Increasing volume level AFTER rip - possible?
  • Nubben
    • Apr 2008
    • 156
    Hi all,
    I recently purchased Depeche Mode DMBX boxes 1-6 and have ripped the tracks to iTunes in the AIFF/WAV format using dBpa.
    One thing I have noticed about the DMBX singles is that the volume level is very low compared to other Depeche CDs.
    My question is whether I can increase the volume level of the AIFF files using dBpa AFTER the fact that I have already ripped the tracks?
    Cheers.
    Nubben
    Re: Increasing volume level AFTER rip - possible?
    Yes, AIFF is lossless so you can perform manipulations (such as volume normalize) with existing AIFF files.
    • Nubben
      • Apr 2008
      • 156
      Thanks Spoon.
      I'm trying to normalise a set of singles to correspond with a remastered series of Depeche Mode albums. Can I take one track from the remastered series, analyze it (whatever dB value comes out) and then normalize a track from the singles to that particular value?
      Not sure how the normalisation would work - how can I be sure it won't clip etc?
      Thanks again!
      Nubben
      • Dr. Oviri
        • Mar 2008
        • 9
        Why not to increase volume BEFORE ripping?
