Problem with my driver Pioneer DCR-102
  • CaiXBo
    • Jan 2009
    I can't find this driver in Offsets List and I only have 1 key disc.:cry:
    Please tell me how to fix the read/write sample offset correction of EAC.
    THX!
    Re: Problem with my driver Pioneer DCR-102
    You have to discover it using multiple Key discs...
      Just keep feeding it popular discs until it asks to configure. If the drive is not in the offset list, you will have to keep putting in discs until it finds 3 matching offsets.
      • CaiXBo
        • Jan 2009
        Thanks to all above!
        I had tried all CDs, finally I found 3 of burnt CDs (SONY CD-R, using NERO or Alcohol 120%) can be used.
        AccurateRip:
        CD Drive Type: PIONEER - DCR-102
        Expected Offset: Unknown Drive
        I clicked "Configure" button.
        Result [Calculated offset value: +0 samples, +0 bytes.]
        PS: the "Calculated offset value" of the other CDs, even the genuine CDs, I had inserted are different.
        Second,
        Expected Offset: Previous my offset [+0 samples]
        The result was the same.
        When I finished, "Use AccurateRip with this drive" in drive option can be used, EAC give the value "0".
        Is my drive's offset value perfect that I don't need to configure it?:(
        Today I've tried another way to detect the value. I burnt an offset test CD using EAC to test another drive "HL-DT-STCD-ROM GCR-8521B", its offset value is "-24" found in AccurateRip's list. I had burnt for several times to test it until the value is "-24", when the Write samples offset of PIONEER GCR-102 I set is "-6".
        I think it is the correct value for my drive, so that I've tried on the other drives:
        MSI DVD-ROM 16X "+738"
        aigo bdv316g c007 "+6"
        Same as the list. Then I used this test CD to test GCR-102, received "+6". Is that the corrent value? Why different from AccurateRip? Please tell which I should use, thx!
          You cannot use CD-Rs for the very fact that 0 is never the right offset....(when you burn a CD-R it is burnt with an offset and read with another offset).
          • juancdg
            • Mar 2008
            • 35
            What result did you obtain when you used your key disc? "+6" ? By the way, I cannot find any information about your drive, is a DVD Burner? Combo? CD-RW?
            • CaiXBo
              • Jan 2009
              It's a combo. I use -6 for Write Samples Offset, to test other drive, the results are same to the LIST. Then I test my drive, +6.
              Another, If a WAV ripped by 10 lower read samples offset than the drive is, what write samples offset I should use to burn this WAV file? THX
