Adding CD Track Nmes Prior to Ripping - Easier Way?
  • jimzzzak
    • Aug 2008
    • 72
    As you may already know, I am ripping about 15,000 CDs to .flac.
    dBpoweramp CD ripper is certainly an invaluable tool.
    However, I find it cumbersome when entering the track names for CDs that don't have online metadata.
    Am I doing something wrong?
    I click around the track number once or twice and the track title then becomes editable.
    I then click ONCE OR TWICE on the next track number, etc.
    It would be nice if a track editing dialog would open in which one could edit all of the track names with one click and tab around the different fields.
    This easier track name entry would make it more likely for people to enter the data and submit it to AMG and Freedb so that others can use it subsequently. Just to give you an idea, I am submitting 5-10 CDs metadata per week as well as Accuraterip info on the new CDs.
    Maybe this type of trackname entry is available and I am missing it?
    Thanks for your consideration of this post.
    Happy Holidays where applicable.
  • moley6knipe
    • May 2008
    • 97
    Re: Adding CD Track Nmes Prior to Ripping - Easier Way?
    Alt+M
    • jimzzzak
      • Aug 2008
      • 72
      Wooohooooo.
      • jimzzzak
        • Aug 2008
        • 72
        Very strange.
        I am using Alt+M but I cannot get the editing window to open.
        What's up?
        • DazBYorks
          • Feb 2008
          • 59
          It would only seem to work if PerfectMeta is the data source.
          Daz
          • jimzzzak
            • Aug 2008
            • 72
            I don't understand.
            I just got to another CD with no metadata.
            I am unable to open the editing window with Alt+M.
            I am trying to add track names, etc. to CDs that are not in any of the online databases apparently.
            Why won't the editing window open???
            Can someone give me some definitive guidance?
              The windows only opens if there is data from 2 proivders.
              • jimzzzak
                • Aug 2008
                • 72
                Well, thanks for the information.
                May I request in a future version that the editing window open without this requirement?
                I have a lot of CDs that are not in the database and the editing window simplifies adding their metadata as well as then getting it online for the next person with that disc.
                Thanks for your consideration.
                • arthurb
                  • Feb 2008
                  • 36
                  It may not help much, but if you edit the first track name, when you are finished with it press Enter; that will take you into edit on the next track. I find this makes it easier, because I am so clumsy that it can take me several clicks before I get into Edit Mode.
                  I agree though, editing track names is a real pain in the...
                  That is a shame because, for me, the data from the outside providers is just a starting point - I very often want to edit it. Indeed, for my classical stuff, I usually change several pieces of Album data, and sometimes I have to change masses of stuff - Genre, Artist, Composer (getting rid of forenames), Album title (especially if dividing the album into new "albums"), track names, etc, etc.
                  Editing Album data is a pain...
                  • jimzzzak
                    • Aug 2008
                    • 72
                    I just wanted to thank the programmer.
                    With the current edition, I am able to open the track identification fields template up via Alt-M for easy entry/editing of the CD data. This is particularly useful for new CDs that are not in any of the databases that come with dBp.
                    Thanks!!!!
                    • eaglescout1998
                      • Apr 2009
                      • 203
                      Sometimes, the Alt+M method won't bring up the editing window if the main ripper window is inactive. Try clicking anywhere on the main program window and then try Alt+M.
