                   Re-rip Frame: 143780 (00:04:13.653) matched 10 / 11
                   Re-rip Frame: 144047 (00:04:17.213). Insecure  (c2 dropped 100)
                   Re-rip Frame: 144264 (00:04:20.106). Insecure  (c2 dropped 100)
                   Re-rip Frame: 144345 (00:04:21.186) matched 10 / 11
                   Re-rip Frame: 144510 (00:04:23.386) matched 10 / 11
                   Re-rip Frame: 144527 (00:04:23.613). Insecure  (c2 dropped 100)
                   Re-rip Frame: 144544 (00:04:23.840) matched 10 / 11
                   Re-rip Frame: 144842 (00:04:27.813) matched 10 / 11
                   Re-rip Frame: 144843 (00:04:27.826) matched 10 / 11
            Information ripping to FLAC, 'Track 9' to 'F:\Redbook\Various Artists\TEST RIP\09 Nando Lauria - Sonho (Dream).flac'
               Track 9:  Ripped LBA 145413 to 171858 (5:52) in 2:14. Filename: F:\Redbook\Various Artists\TEST RIP\09 Nando Lauria - Sonho (Dream).flac
                 AccurateRip: Inaccurate (confidence 1)   Insecure  [Pass 1, Ultra 1 to 1, Re-Rip 56 Frames]
                 CRC32: 1554CEAD     AccurateRip CRC: C0CD030C     [DiscID: 013-0018eea1-00f7d050-930bcb0d-9]
                   Re-rip Frame: 145794 (00:00:05.066) matched 10 / 11
                   Re-rip Frame: 145996 (00:00:07.760). Insecure  (c2 dropped 100)
                   Re-rip Frame: 146513 (00:00:14.653) matched 10 / 11
                   Re-rip Frame: 146993 (00:00:21.053) matched 10 / 11
                   Re-rip Frame: 147865 (00:00:32.680). Insecure  (c2 dropped 100)
                   Re-rip Frame: 148534 (00:00:41.600). Insecure  (c2 dropped 100)
                   Re-rip Frame: 149727 (00:00:57.506). Insecure  (c2 dropped 100)
                   Re-rip Frame: 150890 (00:01:13.013). Insecure  (c2 dropped 100)
                   Re-rip Frame: 150924 (00:01:13.466). Insecure  (c2 dropped 100)
                   Re-rip Frame: 151833 (00:01:25.586) matched 10 / 11
                   Re-rip Frame: 151887 (00:01:26.306). Insecure  (c2 dropped 100)
                   Re-rip Frame: 152104 (00:01:29.200). Insecure  (c2 dropped 100)
                   Re-rip Frame: 152646 (00:01:36.426). Insecure  (c2 dropped 100)
                   Re-rip Frame: 152900 (00:01:39.813) matched 10 / 12
                   Re-rip Frame: 153935 (00:01:53.613) matched 10 / 11
                   Re-rip Frame: 154088 (00:01:55.653) matched 10 / 12
                   Re-rip Frame: 154408 (00:01:59.920). Insecure  (c2 dropped 100)
                   Re-rip Frame: 154495 (00:02:01.080) matched 10 / 11
                   Re-rip Frame: 154854 (00:02:05.866). Insecure  (c2 dropped 100)
                   Re-rip Frame: 154886 (00:02:06.293) matched 10 / 11
                   Re-rip Frame: 155192 (00:02:10.373). Insecure  (c2 dropped 100)
                   Re-rip Frame: 155210 (00:02:10.613). Insecure  (c2 dropped 100)
                   Re-rip Frame: 155398 (00:02:13.120). Insecure  (c2 dropped 100)
                   Re-rip Frame: 155550 (00:02:15.146). Insecure  (c2 dropped 100)
                   Re-rip Frame: 155567 (00:02:15.373). Insecure  (c2 dropped 100)
                   Re-rip Frame: 155618 (00:02:16.053). Insecure  (c2 dropped 100)
                   Re-rip Frame: 156042 (00:02:21.706). Insecure  (c2 dropped 100)
                   Re-rip Frame: 157082 (00:02:35.573) matched 10 / 11
                   Re-rip Frame: 158934 (00:03:00.266) matched 10 / 11
                   Re-rip Frame: 158951 (00:03:00.493). Insecure  (c2 dropped 100)
                   Re-rip Frame: 159035 (00:03:01.613) matched 10 / 12
                   Re-rip Frame: 159103 (00:03:02.520) matched 10 / 12
                   Re-rip Frame: 159671 (00:03:10.093). Insecure  (c2 dropped 100)
                   Re-rip Frame: 159810 (00:03:11.946). Insecure  (c2 dropped 100)
                   Re-rip Frame: 160583 (00:03:22.253) matched 10 / 11
                   Re-rip Frame: 162203 (00:03:43.853). Insecure  (c2 dropped 100)
                   Re-rip Frame: 163033 (00:03:54.920). Insecure  (c2 dropped 100)
                   Re-rip Frame: 163537 (00:04:01.640) matched 10 / 11
                   Re-rip Frame: 164526 (00:04:14.826) matched 10 / 11
                   Re-rip Frame: 165809 (00:04:31.933) matched 10 / 11
                   Re-rip Frame: 166332 (00:04:38.906). Insecure  (c2 dropped 100)
                   Re-rip Frame: 166662 (00:04:43.306) matched 10 / 11
                   Re-rip Frame: 166856 (00:04:45.893). Insecure  (c2 dropped 100)
                   Re-rip Frame: 166873 (00:04:46.120) matched 10 / 11
                   Re-rip Frame: 166890 (00:04:46.346). Insecure  (c2 dropped 100)
                   Re-rip Frame: 167640 (00:04:56.346) matched 10 / 11
                   Re-rip Frame: 167746 (00:04:57.760) matched 10 / 11
                   Re-rip Frame: 168023 (00:05:01.453). Insecure  (c2 dropped 100)
                   Re-rip Frame: 168463 (00:05:07.320). Insecure  (c2 dropped 100)
                   Re-rip Frame: 169389 (00:05:19.666). Insecure  (c2 dropped 100)
                   Re-rip Frame: 169480 (00:05:20.880) matched 10 / 11
                   Re-rip Frame: 169674 (00:05:23.466) matched 10 / 11
                   Re-rip Frame: 170972 (00:05:40.773). Insecure  (c2 dropped 100)
                   Re-rip Frame: 171076 (00:05:42.160). Insecure  (c2 dropped 100)
                   Re-rip Frame: 171500 (00:05:47.813). Insecure  (c2 dropped 100)
                   Re-rip Frame: 171619 (00:05:49.400). Insecure  (c2 dropped 100)
            Information ripping to FLAC, 'Track 10' to 'F:\Redbook\Various Artists\TEST RIP\10 Sheldon Mirowitz - Since You Asked.flac'
               Track 10:  Ripped LBA 171858 to 178468 (1:28) in 0:46. Filename: F:\Redbook\Various Artists\TEST RIP\10 Sheldon Mirowitz - Since You Asked.flac
                 AccurateRip: Inaccurate (confidence 1)   Insecure  [Pass 1, Ultra 1 to 1, Re-Rip 21 Frames]
                 CRC32: 10AAABFD     AccurateRip CRC: 9ABC3590     [DiscID: 013-0018eea1-00f7d050-930bcb0d-10]
                   Re-rip Frame: 172152 (00:00:03.906). Insecure  (c2 dropped 100)
                   Re-rip Frame: 172203 (00:00:04.586). Insecure  (c2 dropped 100)
                   Re-rip Frame: 172273 (00:00:05.520) matched 10 / 11
                   Re-rip Frame: 172274 (00:00:05.533) matched 10 / 12
                   Re-rip Frame: 172716 (00:00:11.426). Insecure  (c2 dropped 100)
                   Re-rip Frame: 173193 (00:00:17.786) matched 10 / 11
                   Re-rip Frame: 174042 (00:00:29.106) matched 10 / 11
                   Re-rip Frame: 174411 (00:00:34.026). Insecure  (c2 dropped 100)
                   Re-rip Frame: 174890 (00:00:40.413) matched 10 / 11
                   Re-rip Frame: 174927 (00:00:40.906) matched 10 / 12
                   Re-rip Frame: 174962 (00:00:41.373). Insecure  (c2 dropped 100)
                   Re-rip Frame: 175084 (00:00:43.000) matched 10 / 11
                   Re-rip Frame: 175123 (00:00:43.520) matched 10 / 12
                   Re-rip Frame: 175795 (00:00:52.480) matched 10 / 11
                   Re-rip Frame: 176096 (00:00:56.493). Insecure  (c2 dropped 100)
                   Re-rip Frame: 176523 (00:01:02.186). Insecure  (c2 dropped 100)
                   Re-rip Frame: 176862 (00:01:06.706). Insecure  (c2 dropped 100)
                   Re-rip Frame: 177323 (00:01:12.853). Insecure  (c2 dropped 100)
                   Re-rip Frame: 177504 (00:01:15.266) matched 10 / 11
                   Re-rip Frame: 178394 (00:01:27.133). Insecure  (c2 dropped 100)
                   Re-rip Frame: 178412 (00:01:27.373) matched 10 / 10
            Information ripping to FLAC, 'Track 11' to 'F:\Redbook\Various Artists\TEST RIP\11 Matthew Montfort - Amber.flac'
               Track 11:  Ripped LBA 178468 to 188343 (2:11) in 1:18. Filename: F:\Redbook\Various Artists\TEST RIP\11 Matthew Montfort - Amber.flac
                 AccurateRip: Inaccurate (confidence 1)   Insecure  [Pass 1, Ultra 1 to 1, Re-Rip 40 Frames]
                 CRC32: 31B110BA     AccurateRip CRC: FDB6C3DB     [DiscID: 013-0018eea1-00f7d050-930bcb0d-11]
                   Re-rip Frame: 178696 (00:00:03.026) matched 10 / 11
                   Re-rip Frame: 178998 (00:00:07.053). Insecure  (c2 dropped 100)
                   Re-rip Frame: 179092 (00:00:08.306). Insecure  (c2 dropped 100)
                   Re-rip Frame: 179323 (00:00:11.386) matched 10 / 11
                   Re-rip Frame: 179375 (00:00:12.080). Insecure  (c2 dropped 100)
                   Re-rip Frame: 179771 (00:00:17.360) matched 10 / 11
                   Re-rip Frame: 180933 (00:00:32.853) matched 10 / 11
                   Re-rip Frame: 181078 (00:00:34.786). Insecure  (c2 dropped 100)
                   Re-rip Frame: 181166 (00:00:35.960) matched 10 / 11
                   Re-rip Frame: 181329 (00:00:38.133). Insecure  (c2 dropped 100)
                   Re-rip Frame: 182642 (00:00:55.640). Insecure  (c2 dropped 100)
                   Re-rip Frame: 182678 (00:00:56.120). Insecure  (c2 dropped 100)
                   Re-rip Frame: 182696 (00:00:56.360) matched 10 / 11
                   Re-rip Frame: 182805 (00:00:57.813). Insecure  (c2 dropped 100)
                   Re-rip Frame: 182875 (00:00:58.746). Insecure  (c2 dropped 100)
                   Re-rip Frame: 183630 (00:01:08.813). Insecure  (c2 dropped 100)
                   Re-rip Frame: 183648 (00:01:09.053). Insecure  (c2 dropped 100)
                   Re-rip Frame: 183666 (00:01:09.293). Insecure  (c2 dropped 100)
                   Re-rip Frame: 183902 (00:01:12.440) matched 10 / 11
                   Re-rip Frame: 184462 (00:01:19.906). Insecure  (c2 dropped 100)
                   Re-rip Frame: 184733 (00:01:23.520). Insecure  (c2 dropped 100)
                   Re-rip Frame: 184857 (00:01:25.173) matched 10 / 11
                   Re-rip Frame: 184874 (00:01:25.400). Insecure  (c2 dropped 100)
                   Re-rip Frame: 184875 (00:01:25.413). Insecure  (c2 dropped 100)
                   Re-rip Frame: 184893 (00:01:25.653). Insecure  (c2 dropped 100)
                   Re-rip Frame: 185365 (00:01:31.946) matched 10 / 12
                   Re-rip Frame: 185491 (00:01:33.626). Insecure  (c2 dropped 100)
                   Re-rip Frame: 185997 (00:01:40.373) matched 10 / 12
                   Re-rip Frame: 186015 (00:01:40.613) matched 10 / 11
                   Re-rip Frame: 186016 (00:01:40.626) matched 10 / 11
                   Re-rip Frame: 186037 (00:01:40.906). Insecure  (c2 dropped 100)
                   Re-rip Frame: 186087 (00:01:41.573) matched 10 / 11
                   Re-rip Frame: 186217 (00:01:43.306). Insecure  (c2 dropped 100)
                   Re-rip Frame: 186218 (00:01:43.320). Insecure  (c2 dropped 100)
                   Re-rip Frame: 186251 (00:01:43.760). Insecure  (c2 dropped 100)
                   Re-rip Frame: 186667 (00:01:49.306) matched 10 / 11
                   Re-rip Frame: 187251 (00:01:57.093). Insecure  (c2 dropped 100)
                   Re-rip Frame: 187321 (00:01:58.026). Insecure  (c2 dropped 100)
                   Re-rip Frame: 187358 (00:01:58.520) matched 10 / 11
                   Re-rip Frame: 188103 (00:02:08.453). Insecure  (c2 dropped 100)
            Information ripping to FLAC, 'Track 12' to 'F:\Redbook\Various Artists\TEST RIP\12 John Doan - Remembering Greensleeves.flac'
               Track 12:  Ripped LBA 188343 to 211180 (5:04) in 2:07. Filename: F:\Redbook\Various Artists\TEST RIP\12 John Doan - Remembering Greensleeves.flac
                 AccurateRip: Inaccurate (confidence 1)   Insecure  [Pass 1, Ultra 1 to 1, Re-Rip 88 Frames]
                 CRC32: BD1E1014     AccurateRip CRC: C710AAC1     [DiscID: 013-0018eea1-00f7d050-930bcb0d-12]
                   Re-rip Frame: 188414 (00:00:00.933). Insecure  (c2 dropped 100)
                   Re-rip Frame: 188432 (00:00:01.173) matched 10 / 12
                   Re-rip Frame: 188466 (00:00:01.626). Insecure  (c2 dropped 100)
                   Re-rip Frame: 188484 (00:00:01.866) matched 10 / 12
                   Re-rip Frame: 188704 (00:00:04.800) matched 10 / 12
                   Re-rip Frame: 188924 (00:00:07.733) matched 10 / 11
                   Re-rip Frame: 189011 (00:00:08.893) matched 10 / 12
                   Re-rip Frame: 189832 (00:00:19.840) matched 10 / 11
                   Re-rip Frame: 190325 (00:00:26.413) matched 10 / 11
                   Re-rip Frame: 190455 (00:00:28.146) matched 10 / 11
                   Re-rip Frame: 191205 (00:00:38.146). Insecure  (c2 dropped 100)
                   Re-rip Frame: 191206 (00:00:38.160). Insecure  (c2 dropped 100)
                   Re-rip Frame: 191240 (00:00:38.613) matched 10 / 12
                   Re-rip Frame: 191313 (00:00:39.586) matched 10 / 12
                   Re-rip Frame: 191607 (00:00:43.506) matched 10 / 12
                   Re-rip Frame: 191680 (00:00:44.480) matched 10 / 11
                   Re-rip Frame: 191768 (00:00:45.653) matched 10 / 11
                   Re-rip Frame: 192230 (00:00:51.813) matched 10 / 11
                   Re-rip Frame: 192394 (00:00:54.000) matched 10 / 11
                   Re-rip Frame: 192907 (00:01:00.840) matched 10 / 11
                   Re-rip Frame: 193072 (00:01:03.040) matched 10 / 11
                   Re-rip Frame: 193091 (00:01:03.293). Insecure  (c2 dropped 100)
                   Re-rip Frame: 193657 (00:01:10.840). Insecure  (c2 dropped 100)
                   Re-rip Frame: 193900 (00:01:14.080) matched 10 / 11
                   Re-rip Frame: 194139 (00:01:17.266) matched 10 / 12
                   Re-rip Frame: 194140 (00:01:17.280) matched 10 / 12
                   Re-rip Frame: 194211 (00:01:18.226) matched 10 / 11
                   Re-rip Frame: 194580 (00:01:23.146) matched 10 / 11
                   Re-rip Frame: 194581 (00:01:23.160). Insecure  (c2 dropped 100)
                   Re-rip Frame: 194582 (00:01:23.173). Insecure  (c2 dropped 100)
                   Re-rip Frame: 194616 (00:01:23.626). Insecure  (c2 dropped 100)
                   Re-rip Frame: 194689 (00:01:24.600). Insecure  (c2 dropped 100)
                   Re-rip Frame: 194800 (00:01:26.080). Insecure  (c2 dropped 100)
                   Re-rip Frame: 194967 (00:01:28.306) matched 10 / 11
                   Re-rip Frame: 194986 (00:01:28.560). Insecure  (c2 dropped 100)
                   Re-rip Frame: 195004 (00:01:28.800) matched 10 / 11
                   Re-rip Frame: 195702 (00:01:38.106). Insecure  (c2 dropped 100)
                   Re-rip Frame: 195995 (00:01:42.013). Insecure  (c2 dropped 100)
                   Re-rip Frame: 196514 (00:01:48.933) matched 10 / 11
                   Re-rip Frame: 196941 (00:01:54.626) matched 10 / 11
                   Re-rip Frame: 197958 (00:02:08.186) matched 10 / 11
                   Re-rip Frame: 198310 (00:02:12.880) matched 10 / 11
                   Re-rip Frame: 198532 (00:02:15.840) matched 10 / 11
                   Re-rip Frame: 198700 (00:02:18.080) matched 10 / 11
                   Re-rip Frame: 198903 (00:02:20.786). Insecure  (c2 dropped 100)
                   Re-rip Frame: 199386 (00:02:27.226). Insecure  (c2 dropped 100)
                   Re-rip Frame: 199869 (00:02:33.666) matched 10 / 11
                   Re-rip Frame: 199964 (00:02:34.933) matched 10 / 11
                   Re-rip Frame: 200093 (00:02:36.653) matched 10 / 11
                   Re-rip Frame: 200147 (00:02:37.373) matched 10 / 11
                   Re-rip Frame: 200166 (00:02:37.626) matched 10 / 11
                   Re-rip Frame: 200202 (00:02:38.106). Insecure  (c2 dropped 100)
                   Re-rip Frame: 201263 (00:02:52.253) matched 10 / 11
                   Re-rip Frame: 201338 (00:02:53.253) matched 10 / 11
                   Re-rip Frame: 202513 (00:03:08.920). Insecure  (c2 dropped 100)
                   Re-rip Frame: 202982 (00:03:15.173) matched 10 / 11
                   Re-rip Frame: 203000 (00:03:15.413) matched 10 / 11
                   Re-rip Frame: 203054 (00:03:16.133) matched 10 / 11
                   Re-rip Frame: 203131 (00:03:17.160). Insecure  (c2 dropped 100)
                   Re-rip Frame: 203149 (00:03:17.400). Insecure  (c2 dropped 100)
                   Re-rip Frame: 203336 (00:03:19.893) matched 10 / 11
                   Re-rip Frame: 203466 (00:03:21.626) matched 10 / 12
                   Re-rip Frame: 204046 (00:03:29.360) matched 10 / 12
                   Re-rip Frame: 204047 (00:03:29.373) matched 10 / 11
                   Re-rip Frame: 204066 (00:03:29.626). Insecure  (c2 dropped 100)
                   Re-rip Frame: 204084 (00:03:29.866) matched 10 / 11
                   Re-rip Frame: 204274 (00:03:32.400). Insecure  (c2 dropped 100)
                   Re-rip Frame: 204552 (00:03:36.106). Insecure  (c2 dropped 100)
                   Re-rip Frame: 204889 (00:03:40.600) matched 10 / 11
                   Re-rip Frame: 205432 (00:03:47.840). Insecure  (c2 dropped 100)
                   Re-rip Frame: 205600 (00:03:50.080) matched 10 / 11
                   Re-rip Frame: 205603 (00:03:50.120) matched 10 / 11
                   Re-rip Frame: 206056 (00:03:56.160) matched 10 / 11
                   Re-rip Frame: 206204 (00:03:58.133). Insecure  (c2 dropped 100)
                   Re-rip Frame: 208048 (00:04:22.720) matched 10 / 11
                   Re-rip Frame: 208085 (00:04:23.213). Insecure  (c2 dropped 100)
                   Re-rip Frame: 208235 (00:04:25.213) matched 10 / 11
                   Re-rip Frame: 208236 (00:04:25.226) matched 10 / 11
                   Re-rip Frame: 208482 (00:04:28.506) matched 10 / 11
                   Re-rip Frame: 208709 (00:04:31.533). Insecure  (c2 dropped 100)
                   Re-rip Frame: 209009 (00:04:35.533). Insecure  (c2 dropped 100)
                   Re-rip Frame: 209048 (00:04:36.053) matched 10 / 11
                   Re-rip Frame: 209049 (00:04:36.066) matched 10 / 11
                   Re-rip Frame: 209444 (00:04:41.333) matched 10 / 12
                   Re-rip Frame: 209745 (00:04:45.346). Insecure  (c2 dropped 100)
                   Re-rip Frame: 209975 (00:04:48.413) matched 10 / 11
                   Re-rip Frame: 211071 (00:05:03.026) matched 10 / 11
                   Re-rip Frame: 211092 (00:05:03.306) matched 10 / 10
            Information ripping to FLAC, 'Track 13' to 'F:\Redbook\Various Artists\TEST RIP\13 Martin Kolbe - Bye Bye Lullaby.flac'
               Track 13:  Ripped LBA 211180 to 226438 (3:23) in 1:35. Filename: F:\Redbook\Various Artists\TEST RIP\13 Martin Kolbe - Bye Bye Lullaby.flac
                 AccurateRip: Inaccurate (confidence 1)   Insecure  [Pass 1, Ultra 1 to 1, Re-Rip 59 Frames]
                 CRC32: 987F7C89     AccurateRip CRC: 112C1880     [DiscID: 013-0018eea1-00f7d050-930bcb0d-13]
                   Re-rip Frame: 211490 (00:00:04.120). Insecure  (c2 dropped 100)
                   Re-rip Frame: 211566 (00:00:05.133) matched 10 / 11
                   Re-rip Frame: 211623 (00:00:05.893) matched 10 / 12
                   Re-rip Frame: 211945 (00:00:10.186). Insecure  (c2 dropped 100)
                   Re-rip Frame: 212230 (00:00:13.986) matched 10 / 12
                   Re-rip Frame: 212878 (00:00:22.626). Insecure  (c2 dropped 100)
                   Re-rip Frame: 213144 (00:00:26.173) matched 10 / 11
                   Re-rip Frame: 213617 (00:00:32.480). Insecure  (c2 dropped 100)
                   Re-rip Frame: 213618 (00:00:32.493) matched 10 / 11
                   Re-rip Frame: 213619 (00:00:32.506). Insecure  (c2 dropped 100)
                   Re-rip Frame: 214189 (00:00:40.106) matched 10 / 11
                   Re-rip Frame: 214227 (00:00:40.613) matched 10 / 11
                   Re-rip Frame: 214265 (00:00:41.120). Insecure  (c2 dropped 100)
                   Re-rip Frame: 214456 (00:00:43.666) matched 10 / 11
                   Re-rip Frame: 214705 (00:00:46.986). Insecure  (c2 dropped 100)
                   Re-rip Frame: 214744 (00:00:47.506). Insecure  (c2 dropped 100)
                   Re-rip Frame: 214781 (00:00:48.000) matched 10 / 11
                   Re-rip Frame: 215391 (00:00:56.133). Insecure  (c2 dropped 100)
                   Re-rip Frame: 215813 (00:01:01.760). Insecure  (c2 dropped 100)
                   Re-rip Frame: 216099 (00:01:05.573). Insecure  (c2 dropped 100)
                   Re-rip Frame: 216403 (00:01:09.626). Insecure  (c2 dropped 100)
                   Re-rip Frame: 216903 (00:01:16.293) matched 10 / 11
                   Re-rip Frame: 217304 (00:01:21.640) matched 10 / 11
                   Re-rip Frame: 217361 (00:01:22.400) matched 10 / 11
                   Re-rip Frame: 217534 (00:01:24.706). Insecure  (c2 dropped 100)
                   Re-rip Frame: 217743 (00:01:27.493) matched 10 / 11
                   Re-rip Frame: 217974 (00:01:30.573) matched 10 / 11
                   Re-rip Frame: 218185 (00:01:33.386) matched 10 / 11
                   Re-rip Frame: 218186 (00:01:33.400) matched 10 / 11
                   Re-rip Frame: 218225 (00:01:33.920) matched 10 / 11
                   Re-rip Frame: 218570 (00:01:38.520) matched 10 / 11
                   Re-rip Frame: 219128 (00:01:45.960) matched 10 / 11
                   Re-rip Frame: 219169 (00:01:46.506). Insecure  (c2 dropped 100)
                   Re-rip Frame: 219246 (00:01:47.533) matched 10 / 11
                   Re-rip Frame: 219491 (00:01:50.800) matched 10 / 11
                   Re-rip Frame: 219821 (00:01:55.200). Insecure  (c2 dropped 100)
                   Re-rip Frame: 220052 (00:01:58.280). Insecure  (c2 dropped 100)
                   Re-rip Frame: 220587 (00:02:05.413). Insecure  (c2 dropped 100)
                   Re-rip Frame: 220879 (00:02:09.306). Insecure  (c2 dropped 100)
                   Re-rip Frame: 220898 (00:02:09.560) matched 10 / 11
                   Re-rip Frame: 220899 (00:02:09.573) matched 10 / 11
                   Re-rip Frame: 221572 (00:02:18.546). Insecure  (c2 dropped 100)
                   Re-rip Frame: 222247 (00:02:27.546) matched 10 / 11
                   Re-rip Frame: 222479 (00:02:30.640). Insecure  (c2 dropped 100)
                   Re-rip Frame: 222576 (00:02:31.933) matched 10 / 11
                   Re-rip Frame: 222772 (00:02:34.546) matched 10 / 11
                   Re-rip Frame: 223232 (00:02:40.680) matched 10 / 11
                   Re-rip Frame: 223565 (00:02:45.120). Insecure  (c2 dropped 100)
                   Re-rip Frame: 224086 (00:02:52.066). Insecure  (c2 dropped 100)
                   Re-rip Frame: 224106 (00:02:52.333). Insecure  (c2 dropped 100)
                   Re-rip Frame: 224223 (00:02:53.893). Insecure  (c2 dropped 100)
                   Re-rip Frame: 224224 (00:02:53.906). Insecure  (c2 dropped 100)
                   Re-rip Frame: 224513 (00:02:57.760) matched 10 / 11
                   Re-rip Frame: 224843 (00:03:02.160). Insecure  (c2 dropped 100)
                   Re-rip Frame: 224862 (00:03:02.413) matched 10 / 11
                   Re-rip Frame: 226007 (00:03:17.680) matched 10 / 11
                   Re-rip Frame: 226027 (00:03:17.946) matched 10 / 11
                   Re-rip Frame: 226106 (00:03:19.000) matched 10 / 11
                   Re-rip Frame: 226261 (00:03:21.066). Insecure  (c2 dropped 100)
            Last edited by LtData; May 20, 2009, 02:47 AM. Reason: added code tags to improve readability
              • 44051
              #36
              Pangit See:
              (new beta to try today 17th)
              • pangit
                • Mar 2009
                • 17
                #37
                Thanks Spoon; I welcome the opportunity to help quash this bug. I installed the latest beta, turned on the diagnostic option, and re-ripped my problem disc that has become my reference for testing this bug. Let me know if you'd like me to try anything else. Log is as follows.
                Code:
                BEGIN DIAGNOSTIC LOG
                Using SCSI PassThrough  [clCDDA::SetCommunication]
                ->->  [frmMain::RefreshTrackListing]
                  Quitting Meta Thread: Quit
                  ->->  [clCDDA::ReturnDriveList]
                    Got drive C:\  ** not CD Rom, type: 3  [cddaSCSIPassTru::FillDriveList]
                    Got drive D:\  CD ROM  [cddaSCSIPassTru::FillDriveList]
                    Got drive F:\  ** not CD Rom, type: 3  [cddaSCSIPassTru::FillDriveList]
                    Got drive H:\  ** not CD Rom, type: 3  [cddaSCSIPassTru::FillDriveList]
                    Got drive I:\  ** not CD Rom, type: 3  [cddaSCSIPassTru::FillDriveList]
                    Got drive K:\  ** not CD Rom, type: 2  [cddaSCSIPassTru::FillDriveList]
                    Got drive L:\  ** not CD Rom, type: 2  [cddaSCSIPassTru::FillDriveList]
                  <-<-  [clCDDA::ReturnDriveList]
                  ->->  [clCDDA::ReadTOC]
                    LBA FirstIndex: 0 last Index: 0
                      Type: Audio Track 0  LBA Address: 0
                    MSF FirstIndex: 0 last Index: 0
                      Type: Audio Track 0  MSF: 0/0/0
                  <-<-  [clCDDA::ReadTOC]
                <-<-  [frmMain::RefreshTrackListing]
                    LBA FirstIndex: 1 last Index: 13
                      Type: Audio Track 1  LBA Address: 0  Length: 00:03:18.973
                      Type: Audio Track 2  LBA Address: 14923  Length: 00:05:22.200
                      Type: Audio Track 3  LBA Address: 39088  Length: 00:03:08.667
                      Type: Audio Track 4  LBA Address: 53238  Length: 00:05:01.266
                      Type: Audio Track 5  LBA Address: 75833  Length: 00:03:55.467
                      Type: Audio Track 6  LBA Address: 93493  Length: 00:03:52.400
                      Type: Audio Track 7  LBA Address: 110923  Length: 00:03:04.427
                      Type: Audio Track 8  LBA Address: 124755  Length: 00:04:35.440
                      Type: Audio Track 9  LBA Address: 145413  Length: 00:05:52.600
                      Type: Audio Track 10  LBA Address: 171858  Length: 00:01:28.133
                      Type: Audio Track 11  LBA Address: 178468  Length: 00:02:11.667
                      Type: Audio Track 12  LBA Address: 188343  Length: 00:05:04.493
                      Type: Audio Track 13  LBA Address: 211180  Length: 00:03:23.440
                      Type: Lead Out  LBA Address: 226438
                    MSF FirstIndex: 1 last Index: 13
                      Type: Audio Track 1  MSF: 0/2/0  Length: 00:03:18.973
                      Type: Audio Track 2  MSF: 3/20/73  Length: 00:05:22.200
                      Type: Audio Track 3  MSF: 8/43/13  Length: 00:03:08.667
                      Type: Audio Track 4  MSF: 11/51/63  Length: 00:05:01.266
                      Type: Audio Track 5  MSF: 16/53/8  Length: 00:03:55.467
                      Type: Audio Track 6  MSF: 20/48/43  Length: 00:03:52.400
                      Type: Audio Track 7  MSF: 24/40/73  Length: 00:03:04.427
                      Type: Audio Track 8  MSF: 27/45/30  Length: 00:04:35.440
                      Type: Audio Track 9  MSF: 32/20/63  Length: 00:05:52.600
                      Type: Audio Track 10  MSF: 38/13/33  Length: 00:01:28.133
                      Type: Audio Track 11  MSF: 39/41/43  Length: 00:02:11.667
                      Type: Audio Track 12  MSF: 41/53/18  Length: 00:05:04.493
                      Type: Audio Track 13  MSF: 46/57/55  Length: 00:03:23.440
                      Type: Lead Out  MSF: 50/21/13
                  ->->  [frmMain::GetMeta]
                    ->->  [clMetaData::GetMetaData]
                      ->->  [clMetadBCache::GetMetaData]
                      <-<-  [clMetadBCache::GetMetaData]
                    <-<-  [clMetaData::GetMetaData]
                    ->->  [frmMain::MetaDataGot]
                      Meta Final Pass
                    <-<-  [frmMain::MetaDataGot]
                  <-<-  [frmMain::GetMeta]
                dBpoweramp Release 13.3 Digital Audio Extraction Log from Monday, May 18, 2009 8:16 PM
                Drive & Settings
                Pass 1 Drive Speed: Max,  Pass 2 Drive Speed: Max
                Extraction Log
                Ripping Method: Secure
                ->->  [clRipperSecure::Init]
                  ->->  [clCDDA::SetDriveSpeed]
                  <-<-  [clCDDA::SetDriveSpeed]
                <-<-  [clRipperSecure::Init]
                ->->  [clRipperSecure::MoveOntoNextStage]
                  4 frames marked bad. 4 new C2 errors detected.
                  ->->  [clCDDA::GetSupportedDriveSpeeds]
                  <-<-  [clCDDA::GetSupportedDriveSpeeds]
                <-<-  [clRipperSecure::MoveOntoNextStage]
                  5 frames marked bad. 1 new C2 errors detected.
                Re-rip Frame: 1123 (00:00:14.960) matched 10 / 12 [2 from passes]
                Re-rip Frame: 1124 (00:00:14.973) matched 10 / 12 [2 from passes]
                Re-rip Frame: 1607 (00:00:21.413) matched 10 / 11 [2 from passes]
                Re-rip Frame: 11336 (00:02:31.133) matched 10 / 11 [2 from passes]
                ->->  [clRipperSecure::InterpolateUnRecoverFrames]
                <-<-  [clRipperSecure::InterpolateUnRecoverFrames]
                Rip Exit By: Finish Bad Re-Read
                *** Information: Track 1:  Ripped LBA 0 to 14923 (3:18) in 1:22. Filename: F:\Redbook\Various Artists\TEST RIP\01 Eric Tingstad - Monongahela.flac
                *** Information:   AccurateRip: Inaccurate (confidence 1)   Insecure  [Pass 1, Ultra 1 to 1, Re-Rip 5 Frames]
                *** Information:   CRC32: 0C4D588F     AccurateRip CRC: 986AE7B2     [DiscID: 013-0018eea1-00f7d050-930bcb0d-1]
                *** Information:     Re-rip Frame: 1123 (00:00:14.960) matched 10 / 12
                *** Information:     Re-rip Frame: 1124 (00:00:14.973) matched 10 / 12
                *** Information:     Re-rip Frame: 1607 (00:00:21.413) matched 10 / 11
                *** Information:     Re-rip Frame: 7711 (00:01:42.800). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 11336 (00:02:31.133) matched 10 / 11
                *** Error: Track Ripped Insecurely.
                ->->  [clCDDA::Destroy]
                <-<-  [clCDDA::Destroy]
                  7 frames marked bad. 7 new C2 errors detected.
                  17 frames marked bad. 10 new C2 errors detected.
                Re-rip Frame: 18552 (00:00:48.373) matched 10 / 11 [2 from passes]
                Re-rip Frame: 18683 (00:00:50.120) matched 10 / 11 [2 from passes]
                Re-rip Frame: 19176 (00:00:56.693) matched 10 / 11 [2 from passes]
                Re-rip Frame: 20970 (00:01:20.613) matched 10 / 11 [2 from passes]
                Re-rip Frame: 25904 (00:02:26.400) matched 10 / 11 [2 from passes]
                Re-rip Frame: 25905 (00:02:26.413) matched 10 / 11 [2 from passes]
                Re-rip Frame: 29423 (00:03:13.320) matched 10 / 11 [2 from passes]
                Re-rip Frame: 30036 (00:03:21.493) matched 10 / 11 [2 from passes]
                Re-rip Frame: 30719 (00:03:30.600) matched 10 / 12 [2 from passes]
                Re-rip Frame: 30754 (00:03:31.066) matched 10 / 11 [2 from passes]
                Re-rip Frame: 32651 (00:03:56.360) matched 10 / 12 [2 from passes]
                Re-rip Frame: 33788 (00:04:11.520) matched 10 / 11 [2 from passes]
                Re-rip Frame: 34708 (00:04:23.786) matched 10 / 11 [2 from passes]
                Re-rip Frame: 36461 (00:04:47.160) matched 10 / 11 [2 from passes]
                *** Information: Track 2:  Ripped LBA 14923 to 39088 (5:22) in 1:33. Filename: F:\Redbook\Various Artists\TEST RIP\02 David L. White - Barcelona.flac
                *** Information:   AccurateRip: Inaccurate (confidence 1)   Insecure  [Pass 1, Ultra 1 to 1, Re-Rip 17 Frames]
                *** Information:   CRC32: A0B04C2B     AccurateRip CRC: 47FAAC1E     [DiscID: 013-0018eea1-00f7d050-930bcb0d-2]
                *** Information:     Re-rip Frame: 18552 (00:00:48.373) matched 10 / 11
                *** Information:     Re-rip Frame: 18683 (00:00:50.120) matched 10 / 11
                *** Information:     Re-rip Frame: 19176 (00:00:56.693) matched 10 / 11
                *** Information:     Re-rip Frame: 20970 (00:01:20.613) matched 10 / 11
                *** Information:     Re-rip Frame: 25904 (00:02:26.400) matched 10 / 11
                *** Information:     Re-rip Frame: 25905 (00:02:26.413) matched 10 / 11
                *** Information:     Re-rip Frame: 29274 (00:03:11.333). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 29276 (00:03:11.360). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 29423 (00:03:13.320) matched 10 / 11
                *** Information:     Re-rip Frame: 30036 (00:03:21.493) matched 10 / 11
                *** Information:     Re-rip Frame: 30719 (00:03:30.600) matched 10 / 12
                *** Information:     Re-rip Frame: 30754 (00:03:31.066) matched 10 / 11
                *** Information:     Re-rip Frame: 32651 (00:03:56.360) matched 10 / 12
                *** Information:     Re-rip Frame: 33788 (00:04:11.520) matched 10 / 11
                *** Information:     Re-rip Frame: 33858 (00:04:12.453). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 34708 (00:04:23.786) matched 10 / 11
                *** Information:     Re-rip Frame: 36461 (00:04:47.160) matched 10 / 11
                  1 frames marked bad. 1 new C2 errors detected.
                Rip Exit By: MoveOntoNextStage
                *** Information: Track 3:  Ripped LBA 39088 to 53238 (3:08) in 0:14. Filename: F:\Redbook\Various Artists\TEST RIP\03 Martin Kolbe - Bye Bye Lullaby.flac
                *** Information:   AccurateRip: Accurate (confidence 1)     [Pass 1]
                *** Information:   CRC32: 69A1813A     AccurateRip CRC: 7D480A63     [DiscID: 013-0018eea1-00f7d050-930bcb0d-3]
                  6 frames marked bad. 2 new C2 errors detected.
                Re-rip Frame: 62342 (00:02:01.373) matched 10 / 11 [2 from passes]
                Re-rip Frame: 66874 (00:03:01.800) matched 10 / 11 [2 from passes]
                Re-rip Frame: 68699 (00:03:26.133) matched 10 / 11 [2 from passes]
                *** Information: Track 4:  Ripped LBA 53238 to 75833 (5:01) in 1:14. Filename: F:\Redbook\Various Artists\TEST RIP\04 William Ellwood - Light a Candle.flac
                *** Information:   AccurateRip: Inaccurate (confidence 1)   Insecure  [Pass 1, Ultra 1 to 1, Re-Rip 6 Frames]
                *** Information:   CRC32: BE7FB8E5     AccurateRip CRC: 9BEB6977     [DiscID: 013-0018eea1-00f7d050-930bcb0d-4]
                *** Information:     Re-rip Frame: 60686 (00:01:39.293). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 62342 (00:02:01.373) matched 10 / 11
                *** Information:     Re-rip Frame: 66192 (00:02:52.706). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 66874 (00:03:01.800) matched 10 / 11
                *** Information:     Re-rip Frame: 68699 (00:03:26.133) matched 10 / 11
                *** Information:     Re-rip Frame: 70838 (00:03:54.653). Insecure  (c2 dropped 100)
                ->->  [clCPUEncoder::WriteAccRipCRCTags]
                  ->->  [cldBCodecHandler::FindDecoder]
                      Checking Decoder 'C:\Program Files\Illustrate\dBpoweramp\decoder\FLAC.dll' for extension '.flac'
                Decodes  [clDecoder::Get]
                    <<< Match, using decoder
                    Using Registry Cached Decoder: C:\Program Files\Illustrate\dBpoweramp\decoder\FLAC.dll
                ->->  [clDecoder::Close]
                <-<-  [clDecoder::Close]
                  <-<-  [cldBCodecHandler::FindDecoder]
                IDTags  [clDecoder::Set]
                ->->  [clDecoder::WriteIDTags]
                  Opening file 'F:\Redbook\Various Artists\TEST RIP\03 Martin Kolbe - Bye Bye Lullaby.flac' for write access: Opened
                  ->->  [clDecoder::Open]
                    Opening file 'F:\Redbook\Various Artists\TEST RIP\03 Martin Kolbe - Bye Bye Lullaby.flac' for read access: Opened
                    Init FLAC:
                    Reading Meta Data:
                     contained 22 tags:
                			Title: Bye Bye Lullaby
                			Year: 1992
                			Composer: Martin Kolbe
                			Label: Narada
                			UPC: 083616103228
                			Style: Modern Creative
                Ethnic Fusion
                Post-Bop
                Free Jazz
                Celtic Fusion
                Contemporary Celtic
                Meditation
                Neo-Classical
                Chamber Jazz
                Solo Instrumental
                Adult Alternative
                Contemporary Instrumental
                			Album: TEST RIP
                			Genre: Acoustic Guitar
                			Artist: Martin Kolbe
                			Rating: 5
                			Compilation: 1
                			Source: CD (Lossless)
                			Length: 188666
                			_cdtoc: DATA Length: 116   p.................:K
                			CDDB Disc ID: 930BCB0D
                			Encoded By: dBpoweramp Release 13.3
                			Encoder: FLAC 1.2.1
                			Encoder Settings: -compression-level-7 -verify
                			replaygain_track_gain: +1.7 dB
                			replaygain_track_peak: 0.851746
                			Track: 3/13
                			Disc: 1/1
                    Contains picture block, size (bytes): 51451 type: 3
                    ->->  [clDecoder::ReadIDTags]
                    <-<-  [clDecoder::ReadIDTags]
                  <-<-  [clDecoder::Open]
                <-<-  [clDecoder::WriteIDTags]
                <-<-  [clCPUEncoder::WriteAccRipCRCTags]
                  11 frames marked bad. 4 new C2 errors detected.
                Re-rip Frame: 78472 (00:00:35.173) matched 10 / 11 [2 from passes]
                Re-rip Frame: 79433 (00:00:47.986) matched 10 / 11 [2 from passes]
                Re-rip Frame: 88644 (00:02:50.800) matched 10 / 11 [2 from passes]
                Re-rip Frame: 89480 (00:03:01.946) matched 10 / 11 [2 from passes]
                Re-rip Frame: 91692 (00:03:31.440) matched 10 / 12 [2 from passes]
                *** Information: Track 5:  Ripped LBA 75833 to 93493 (3:55) in 1:04. Filename: F:\Redbook\Various Artists\TEST RIP\05 Ralf Illenberger - Inner Movement.flac
                *** Information:   AccurateRip: Inaccurate (confidence 1)   Insecure  [Pass 1, Ultra 1 to 1, Re-Rip 11 Frames]
                *** Information:   CRC32: 1D6E2979     AccurateRip CRC: D3E63737     [DiscID: 013-0018eea1-00f7d050-930bcb0d-5]
                *** Information:     Re-rip Frame: 78290 (00:00:32.746). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 78472 (00:00:35.173) matched 10 / 11
                *** Information:     Re-rip Frame: 78901 (00:00:40.893). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 78902 (00:00:40.906). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 79433 (00:00:47.986) matched 10 / 11
                *** Information:     Re-rip Frame: 87024 (00:02:29.200). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 87941 (00:02:41.426). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 88644 (00:02:50.800) matched 10 / 11
                *** Information:     Re-rip Frame: 89480 (00:03:01.946) matched 10 / 11
                *** Information:     Re-rip Frame: 90504 (00:03:15.600). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 91692 (00:03:31.440) matched 10 / 12
                  12 frames marked bad. 12 new C2 errors detected.
                  20 frames marked bad. 8 new C2 errors detected.
                Re-rip Frame: 94941 (00:00:19.293) matched 10 / 11 [2 from passes]
                Re-rip Frame: 95484 (00:00:26.533). Insecure  (c2 dropped 100)
                Re-rip Frame: 98162 (00:01:02.240) matched 10 / 11 [2 from passes]
                Re-rip Frame: 101146 (00:01:42.026) matched 10 / 11 [2 from passes]
                Re-rip Frame: 101578 (00:01:47.786) matched 10 / 11 [2 from passes]
                Re-rip Frame: 105842 (00:02:44.640) matched 10 / 11 [2 from passes]
                Re-rip Frame: 105872 (00:02:45.040). Insecure  (c2 dropped 100)
                Re-rip Frame: 106552 (00:02:54.106) matched 10 / 11 [2 from passes]
                Re-rip Frame: 107614 (00:03:08.266) matched 10 / 11 [2 from passes]
                Re-rip Frame: 110050 (00:03:40.746). Insecure  (c2 dropped 100)
                Re-rip Frame: 110829 (00:03:51.133) matched 10 / 10 [2 from passes]
                *** Information: Track 6:  Ripped LBA 93493 to 110923 (3:52) in 1:19. Filename: F:\Redbook\Various Artists\TEST RIP\06 Sheldon Mirowitz - Leaving Home.flac
                *** Information:   AccurateRip: Inaccurate (confidence 1)   Insecure  [Pass 1, Ultra 1 to 1, Re-Rip 20 Frames]
                *** Information:   CRC32: 8242F181     AccurateRip CRC: AAB44710     [DiscID: 013-0018eea1-00f7d050-930bcb0d-6]
                *** Information:     Re-rip Frame: 94605 (00:00:14.813). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 94941 (00:00:19.293) matched 10 / 11
                *** Information:     Re-rip Frame: 95484 (00:00:26.533). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 95498 (00:00:26.720). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 95527 (00:00:27.106). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 98162 (00:01:02.240) matched 10 / 11
                *** Information:     Re-rip Frame: 101146 (00:01:42.026) matched 10 / 11
                *** Information:     Re-rip Frame: 101535 (00:01:47.213). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 101578 (00:01:47.786) matched 10 / 11
                *** Information:     Re-rip Frame: 102596 (00:02:01.360). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 102670 (00:02:02.346). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 105842 (00:02:44.640) matched 10 / 11
                *** Information:     Re-rip Frame: 105871 (00:02:45.026). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 105872 (00:02:45.040). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 106220 (00:02:49.680). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 106552 (00:02:54.106) matched 10 / 11
                *** Information:     Re-rip Frame: 107614 (00:03:08.266) matched 10 / 11
                *** Information:     Re-rip Frame: 108284 (00:03:17.200). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 110050 (00:03:40.746). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 110829 (00:03:51.133) matched 10 / 10
                  22 frames marked bad. 22 new C2 errors detected.
                  28 frames marked bad. 6 new C2 errors detected.
                Re-rip Frame: 112761 (00:00:24.493) matched 10 / 11 [2 from passes]
                Re-rip Frame: 114059 (00:00:41.800) matched 10 / 11 [2 from passes]
                Re-rip Frame: 114675 (00:00:50.013) matched 10 / 11 [2 from passes]
                Re-rip Frame: 115838 (00:01:05.520). Insecure  (c2 dropped 100)
                Re-rip Frame: 116273 (00:01:11.320). Insecure  (c2 dropped 100)
                Re-rip Frame: 117375 (00:01:26.013) matched 10 / 11 [2 from passes]
                Re-rip Frame: 118091 (00:01:35.560). Insecure  (c2 dropped 100)
                Re-rip Frame: 118294 (00:01:38.266). Insecure  (c2 dropped 100)
                Re-rip Frame: 119216 (00:01:50.560). Insecure  (c2 dropped 100)
                Re-rip Frame: 119702 (00:01:57.040). Insecure  (c2 dropped 100)
                Re-rip Frame: 121065 (00:02:15.213) matched 10 / 11 [2 from passes]
                Re-rip Frame: 121318 (00:02:18.586). Insecure  (c2 dropped 100)
                Re-rip Frame: 121789 (00:02:24.866) matched 10 / 11 [2 from passes]
                Re-rip Frame: 121805 (00:02:25.080) matched 10 / 11 [2 from passes]
                Re-rip Frame: 123021 (00:02:41.293) matched 10 / 11 [2 from passes]
                *** Information: Track 7:  Ripped LBA 110923 to 124755 (3:04) in 1:18. Filename: F:\Redbook\Various Artists\TEST RIP\07 Simon Wyberg - Nocturne Mariah's Watermill.flac
                *** Information:   AccurateRip: Inaccurate (confidence 1)   Insecure  [Pass 1, Ultra 1 to 1, Re-Rip 28 Frames]
                *** Information:   CRC32: 7514C4D5     AccurateRip CRC: F759EF60     [DiscID: 013-0018eea1-00f7d050-930bcb0d-7]
                *** Information:     Re-rip Frame: 111659 (00:00:09.800). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 112761 (00:00:24.493) matched 10 / 11
                *** Information:     Re-rip Frame: 114059 (00:00:41.800) matched 10 / 11
                *** Information:     Re-rip Frame: 114645 (00:00:49.613). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 114660 (00:00:49.813). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 114675 (00:00:50.013) matched 10 / 11
                *** Information:     Re-rip Frame: 115838 (00:01:05.520). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 116242 (00:01:10.906). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 116273 (00:01:11.320). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 116365 (00:01:12.546). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 116380 (00:01:12.746). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 117375 (00:01:26.013) matched 10 / 11
                *** Information:     Re-rip Frame: 118091 (00:01:35.560). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 118294 (00:01:38.266). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 119216 (00:01:50.560). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 119499 (00:01:54.333). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 119702 (00:01:57.040). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 120093 (00:02:02.253). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 120861 (00:02:12.493). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 121065 (00:02:15.213) matched 10 / 11
                *** Information:     Re-rip Frame: 121318 (00:02:18.586). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 121380 (00:02:19.413). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 121758 (00:02:24.453). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 121789 (00:02:24.866) matched 10 / 11
                *** Information:     Re-rip Frame: 121805 (00:02:25.080) matched 10 / 11
                *** Information:     Re-rip Frame: 123021 (00:02:41.293) matched 10 / 11
                *** Information:     Re-rip Frame: 123051 (00:02:41.693). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 123922 (00:02:53.306). Insecure  (c2 dropped 100)
                  35 frames marked bad. 13 new C2 errors detected.
                Re-rip Frame: 124999 (00:00:03.240). Insecure  (c2 dropped 100)
                Re-rip Frame: 127674 (00:00:38.906) matched 10 / 11 [2 from passes]
                Re-rip Frame: 127756 (00:00:40.000) matched 10 / 11 [2 from passes]
                Re-rip Frame: 127787 (00:00:40.413). Insecure  (c2 dropped 100)
                Re-rip Frame: 129547 (00:01:03.880) matched 10 / 11 [2 from passes]
                Re-rip Frame: 130239 (00:01:13.106) matched 10 / 12 [2 from passes]
                Re-rip Frame: 131203 (00:01:25.960) matched 10 / 11 [2 from passes]
                Re-rip Frame: 133498 (00:01:56.560). Insecure  (c2 dropped 100)
                Re-rip Frame: 135824 (00:02:27.573). Insecure  (c2 dropped 100)
                Re-rip Frame: 136083 (00:02:31.026). Insecure  (c2 dropped 100)
                Re-rip Frame: 136084 (00:02:31.040) matched 10 / 10 [2 from passes]
                Re-rip Frame: 136312 (00:02:34.080) matched 10 / 11 [2 from passes]
                Re-rip Frame: 136622 (00:02:38.213) matched 10 / 11 [2 from passes]
                Re-rip Frame: 137275 (00:02:46.920) matched 10 / 11 [2 from passes]
                Re-rip Frame: 137683 (00:02:52.360) matched 10 / 11 [2 from passes]
                Re-rip Frame: 138010 (00:02:56.720) matched 10 / 11 [2 from passes]
                Re-rip Frame: 139456 (00:03:16.000) matched 10 / 11 [2 from passes]
                Re-rip Frame: 139586 (00:03:17.733) matched 10 / 11 [2 from passes]
                Re-rip Frame: 142305 (00:03:53.986). Insecure  (c2 dropped 100)
                Re-rip Frame: 143414 (00:04:08.773) matched 10 / 11 [2 from passes]
                Re-rip Frame: 144345 (00:04:21.186) matched 10 / 11 [2 from passes]
                Re-rip Frame: 144842 (00:04:27.813) matched 10 / 11 [2 from passes]
                Re-rip Frame: 144843 (00:04:27.826) matched 10 / 11 [2 from passes]
                *** Information: Track 8:  Ripped LBA 124755 to 145413 (4:35) in 1:39. Filename: F:\Redbook\Various Artists\TEST RIP\08 Simon Wynberg - Mariah's Watermill.flac
                *** Information:   AccurateRip: Inaccurate (confidence 1)   Insecure  [Pass 1, Ultra 1 to 1, Re-Rip 35 Frames]
                *** Information:   CRC32: 169D077B     AccurateRip CRC: 6AE70EDE     [DiscID: 013-0018eea1-00f7d050-930bcb0d-8]
                *** Information:     Re-rip Frame: 124999 (00:00:03.240). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 127674 (00:00:38.906) matched 10 / 11
                *** Information:     Re-rip Frame: 127756 (00:00:40.000) matched 10 / 11
                *** Information:     Re-rip Frame: 127787 (00:00:40.413). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 128649 (00:00:51.906). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 129547 (00:01:03.880) matched 10 / 11
                *** Information:     Re-rip Frame: 130239 (00:01:13.106) matched 10 / 12
                *** Information:     Re-rip Frame: 131203 (00:01:25.960) matched 10 / 11
                *** Information:     Re-rip Frame: 133094 (00:01:51.173). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 133498 (00:01:56.560). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 135824 (00:02:27.573). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 136083 (00:02:31.026). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 136084 (00:02:31.040) matched 10 / 10
                *** Information:     Re-rip Frame: 136098 (00:02:31.226). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 136312 (00:02:34.080) matched 10 / 11
                *** Information:     Re-rip Frame: 136622 (00:02:38.213) matched 10 / 11
                *** Information:     Re-rip Frame: 136655 (00:02:38.653). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 137275 (00:02:46.920) matched 10 / 11
                *** Information:     Re-rip Frame: 137683 (00:02:52.360) matched 10 / 11
                *** Information:     Re-rip Frame: 137977 (00:02:56.280). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 138010 (00:02:56.720) matched 10 / 11
                *** Information:     Re-rip Frame: 139456 (00:03:16.000) matched 10 / 11
                *** Information:     Re-rip Frame: 139586 (00:03:17.733) matched 10 / 11
                *** Information:     Re-rip Frame: 140160 (00:03:25.386). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 140590 (00:03:31.120). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 141149 (00:03:38.573). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 141596 (00:03:44.533). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 142305 (00:03:53.986). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 143414 (00:04:08.773) matched 10 / 11
                *** Information:     Re-rip Frame: 144047 (00:04:17.213). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 144264 (00:04:20.106). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 144345 (00:04:21.186) matched 10 / 11
                *** Information:     Re-rip Frame: 144527 (00:04:23.613). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 144842 (00:04:27.813) matched 10 / 11
                *** Information:     Re-rip Frame: 144843 (00:04:27.826) matched 10 / 11
                  45 frames marked bad. 45 new C2 errors detected.
                  59 frames marked bad. 14 new C2 errors detected.
                Re-rip Frame: 146511 (00:00:14.626) matched 10 / 11 [2 from passes]
                Re-rip Frame: 146993 (00:00:21.053) matched 10 / 11 [2 from passes]
                Re-rip Frame: 148117 (00:00:36.040) matched 10 / 12 [2 from passes]
                Re-rip Frame: 148605 (00:00:42.546). Insecure  (c2 dropped 100)
                Re-rip Frame: 151868 (00:01:26.053) matched 10 / 11 [2 from passes]
                Re-rip Frame: 151904 (00:01:26.533) matched 10 / 11 [2 from passes]
                Re-rip Frame: 151988 (00:01:27.653) matched 10 / 11 [2 from passes]
                Re-rip Frame: 153087 (00:01:42.306) matched 10 / 11 [2 from passes]
                Re-rip Frame: 154088 (00:01:55.653). Insecure  (c2 dropped 100)
                Re-rip Frame: 154139 (00:01:56.333) matched 10 / 11 [2 from passes]
                Re-rip Frame: 154495 (00:02:01.080) matched 10 / 11 [2 from passes]
                Re-rip Frame: 155022 (00:02:08.106) matched 10 / 11 [2 from passes]
                Re-rip Frame: 155584 (00:02:15.600) matched 10 / 11 [2 from passes]
                Re-rip Frame: 157082 (00:02:35.573) matched 10 / 12 [2 from passes]
                Re-rip Frame: 158934 (00:03:00.266) matched 10 / 11 [2 from passes]
                Re-rip Frame: 159103 (00:03:02.520). Insecure  (c2 dropped 100)
                Re-rip Frame: 160583 (00:03:22.253). Insecure  (c2 dropped 100)
                Re-rip Frame: 163084 (00:03:55.600). Insecure  (c2 dropped 100)
                Re-rip Frame: 163103 (00:03:55.853) matched 10 / 11 [2 from passes]
                Re-rip Frame: 163501 (00:04:01.160) matched 10 / 11 [2 from passes]
                Re-rip Frame: 163502 (00:04:01.173). Insecure  (c2 dropped 100)
                Re-rip Frame: 165252 (00:04:24.506) matched 10 / 11 [2 from passes]
                Re-rip Frame: 165809 (00:04:31.933) matched 10 / 11 [2 from passes]
                Re-rip Frame: 167746 (00:04:57.760). Insecure  (c2 dropped 100)
                Re-rip Frame: 168023 (00:05:01.453) matched 10 / 12 [2 from passes]
                Re-rip Frame: 168793 (00:05:11.720) matched 10 / 11 [2 from passes]
                Re-rip Frame: 169092 (00:05:15.706) matched 10 / 11 [2 from passes]
                Re-rip Frame: 169480 (00:05:20.880) matched 10 / 11 [2 from passes]
                Re-rip Frame: 169674 (00:05:23.466) matched 10 / 11 [2 from passes]
                *** Information: Track 9:  Ripped LBA 145413 to 171858 (5:52) in 2:25. Filename: F:\Redbook\Various Artists\TEST RIP\09 Nando Lauria - Sonho (Dream).flac
                *** Information:   AccurateRip: Inaccurate (confidence 1)   Insecure  [Pass 1, Ultra 1 to 1, Re-Rip 59 Frames]
                *** Information:   CRC32: 557202B6     AccurateRip CRC: A7969280     [DiscID: 013-0018eea1-00f7d050-930bcb0d-9]
                *** Information:     Re-rip Frame: 145996 (00:00:07.760). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 146511 (00:00:14.626) matched 10 / 11
                *** Information:     Re-rip Frame: 146993 (00:00:21.053) matched 10 / 11
                *** Information:     Re-rip Frame: 148117 (00:00:36.040) matched 10 / 12
                *** Information:     Re-rip Frame: 148534 (00:00:41.600). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 148605 (00:00:42.546). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 149727 (00:00:57.506). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 150890 (00:01:13.013). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 150924 (00:01:13.466). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 151868 (00:01:26.053) matched 10 / 11
                *** Information:     Re-rip Frame: 151887 (00:01:26.306). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 151904 (00:01:26.533) matched 10 / 11
                *** Information:     Re-rip Frame: 151988 (00:01:27.653) matched 10 / 11
                *** Information:     Re-rip Frame: 152104 (00:01:29.200). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 152646 (00:01:36.426). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 153087 (00:01:42.306) matched 10 / 11
                *** Information:     Re-rip Frame: 154088 (00:01:55.653). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 154139 (00:01:56.333) matched 10 / 11
                *** Information:     Re-rip Frame: 154408 (00:01:59.920). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 154495 (00:02:01.080) matched 10 / 11
                *** Information:     Re-rip Frame: 154854 (00:02:05.866). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 155022 (00:02:08.106) matched 10 / 11
                *** Information:     Re-rip Frame: 155192 (00:02:10.373). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 155210 (00:02:10.613). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 155398 (00:02:13.120). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 155550 (00:02:15.146). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 155567 (00:02:15.373). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 155584 (00:02:15.600) matched 10 / 11
                *** Information:     Re-rip Frame: 155618 (00:02:16.053). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 156042 (00:02:21.706). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 157082 (00:02:35.573) matched 10 / 12
                *** Information:     Re-rip Frame: 158934 (00:03:00.266) matched 10 / 11
                *** Information:     Re-rip Frame: 158951 (00:03:00.493). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 159103 (00:03:02.520). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 159671 (00:03:10.093). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 159810 (00:03:11.946). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 160583 (00:03:22.253). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 162203 (00:03:43.853). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 163033 (00:03:54.920). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 163084 (00:03:55.600). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 163103 (00:03:55.853) matched 10 / 11
                *** Information:     Re-rip Frame: 163501 (00:04:01.160) matched 10 / 11
                *** Information:     Re-rip Frame: 163502 (00:04:01.173). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 165252 (00:04:24.506) matched 10 / 11
                *** Information:     Re-rip Frame: 165809 (00:04:31.933) matched 10 / 11
                *** Information:     Re-rip Frame: 166332 (00:04:38.906). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 166856 (00:04:45.893). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 166890 (00:04:46.346). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 167746 (00:04:57.760). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 168023 (00:05:01.453) matched 10 / 12
                *** Information:     Re-rip Frame: 168463 (00:05:07.320). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 168793 (00:05:11.720) matched 10 / 11
                *** Information:     Re-rip Frame: 169092 (00:05:15.706) matched 10 / 11
                *** Information:     Re-rip Frame: 169480 (00:05:20.880) matched 10 / 11
                *** Information:     Re-rip Frame: 169674 (00:05:23.466) matched 10 / 11
                *** Information:     Re-rip Frame: 170972 (00:05:40.773). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 171076 (00:05:42.160). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 171500 (00:05:47.813). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 171619 (00:05:49.400). Insecure  (c2 dropped 100)
                  15 frames marked bad. 15 new C2 errors detected.
                  20 frames marked bad. 5 new C2 errors detected.
                Re-rip Frame: 172273 (00:00:05.520) matched 10 / 11 [2 from passes]
                Re-rip Frame: 172274 (00:00:05.533) matched 10 / 11 [2 from passes]
                Re-rip Frame: 172326 (00:00:06.226) matched 10 / 11 [2 from passes]
                Re-rip Frame: 173087 (00:00:16.373). Insecure  (c2 dropped 100)
                Re-rip Frame: 173193 (00:00:17.786) matched 10 / 11 [2 from passes]
                Re-rip Frame: 174927 (00:00:40.906). Insecure  (c2 dropped 100)
                Re-rip Frame: 175123 (00:00:43.520). Insecure  (c2 dropped 100)
                Re-rip Frame: 175777 (00:00:52.240) matched 10 / 11 [2 from passes]
                Re-rip Frame: 175795 (00:00:52.480). Insecure  (c2 dropped 100)
                Re-rip Frame: 176790 (00:01:05.746). Insecure  (c2 dropped 100)
                Re-rip Frame: 177504 (00:01:15.266) matched 10 / 11 [2 from passes]
                Re-rip Frame: 178412 (00:01:27.373). Insecure  (c2 dropped 100)
                *** Information: Track 10:  Ripped LBA 171858 to 178468 (1:28) in 0:54. Filename: F:\Redbook\Various Artists\TEST RIP\10 Sheldon Mirowitz - Since You Asked.flac
                *** Information:   CRC32: D4FEC960     AccurateRip CRC: 892121FF     [DiscID: 013-0018eea1-00f7d050-930bcb0d-10]
                *** Information:     Re-rip Frame: 172152 (00:00:03.906). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 172203 (00:00:04.586). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 172273 (00:00:05.520) matched 10 / 11
                *** Information:     Re-rip Frame: 172274 (00:00:05.533) matched 10 / 11
                *** Information:     Re-rip Frame: 172326 (00:00:06.226) matched 10 / 11
                *** Information:     Re-rip Frame: 173087 (00:00:16.373). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 173193 (00:00:17.786) matched 10 / 11
                *** Information:     Re-rip Frame: 174927 (00:00:40.906). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 174962 (00:00:41.373). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 175123 (00:00:43.520). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 175777 (00:00:52.240) matched 10 / 11
                *** Information:     Re-rip Frame: 175795 (00:00:52.480). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 176096 (00:00:56.493). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 176523 (00:01:02.186). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 176790 (00:01:05.746). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 176862 (00:01:06.706). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 177323 (00:01:12.853). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 177504 (00:01:15.266) matched 10 / 11
                *** Information:     Re-rip Frame: 178394 (00:01:27.133). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 178412 (00:01:27.373). Insecure  (c2 dropped 100)
                  27 frames marked bad. 27 new C2 errors detected.
                  36 frames marked bad. 9 new C2 errors detected.
                Re-rip Frame: 178696 (00:00:03.026) matched 10 / 11 [2 from passes]
                Re-rip Frame: 179323 (00:00:11.386). Insecure  (c2 dropped 100)
                Re-rip Frame: 179771 (00:00:17.360). Insecure  (c2 dropped 100)
                Re-rip Frame: 180933 (00:00:32.853) matched 10 / 11 [2 from passes]
                Re-rip Frame: 181166 (00:00:35.960) matched 10 / 11 [2 from passes]
                Re-rip Frame: 181329 (00:00:38.133) matched 10 / 12 [2 from passes]
                Re-rip Frame: 182696 (00:00:56.360) matched 10 / 11 [2 from passes]
                Re-rip Frame: 182805 (00:00:57.813) matched 10 / 11 [2 from passes]
                Re-rip Frame: 182820 (00:00:58.013) matched 10 / 11 [2 from passes]
                Re-rip Frame: 183902 (00:01:12.440) matched 10 / 11 [2 from passes]
                Re-rip Frame: 184857 (00:01:25.173) matched 10 / 12 [2 from passes]
                Re-rip Frame: 184892 (00:01:25.640). Insecure  (c2 dropped 100)
                Re-rip Frame: 185490 (00:01:33.613) matched 10 / 11 [2 from passes]
                Re-rip Frame: 185997 (00:01:40.373) matched 10 / 12 [2 from passes]
                Re-rip Frame: 186667 (00:01:49.306) matched 10 / 11 [2 from passes]
                Re-rip Frame: 186850 (00:01:51.746) matched 10 / 11 [2 from passes]
                Re-rip Frame: 188175 (00:02:09.413) matched 10 / 10 [2 from passes]
                *** Information: Track 11:  Ripped LBA 178468 to 188343 (2:11) in 1:13. Filename: F:\Redbook\Various Artists\TEST RIP\11 Matthew Montfort - Amber.flac
                *** Information:   AccurateRip: Inaccurate (confidence 1)   Insecure  [Pass 1, Ultra 1 to 1, Re-Rip 36 Frames]
                *** Information:   CRC32: 2B2C956B     AccurateRip CRC: F4D8FD22     [DiscID: 013-0018eea1-00f7d050-930bcb0d-11]
                *** Information:     Re-rip Frame: 178696 (00:00:03.026) matched 10 / 11
                *** Information:     Re-rip Frame: 178998 (00:00:07.053). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 179092 (00:00:08.306). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 179323 (00:00:11.386). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 179375 (00:00:12.080). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 179771 (00:00:17.360). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 180933 (00:00:32.853) matched 10 / 11
                *** Information:     Re-rip Frame: 181078 (00:00:34.786). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 181166 (00:00:35.960) matched 10 / 11
                *** Information:     Re-rip Frame: 181329 (00:00:38.133) matched 10 / 12
                *** Information:     Re-rip Frame: 182642 (00:00:55.640). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 182696 (00:00:56.360) matched 10 / 11
                *** Information:     Re-rip Frame: 182805 (00:00:57.813) matched 10 / 11
                *** Information:     Re-rip Frame: 182820 (00:00:58.013) matched 10 / 11
                *** Information:     Re-rip Frame: 182875 (00:00:58.746). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 183630 (00:01:08.813). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 183648 (00:01:09.053). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 183666 (00:01:09.293). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 183902 (00:01:12.440) matched 10 / 11
                *** Information:     Re-rip Frame: 184462 (00:01:19.906). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 184857 (00:01:25.173) matched 10 / 12
                *** Information:     Re-rip Frame: 184874 (00:01:25.400). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 184875 (00:01:25.413). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 184892 (00:01:25.640). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 184893 (00:01:25.653). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 185490 (00:01:33.613) matched 10 / 11
                *** Information:     Re-rip Frame: 185491 (00:01:33.626). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 185997 (00:01:40.373) matched 10 / 12
                *** Information:     Re-rip Frame: 186037 (00:01:40.906). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 186217 (00:01:43.306). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 186218 (00:01:43.320). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 186251 (00:01:43.760). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 186667 (00:01:49.306) matched 10 / 11
                *** Information:     Re-rip Frame: 186850 (00:01:51.746) matched 10 / 11
                *** Information:     Re-rip Frame: 188103 (00:02:08.453). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 188175 (00:02:09.413) matched 10 / 10
                  86 frames marked bad. 41 new C2 errors detected.
                Re-rip Frame: 188432 (00:00:01.173) matched 10 / 12 [2 from passes]
                Re-rip Frame: 188484 (00:00:01.866) matched 10 / 11 [2 from passes]
                Re-rip Frame: 188704 (00:00:04.800) matched 10 / 11 [2 from passes]
                Re-rip Frame: 189011 (00:00:08.893) matched 10 / 12 [2 from passes]
                Re-rip Frame: 189177 (00:00:11.106) matched 10 / 12 [2 from passes]
                Re-rip Frame: 189359 (00:00:13.533) matched 10 / 11 [2 from passes]
                Re-rip Frame: 189832 (00:00:19.840). Insecure  (c2 dropped 100)
                Re-rip Frame: 190325 (00:00:26.413) matched 10 / 11 [2 from passes]
                Re-rip Frame: 190455 (00:00:28.146). Insecure  (c2 dropped 100)
                Re-rip Frame: 191240 (00:00:38.613) matched 10 / 11 [2 from passes]
                Re-rip Frame: 191313 (00:00:39.586) matched 10 / 12 [2 from passes]
                Re-rip Frame: 191607 (00:00:43.506) matched 10 / 11 [2 from passes]
                Re-rip Frame: 191768 (00:00:45.653) matched 10 / 11 [2 from passes]
                Re-rip Frame: 192230 (00:00:51.813) matched 10 / 11 [2 from passes]
                Re-rip Frame: 192357 (00:00:53.506) matched 10 / 11 [2 from passes]
                Re-rip Frame: 192358 (00:00:53.520) matched 10 / 11 [2 from passes]
                Re-rip Frame: 192394 (00:00:54.000) matched 10 / 12 [2 from passes]
                Re-rip Frame: 193072 (00:01:03.040) matched 10 / 11 [2 from passes]
                Re-rip Frame: 193255 (00:01:05.480) matched 10 / 12 [2 from passes]
                Re-rip Frame: 193900 (00:01:14.080) matched 10 / 12 [2 from passes]
                Re-rip Frame: 194139 (00:01:17.266). Insecure  (c2 dropped 100)
                Re-rip Frame: 194140 (00:01:17.280). Insecure  (c2 dropped 100)
                Re-rip Frame: 194211 (00:01:18.226) matched 10 / 11 [2 from passes]
                Re-rip Frame: 194580 (00:01:23.146) matched 10 / 11 [2 from passes]
                Re-rip Frame: 195702 (00:01:38.106) matched 10 / 12 [2 from passes]
                Re-rip Frame: 196719 (00:01:51.666) matched 10 / 11 [2 from passes]
                Re-rip Frame: 197051 (00:01:56.093) matched 10 / 11 [2 from passes]
                Re-rip Frame: 198329 (00:02:13.133) matched 10 / 11 [2 from passes]
                Re-rip Frame: 198366 (00:02:13.626) matched 10 / 11 [2 from passes]
                Re-rip Frame: 198903 (00:02:20.786) matched 10 / 11 [2 from passes]
                Re-rip Frame: 199182 (00:02:24.506) matched 10 / 11 [2 from passes]
                Re-rip Frame: 199867 (00:02:33.640). Insecure  (c2 dropped 100)
                Re-rip Frame: 199869 (00:02:33.666) matched 10 / 11 [2 from passes]
                Re-rip Frame: 200093 (00:02:36.653). Insecure  (c2 dropped 100)
                Re-rip Frame: 201263 (00:02:52.253) matched 10 / 11 [2 from passes]
                Re-rip Frame: 201338 (00:02:53.253) matched 10 / 11 [2 from passes]
                Re-rip Frame: 201582 (00:02:56.506) matched 10 / 11 [2 from passes]
                Re-rip Frame: 202982 (00:03:15.173) matched 10 / 11 [2 from passes]
                Re-rip Frame: 203001 (00:03:15.426). Insecure  (c2 dropped 100)
                Re-rip Frame: 203054 (00:03:16.133) matched 10 / 11 [2 from passes]
                Re-rip Frame: 203129 (00:03:17.133) matched 10 / 11 [2 from passes]
                Re-rip Frame: 203466 (00:03:21.626). Insecure  (c2 dropped 100)
                Re-rip Frame: 204046 (00:03:29.360). Insecure  (c2 dropped 100)
                Re-rip Frame: 204047 (00:03:29.373) matched 10 / 11 [2 from passes]
                Re-rip Frame: 204066 (00:03:29.626) matched 10 / 11 [2 from passes]
                Re-rip Frame: 204274 (00:03:32.400) matched 10 / 11 [2 from passes]
                Re-rip Frame: 205020 (00:03:42.346) matched 10 / 11 [2 from passes]
                Re-rip Frame: 205603 (00:03:50.120). Insecure  (c2 dropped 100)
                Re-rip Frame: 205638 (00:03:50.586) matched 10 / 11 [2 from passes]
                Re-rip Frame: 206056 (00:03:56.160) matched 10 / 11 [2 from passes]
                Re-rip Frame: 206994 (00:04:08.666) matched 10 / 11 [2 from passes]
                Re-rip Frame: 207917 (00:04:20.973) matched 10 / 11 [2 from passes]
                Re-rip Frame: 208048 (00:04:22.720) matched 10 / 11 [2 from passes]
                Re-rip Frame: 208161 (00:04:24.226) matched 10 / 11 [2 from passes]
                Re-rip Frame: 208235 (00:04:25.213) matched 10 / 11 [2 from passes]
                Re-rip Frame: 208236 (00:04:25.226) matched 10 / 11 [2 from passes]
                Re-rip Frame: 208934 (00:04:34.533) matched 10 / 11 [2 from passes]
                Re-rip Frame: 209444 (00:04:41.333) matched 10 / 11 [2 from passes]
                Re-rip Frame: 209745 (00:04:45.346) matched 10 / 11 [2 from passes]
                Re-rip Frame: 209783 (00:04:45.853). Insecure  (c2 dropped 100)
                Re-rip Frame: 209975 (00:04:48.413) matched 10 / 11 [2 from passes]
                Re-rip Frame: 210809 (00:04:59.533). Insecure  (c2 dropped 100)
                Re-rip Frame: 211092 (00:05:03.306) matched 10 / 10 [2 from passes]
                *** Information: Track 12:  Ripped LBA 188343 to 211180 (5:04) in 2:22. Filename: F:\Redbook\Various Artists\TEST RIP\12 John Doan - Remembering Greensleeves.flac
                *** Information:   AccurateRip: Inaccurate (confidence 1)   Insecure  [Pass 1, Ultra 1 to 1, Re-Rip 86 Frames]
                *** Information:   CRC32: 5F70D927     AccurateRip CRC: 464F362E     [DiscID: 013-0018eea1-00f7d050-930bcb0d-12]
                *** Information:     Re-rip Frame: 188414 (00:00:00.933). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 188432 (00:00:01.173) matched 10 / 12
                *** Information:     Re-rip Frame: 188466 (00:00:01.626). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 188484 (00:00:01.866) matched 10 / 11
                *** Information:     Re-rip Frame: 188704 (00:00:04.800) matched 10 / 11
                *** Information:     Re-rip Frame: 189011 (00:00:08.893) matched 10 / 12
                *** Information:     Re-rip Frame: 189177 (00:00:11.106) matched 10 / 12
                *** Information:     Re-rip Frame: 189359 (00:00:13.533) matched 10 / 11
                *** Information:     Re-rip Frame: 189832 (00:00:19.840). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 190325 (00:00:26.413) matched 10 / 11
                *** Information:     Re-rip Frame: 190455 (00:00:28.146). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 191205 (00:00:38.146). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 191206 (00:00:38.160). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 191240 (00:00:38.613) matched 10 / 11
                *** Information:     Re-rip Frame: 191313 (00:00:39.586) matched 10 / 12
                *** Information:     Re-rip Frame: 191607 (00:00:43.506) matched 10 / 11
                *** Information:     Re-rip Frame: 191768 (00:00:45.653) matched 10 / 11
                *** Information:     Re-rip Frame: 192230 (00:00:51.813) matched 10 / 11
                *** Information:     Re-rip Frame: 192357 (00:00:53.506) matched 10 / 11
                *** Information:     Re-rip Frame: 192358 (00:00:53.520) matched 10 / 11
                *** Information:     Re-rip Frame: 192394 (00:00:54.000) matched 10 / 12
                *** Information:     Re-rip Frame: 193072 (00:01:03.040) matched 10 / 11
                *** Information:     Re-rip Frame: 193091 (00:01:03.293). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 193255 (00:01:05.480) matched 10 / 12
                *** Information:     Re-rip Frame: 193657 (00:01:10.840). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 193900 (00:01:14.080) matched 10 / 12
                *** Information:     Re-rip Frame: 194139 (00:01:17.266). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 194140 (00:01:17.280). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 194211 (00:01:18.226) matched 10 / 11
                *** Information:     Re-rip Frame: 194580 (00:01:23.146) matched 10 / 11
                *** Information:     Re-rip Frame: 194581 (00:01:23.160). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 194582 (00:01:23.173). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 194616 (00:01:23.626). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 194689 (00:01:24.600). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 194800 (00:01:26.080). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 194986 (00:01:28.560). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 195702 (00:01:38.106) matched 10 / 12
                *** Information:     Re-rip Frame: 195995 (00:01:42.013). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 196719 (00:01:51.666) matched 10 / 11
                *** Information:     Re-rip Frame: 197051 (00:01:56.093) matched 10 / 11
                *** Information:     Re-rip Frame: 198329 (00:02:13.133) matched 10 / 11
                *** Information:     Re-rip Frame: 198366 (00:02:13.626) matched 10 / 11
                *** Information:     Re-rip Frame: 198903 (00:02:20.786) matched 10 / 11
                *** Information:     Re-rip Frame: 199182 (00:02:24.506) matched 10 / 11
                *** Information:     Re-rip Frame: 199386 (00:02:27.226). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 199867 (00:02:33.640). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 199869 (00:02:33.666) matched 10 / 11
                *** Information:     Re-rip Frame: 200093 (00:02:36.653). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 200202 (00:02:38.106). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 201263 (00:02:52.253) matched 10 / 11
                *** Information:     Re-rip Frame: 201338 (00:02:53.253) matched 10 / 11
                *** Information:     Re-rip Frame: 201582 (00:02:56.506) matched 10 / 11
                *** Information:     Re-rip Frame: 202513 (00:03:08.920). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 202982 (00:03:15.173) matched 10 / 11
                *** Information:     Re-rip Frame: 203001 (00:03:15.426). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 203054 (00:03:16.133) matched 10 / 11
                *** Information:     Re-rip Frame: 203129 (00:03:17.133) matched 10 / 11
                *** Information:     Re-rip Frame: 203131 (00:03:17.160). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 203149 (00:03:17.400). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 203466 (00:03:21.626). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 204046 (00:03:29.360). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 204047 (00:03:29.373) matched 10 / 11
                *** Information:     Re-rip Frame: 204066 (00:03:29.626) matched 10 / 11
                *** Information:     Re-rip Frame: 204274 (00:03:32.400) matched 10 / 11
                *** Information:     Re-rip Frame: 204552 (00:03:36.106). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 205020 (00:03:42.346) matched 10 / 11
                *** Information:     Re-rip Frame: 205432 (00:03:47.840). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 205603 (00:03:50.120). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 205638 (00:03:50.586) matched 10 / 11
                *** Information:     Re-rip Frame: 206056 (00:03:56.160) matched 10 / 11
                *** Information:     Re-rip Frame: 206204 (00:03:58.133). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 206994 (00:04:08.666) matched 10 / 11
                *** Information:     Re-rip Frame: 207917 (00:04:20.973) matched 10 / 11
                *** Information:     Re-rip Frame: 208048 (00:04:22.720) matched 10 / 11
                *** Information:     Re-rip Frame: 208085 (00:04:23.213). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 208161 (00:04:24.226) matched 10 / 11
                *** Information:     Re-rip Frame: 208235 (00:04:25.213) matched 10 / 11
                *** Information:     Re-rip Frame: 208236 (00:04:25.226) matched 10 / 11
                *** Information:     Re-rip Frame: 208934 (00:04:34.533) matched 10 / 11
                *** Information:     Re-rip Frame: 209009 (00:04:35.533). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 209444 (00:04:41.333) matched 10 / 11
                *** Information:     Re-rip Frame: 209745 (00:04:45.346) matched 10 / 11
                *** Information:     Re-rip Frame: 209783 (00:04:45.853). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 209975 (00:04:48.413) matched 10 / 11
                *** Information:     Re-rip Frame: 210809 (00:04:59.533). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 211092 (00:05:03.306) matched 10 / 10
                  29 frames marked bad. 29 new C2 errors detected.
                  59 frames marked bad. 30 new C2 errors detected.
                Re-rip Frame: 211566 (00:00:05.133) matched 10 / 11 [2 from passes]
                Re-rip Frame: 211623 (00:00:05.893). Insecure  (c2 dropped 100)
                Re-rip Frame: 211642 (00:00:06.146) matched 10 / 11 [2 from passes]
                Re-rip Frame: 211945 (00:00:10.186) matched 10 / 12 [2 from passes]
                Re-rip Frame: 213618 (00:00:32.493) matched 10 / 11 [2 from passes]
                Re-rip Frame: 213619 (00:00:32.506) matched 10 / 11 [2 from passes]
                Re-rip Frame: 214056 (00:00:38.333) matched 10 / 11 [2 from passes]
                Re-rip Frame: 214057 (00:00:38.346) matched 10 / 11 [2 from passes]
                Re-rip Frame: 214227 (00:00:40.613) matched 10 / 11 [2 from passes]
                Re-rip Frame: 214362 (00:00:42.413) matched 10 / 11 [2 from passes]
                Re-rip Frame: 214474 (00:00:43.906) matched 10 / 11 [2 from passes]
                Re-rip Frame: 215508 (00:00:57.693) matched 10 / 11 [2 from passes]
                Re-rip Frame: 216099 (00:01:05.573) matched 10 / 11 [2 from passes]
                Re-rip Frame: 216214 (00:01:07.106) matched 10 / 11 [2 from passes]
                Re-rip Frame: 217113 (00:01:19.093) matched 10 / 11 [2 from passes]
                Re-rip Frame: 217304 (00:01:21.640) matched 10 / 11 [2 from passes]
                Re-rip Frame: 217534 (00:01:24.706) matched 10 / 12 [2 from passes]
                Re-rip Frame: 218185 (00:01:33.386) matched 10 / 11 [2 from passes]
                Re-rip Frame: 218186 (00:01:33.400) matched 10 / 11 [2 from passes]
                Re-rip Frame: 219491 (00:01:50.800) matched 10 / 11 [2 from passes]
                Re-rip Frame: 219991 (00:01:57.466) matched 10 / 11 [2 from passes]
                Re-rip Frame: 219992 (00:01:57.480) matched 10 / 11 [2 from passes]
                Re-rip Frame: 220647 (00:02:06.213) matched 10 / 11 [2 from passes]
                Re-rip Frame: 220762 (00:02:07.746) matched 10 / 11 [2 from passes]
                Re-rip Frame: 221378 (00:02:15.960) matched 10 / 11 [2 from passes]
                Re-rip Frame: 221399 (00:02:16.240) matched 10 / 11 [2 from passes]
                Re-rip Frame: 222074 (00:02:25.240) matched 10 / 11 [2 from passes]
                Re-rip Frame: 222247 (00:02:27.546) matched 10 / 11 [2 from passes]
                Re-rip Frame: 222576 (00:02:31.933) matched 10 / 11 [2 from passes]
                Re-rip Frame: 222772 (00:02:34.546) matched 10 / 12 [2 from passes]
                Re-rip Frame: 223254 (00:02:40.973) matched 10 / 11 [2 from passes]
                Re-rip Frame: 223410 (00:02:43.053) matched 10 / 11 [2 from passes]
                Re-rip Frame: 223950 (00:02:50.253) matched 10 / 11 [2 from passes]
                Re-rip Frame: 224259 (00:02:54.373) matched 10 / 11 [2 from passes]
                Re-rip Frame: 224453 (00:02:56.960) matched 10 / 11 [2 from passes]
                Re-rip Frame: 224862 (00:03:02.413) matched 10 / 11 [2 from passes]
                Re-rip Frame: 225094 (00:03:05.506) matched 10 / 11 [2 from passes]
                Re-rip Frame: 225155 (00:03:06.320) matched 10 / 11 [2 from passes]
                Re-rip Frame: 226007 (00:03:17.680) matched 10 / 11 [2 from passes]
                *** Information: Track 13:  Ripped LBA 211180 to 226438 (3:23) in 1:26. Filename: F:\Redbook\Various Artists\TEST RIP\13 Martin Kolbe - Bye Bye Lullaby.flac
                *** Information:   CRC32: 1B674CAF     AccurateRip CRC: 06658175     [DiscID: 013-0018eea1-00f7d050-930bcb0d-13]
                *** Information:     Re-rip Frame: 211490 (00:00:04.120). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 211566 (00:00:05.133) matched 10 / 11
                *** Information:     Re-rip Frame: 211623 (00:00:05.893). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 211642 (00:00:06.146) matched 10 / 11
                *** Information:     Re-rip Frame: 211945 (00:00:10.186) matched 10 / 12
                *** Information:     Re-rip Frame: 212878 (00:00:22.626). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 213618 (00:00:32.493) matched 10 / 11
                *** Information:     Re-rip Frame: 213619 (00:00:32.506) matched 10 / 11
                *** Information:     Re-rip Frame: 214056 (00:00:38.333) matched 10 / 11
                *** Information:     Re-rip Frame: 214057 (00:00:38.346) matched 10 / 11
                *** Information:     Re-rip Frame: 214227 (00:00:40.613) matched 10 / 11
                *** Information:     Re-rip Frame: 214265 (00:00:41.120). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 214362 (00:00:42.413) matched 10 / 11
                *** Information:     Re-rip Frame: 214474 (00:00:43.906) matched 10 / 11
                *** Information:     Re-rip Frame: 214705 (00:00:46.986). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 214744 (00:00:47.506). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 215391 (00:00:56.133). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 215508 (00:00:57.693) matched 10 / 11
                *** Information:     Re-rip Frame: 215813 (00:01:01.760). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 216099 (00:01:05.573) matched 10 / 11
                *** Information:     Re-rip Frame: 216214 (00:01:07.106) matched 10 / 11
                *** Information:     Re-rip Frame: 217113 (00:01:19.093) matched 10 / 11
                *** Information:     Re-rip Frame: 217304 (00:01:21.640) matched 10 / 11
                *** Information:     Re-rip Frame: 217534 (00:01:24.706) matched 10 / 12
                *** Information:     Re-rip Frame: 218185 (00:01:33.386) matched 10 / 11
                *** Information:     Re-rip Frame: 218186 (00:01:33.400) matched 10 / 11
                *** Information:     Re-rip Frame: 219169 (00:01:46.506). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 219491 (00:01:50.800) matched 10 / 11
                *** Information:     Re-rip Frame: 219821 (00:01:55.200). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 219991 (00:01:57.466) matched 10 / 11
                *** Information:     Re-rip Frame: 219992 (00:01:57.480) matched 10 / 11
                *** Information:     Re-rip Frame: 220587 (00:02:05.413). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 220647 (00:02:06.213) matched 10 / 11
                *** Information:     Re-rip Frame: 220762 (00:02:07.746) matched 10 / 11
                *** Information:     Re-rip Frame: 220879 (00:02:09.306). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 221378 (00:02:15.960) matched 10 / 11
                *** Information:     Re-rip Frame: 221399 (00:02:16.240) matched 10 / 11
                *** Information:     Re-rip Frame: 221572 (00:02:18.546). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 222074 (00:02:25.240) matched 10 / 11
                *** Information:     Re-rip Frame: 222247 (00:02:27.546) matched 10 / 11
                *** Information:     Re-rip Frame: 222479 (00:02:30.640). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 222576 (00:02:31.933) matched 10 / 11
                *** Information:     Re-rip Frame: 222772 (00:02:34.546) matched 10 / 12
                *** Information:     Re-rip Frame: 223254 (00:02:40.973) matched 10 / 11
                *** Information:     Re-rip Frame: 223410 (00:02:43.053) matched 10 / 11
                *** Information:     Re-rip Frame: 223565 (00:02:45.120). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 223950 (00:02:50.253) matched 10 / 11
                *** Information:     Re-rip Frame: 224086 (00:02:52.066). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 224106 (00:02:52.333). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 224223 (00:02:53.893). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 224224 (00:02:53.906). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 224259 (00:02:54.373) matched 10 / 11
                *** Information:     Re-rip Frame: 224453 (00:02:56.960) matched 10 / 11
                *** Information:     Re-rip Frame: 224843 (00:03:02.160). Insecure  (c2 dropped 100)
                *** Information:     Re-rip Frame: 224862 (00:03:02.413) matched 10 / 11
                *** Information:     Re-rip Frame: 225094 (00:03:05.506) matched 10 / 11
                *** Information:     Re-rip Frame: 225155 (00:03:06.320) matched 10 / 11
                *** Information:     Re-rip Frame: 226007 (00:03:17.680) matched 10 / 11
                *** Information:     Re-rip Frame: 226261 (00:03:21.066). Insecure  (c2 dropped 100)
                13 Tracks Ripped: 1 Accurate, 12 Inaccurate
                ->->  [clMetaData::SaveMetaData]
                  ->->  [clMetadBCache::SaveMetaData]
                  <-<-  [clMetadBCache::SaveMetaData]
                <-<-  [clMetaData::SaveMetaData]
                ->->  [clCDDA::EjectCD]
                <-<-  [clCDDA::EjectCD]
                • ShrinerMonkey
                  • Apr 2009
                  • 17
                  #38
                  Re: Preventing Secure Rip Aborts
                  I am still watching this thread to see if this bug will get fixed as I am still suffering from it and have to say am also somewhat frustrated.
                  • pangit
                    • Mar 2009
                    • 17
                    #39
                    Thanks for editing my excessively long posts LtData - I will include the code tags in the future when posting logs. I don't use forums much and wasn't aware of their existence.
                    I'm watching this situation too - hopefully that last log I posted will allow Spoon to home in on the error.
                    • cubiq
                      • Jan 2007
                      Just to say I am also getting this problem and the beta doesn't fix it for me.
                      I also get the same with and without having C2 error checking.
                        • 44051
                        #41
                        We will be able to look at it again very shortly.
                        • cubiq
                          • Jan 2007
                          Any news on this, I'd really like to start a large ripping project but can't until this is fixed. This is actually the second time I have evaluated dbPowerAmp and in the end not bought it to a major bug (last time was v12).
                          • pangit
                            • Mar 2009
                            • 17
                            #43
                            I'm anxious for some news also... another beta... more testing.... something. :(
                            Cubiq, this may seem like a fatal flaw, but it's still excellent, powerful software overall. I'm still in the midst of an active, months-long ripping project and this bug hasn't stopped me for proceeding. Admittedly it has wasted a fair bit of my time, and caused more than a wee dram of frustration. If you have a multitude of scratched or otherwise damaged discs that are likely to give you grief, then yes, you may want to hold off, but otherwise the software is still usable and functional.
                            Just my $.02.
                            • cubiq
                              • Jan 2007
                              Yes I realise that, just the last time I did the same I ended up not knowing what didn't rip. Don't want to repeat.
                              Out of interest, in ultra secure mode, when I do repeated rips should I actually get the exact same number of frames that fail. I always get different, with and without C2 on. Varying the number of minimum matches doesn't get me any closer. Is this an indication that my DVD drive is just not up to scratch?
                              • pangit
                                • Mar 2009
                                • 17
                                #45
                                You could always turn on the logs if you want a detailed accounting of how the ripping went, but I realize that's a pain to have to check each one. Ideally it would just all work. You can also turn on either the option to abort an erroneous rip, or the DSP effect that moves a bad rip track to a directory of your choosing. With the latter, I made a directory called "bad rip" and then every so often I check to see if anything is in there. If so, I know exactly which tracks needed to be re-ripped.
                                I'm not experienced enough with the software to give qualified comment on whether your drive is up to the task, and I confess I've wondered the same thing about my drive. I've been planning at some point to buy one of the top Plextors in the list (http://forum.dbpoweramp.com/showthread.php?t=18088) and call it a day, just so I can stop worrying about it.
