Very ODD problem ripping to FLAC....please help?
  • gazjam
    • Oct 2008
    HI, new user over from EAC here...
    I'm using Vista64 and not had any problems with Version 13 Reference trial.
    I was getting an error (Twunk_16 incompatibiliy related error message - some funtionality was lost - wasn;t sure if rips WERE accurate or not) and other forum posts suggested would be fixed in Rel. 13.1.
    I downloaded the trial version of 13.1 and whilst I'm not getting the error message - and DP says the Rips are Accurate and successful - the actual flac files ripped are only 46K in size!?
    I tried it with different CDs and its just the same. Tried uninstalling DB and cleaning out reistry...all the usual stuff.
    One thing I noticed though(hope its relevant) is that despite uninstallin/reinstalling etc...my custom settings are still i place when I reinstall? Should this be right on a fresh install?
    PLease help, I've about 12 CD's to rip to complete my Library.....!
    Re: Very ODD problem ripping to FLAC....please help?
    Look at the DSP tab in CD Ripper, it should contain no items.
    • gazjam
      • Oct 2008
      In the last install I had Replaygain set...
      Checking 13.1 install....its still there?
      I'm stumped!
      *edit*
      I'll try disabling DSP and try again, thanks.
      • gazjam
        • Oct 2008
        *SOLVED*
        I disabled DSP - no avail.
        I reinstalled the FLAC codec...now it works.
        Possible conflict between R13.1 and existing FLAC codec plugin?
        Probably just my sysytem!
        Thanks for the quick reply.
