Please help! Offset for BENQ - DVD LS DW1655 [Purged]???
  • speshull
    • Oct 2008
    Hi it says purged.
    Does this mean you have no information for the drive or what offset should be used???
    Thanks!
    Re: Please help! Offset for BENQ - DVD LS DW1655 [Purged]???
    Spoon answered this here: http://forum.dbpoweramp.com/showthread.php?t=17757
    • speshull
      • Oct 2008
      Thanks I already saw that thread... but it doesn't explain which offset I should use to rip or if this specific drive changes offsets each time it is used. Is it going to be inaccurate regardless of what I use??
        You have to give it 3 key discs that return the same offset, then the drive is configured. However, you would be better off using a different drive to rip, because it was purged due to unreliability.
